Question about Goldstar Heating & Cooling
GE air conditioner remote control will not work, is a replacement printed circuit board available? The board is marked GoldStar P/NO 2Q01040A
  • rre77534 Nov 08, 2008
    Checking the batteries is the first thing you do.
    What I need is technical information about the printed circuit board - even a circuit diagram of the board would be helpful so that I can identify possible failed components or is a replacement circuit board available?
    some what
    President:
  • 2,712 Answers
If you know the model of your AC, you can purchase a replacement here:
http://www.vcrremotecontrols.com/Mfrs/device_files.php?brand=GE&dt=AIR%20CONDITIONER
Dont forget to "ACCEPT" the solution!
Posted on Nov 08, 2008
  • 728 Answers
Check the batteries and try to use it at close range if it is wireless.
    Sergeant:
    Novelist:
  • 196 Answers
Have you tried to replace the batteries in the remote control.
I have a goldstart gw 6500 the remote is not turning the unit on how can i fix it?
check battery in remote clean remote sender and a/c receiver replace remote
Jul 14, 2014 | Goldstar M5200R Air Conditioner
I have a GE Air Conditioner ASW 180AS1. It has a WJ26X10084 ARC-715 remote control that does not work!
You can access the circuit board by first removing one small phillipshead screw from inside the battery compartment. Next, pry the case apart at the parting line toward the front of the remote. On either side of the IR LED's you'll be able to push a very small flat tip in there and get the case to start coming off.
Once you have the case off, you cannot miss the capacitor. Its either blue or black with words like 4.7uF (microfarad) 50V 85degrees with a stripe on the right side.
Use a 30 watt soldering tool ($7 at an electornics store) to heat the solder mount and a pair of pliers to tug gently at the wire as you remove them from the liquid solder. Install the new capacitor into that same solder paying special attention to the matching stripe marking on the capacitor and PCB. Make sure you do not overheat the new capacitor as you install it.
Jun 21, 2012 | GE Air Conditioner Remote Control -...
GE split air unit.remote is intermittent.I have 2 remotes same problem. Should I replace the display board or the pc board it plugs into?Which one controls the signal?
Replace new batteries and check. Switch off ac,remove any dc wire from indoor unit and then re-fix it.Now try. If still problem, repair/replace PCB
Jun 01, 2011 | GE Quiet-Aire Ductless Mini Split System...
I need a GE Air conditioner Remote control #6711AR2853L
Try: Replacement Remotes.com
I have done business with them myself and they have always been very helpful. They offer reasonable prices and speedy service.
I hope they can help you. GOOD LUCK.
Jan 27, 2011 | GE AJCQ08ACB Air Conditioner
Temperature setting rises up by itself no matter how many times you lower it back down to a lower setting manually or with remote. When the unit acts up like this it won't even let you power off...
Most window units are circuit board controlled. Most all electrical circuits like the fan motor, compressor, and heating, are powered through the circuit board, and distributed through different circuits in that board(control board). I would guess you have a circuit board malfunction. It's possible the thermostat is sticking, allowing the control board to misread a return air temp. Without some troubleshooting it will be difficult to pinpoint the problem but I'd bet it's one of the two.
Oct 10, 2017 | GE APH10AA Air Conditioner
Goldstar GE120CE aircoditioner control panel
sounds like a bad circuit board inside contact GE and have them send you a replacement or have a tech service it for you
Jul 25, 2009 | Heating & Cooling
Unit will not turn on
I have two of these units (actually it is my sister and brother in law's) but they come to me to fix stuff.
Last year they came to me with this unit not working. No indication of power on the display. I diagnosed it down to the PWB Assmebly, Main. I believe they are referring to it as a Power printed circuit board (part #6871A20271A). The new board worked for about 4 months and then quit in the same manner. Also, the second unit quit in the same manner also indicating the circuit board is bad.
I don't want to throw a board at it till I know why they are burning out. Also, want to try to diagnose the board to component level ($33.28/board last year). Let me know if this helps if you have the same symptoms?
You can replace the board but my experience says it will only last for a short time till we find the real cause (Sears must know this problem exist).
Apr 21, 2009 | Kenmore 76129 Air Conditioner
I am looking for a remote control; see below.
I bought one from here: http://www.bestofferbuy.com/Universal-Air-Conditioner-Remote-Controller-Keychain-with-2LED--p-7228.html?currency=USD&utm_source=gbase&utm_medium=cse&utm_campaign=gbase
works great $3.50 free shipping
Mar 27, 2009 | Goldstar R7003 Air Conditioner
Replacement remote for window unit air conditioner
I have that model Air conditioner with remote. Although the remote is marked Admiral thats the only identifying marks on the outside. Here are pictures of the remote.
Top View
Side View
Battery Compartment Cover
Here is what is printed on the battery compartment cover label.
SHUNDE HUA AO
ELECTRONICS CO., LTD
Drawing No: DF11F1-01 (AL) KYK-1801
Part No: 814011422
QA: 01
Date: 2005.01.11
Hope this helps. You might try a company called Vance Baldwin they usually carry a large inventory of remote replacements for all kinds of applicances. Had to get a remote for my Panasonic DVD player and it was only $12.00 (brand new)
Mar 15, 2009 | Whirlpool ACC108PS Air Conditioner
Heating & Cooling Logo
87 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Dan Webster
Dan Webster
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
