Question about Simplehuman Single Cup Pod Brewer Brushed Steel Coffee Maker
"add water" error message.
I just received a preowned A40. i filled the tank and powered on. i thought that i might have to go through the priming procedure but the machine doesn't ask for it. i'm getting an "add water" error message.
customer service says the sensor on the tank may be bad and will ship me a new tank. i'm leary. tank and float/sensor both look fine. i've read that they've had some problems with this product but nothing too specific.
anyone have any history? any one know how the "sensor" works? i hear water sloshing in the heater tank so i think it's primed.
  • claire_owens May 22, 2009
    I have the same "add water" error message but I've taken off the water tank and cannot see anything wrong.  I don't know where the magnet is that you talk about in your solution.
  • claire_owens May 11, 2010
    I can't see the magnet... I can't see the float!  Help!  I have the same error message and I've tried everything I can!
Problem solved! the float in the water tank has a magnet in it that the main unit senses. the previous owner cleaned the tank before shipping and installed the sensor upside down. if you disassemble the water tank, it is very easy to install the float incorrectly.
Posted on Nov 08, 2008
Ok, duh... sorry.  I found the magnet, turned it around and now I'm up and running again!  Thanks!
Posted on May 22, 2009
PRIME A GOULD PUMP
whats your question how to prime the pump? if so at the bottom is a 3/4 inch plug screwed into it, or at top, once the pump is hooked up to the lines turn off the power, and unscrew the prime plug fill with water, then screw in tight DO NOT USE THREAD SEALANT THEN THROW THE POWER TO THE PUMP, of course house supply valve must be off 3/4 turn valve off until the line is primed then open the supply line to house slowly to supply the water to all the lines, NOTE WHEN YOU FIRST INSTALL A NEW PUMP, HAS TO BE PRIMED, HAVE TO HAVE SUPPLY LINES FROM WELL TO HOUSE CLOSED TO PRESSURE THE TANK AND TO FILL THE LINES.
Apr 27, 2014 | Jet Flo 04325143A Marine Heavy Duty Water...
Won't prime
The water pump system is not primed properly. Remove the water tank while the pump is running and put back a couple of times. If not working, when the power is off, using a straw, blow air through and try to **** through the water port at the bottom of Keurig. Plug the water tank again in and start the system. It will take some time to prime, keep trying. There is nothing wrong with the machine, but the water pump circuit.
Oct 18, 2012 | Keurig Elite B40 Coffee Maker
Saeco Exprilia showing error E05 wont start. tries to prime water circut but then stops....help
Put vinegar in the water tank about 1/4 of a tank and 1/4 of tank water then turn the machine on with the water tank out ( so you don't get the priming message ) then it should tell you fill water tank put the tank in for 5 second and pull it out do it 3 - 5 times ones the vinegar gets in the system let in stay for a wile and then run the rest thrue the hot water and stem works for me I have real hard water at home
Apr 15, 2011 | Saeco Coffee Makers & Espresso Machines
My machine displays "Need to Prime". I attempt to prime it but the message keeps reappearing. In other words is seems that it is unable to be primed in the usual fashion. Any advise would be...
Ventilate message
That means the pump needs to be primed by running water through the wand. Push the water button and open the knob on the right. You will hear the pump change tone when it primes and the light or message will disappear. If you have a restriction in the intake line the message will not go away. There is a flow meter inside the machine that measures water flow. If the flow meter does not spin when the pump is running, the computer thinks that the pump is not primed. Coffee grounds can get into the intake and restrict the flow meter. If you get a restriction in the water intake (below the water tank, on the machine) the pump may run and water comes out, but the flow meter does not create the jet of water to spin the turbine wheel to send impulses to the computer. You get the ventilate message. One thing to remember is when you are working on the water system (have the water tank off) do not fill the bean hopper and visa versa. Keep them covered when working on the other. Cross contamination will damage a machine fast
The first thing that I would check is the tip of the steam wand for a plug. If that is clear then I would suspect a clogged flow meter. If you can get the flow meter out it twists apart and don't loose the parts and the dot on the turbine goes up. Clean out the small opening on the bottom pipes where the hoses attach. Look inside and make sure that they are clear before reassembling.
Oct 22, 2010 | Starbucks Saeco Italia Digital Barista...
My saeco royal has ventilate on the screen and is not working. what does this mean?
Hi That means the pump needs to be primed by running water through the wand. Push the water. You will hear the pump change tone when it primes and the light or message will disappear. If you have a restriction in the intake line the message will not go away. There is a flow meter inside the machine that measures water flow. If the flow meter does not spin when the pump is running, the computer thinks that the pump is not primed. Coffee grounds will get into the intake and restrict the flow meter. If you get a restriction in the water intake (below the water tank, on the machine) the pump may run and water comes out, but the flow meter does not create the jet of water to spin the turbine wheel to send impulses to the computer. You get the ventilate message. One thing to remember is when you are working on the water system (have the water tank off) do not fill the bean hopper and visa versa. Keep them covered when working on the other. Cross contamination will damage a machine fast
Feb 08, 2010 | Saeco Royal Professional Espresso Machine
What do I do when it says ventalate
Hi That means the pump needs to be primed by running water through the wand. Push the water button and open the knob on the right. You will hear the pump change tone when it primes and the light or message will disappear. If you have a restriction in the intake line the message will not go away. There is a flow meter inside the machine that measures water flow. If the flow meter does not spin when the pump is running, the computer thinks that the pump is not primed. Coffee grounds will get into the intake and restrict the flow meter. If you get a restriction in the water intake (below the water tank, on the machine) the pump may run and water comes out, but the flow meter does not create the jet of water to spin the turbine wheel to send impulses to the computer. You get the ventilate message. One thing to remember is when you are working on the water system (have the water tank off) do not fill the bean hopper and visa versa. Keep them covered when working on the other. Cross contamination will damage a machine fast
Feb 07, 2010 | Gaggia Titanium Espresso Machine
My machine is saying hot water ventilate what does that mean
Hi
That means the pump needs to be primed by running water through the wand. Push the water button and open the knob on the right. You will hear the pump change tone when it primes and the light or message will disappear. If you have a restriction in the intake line the message will not go away. There is a flow meter inside the machine that measures water flow. If the flow meter does not spin when the pump is running, the computer thinks that the pump is not primed. Coffee grounds will get into the intake and restrict the flow meter. If you get a restriction in the water intake (below the water tank, on the machine) the pump may run and water comes out, but the flow meter does not create the jet of water to spin the turbine wheel to send impulses to the computer. You get the ventilate message. One thing to remember is when you are working on the water system (have the water tank off) do not fill the bean hopper and visa versa. Keep them covered when working on the other. Cross contamination will damage a machine fast.
Oct 16, 2009 | Saeco INCANTO DELUXE Espresso Machine
Franke coffee system, always same error message ''fill water tank''
What you would have to do is take the side panel off to get at the solenoid. It is probably sticking closed and not letting the water fill into the boiler.
Mar 20, 2009 | Coffee Makers & Espresso Machines
What is the priming?
Prime refers to priming the pump. The error message means that there is air in the system which is preventing the pump from pumping water. To correct this, fill the tank with water, press the water button on the right side, and turn the water/steam knob to open. Allow the water to flow until the stream is steady. Press the water button again and your problem should be fixed
Feb 14, 2009 | Saeco Aroma Espresso Machine
Open Questions:
Simplehuman Single Cup Pod Brewer Brushed Steel Coffee Maker Logo
316 people viewed this question
Top Simplehuman Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Simplehuman Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
