Question about Air Tools & Compressors
Turbo i have a 99 F350 4x4 turbo crew cab.. truck ran real fine..till i had a new exsast instaled.. now runs like s..t.....took it back to the place that did it and told them it did nit smoke like this when i droped it off and now i also have oil running out of the turbo some were...........thay did atempt to fix it........but thay thought it was the full line and conection on the back of the head.......so tha replaced it at there cost not mine....now thay tell me that was not the trouble..it has oil comming from the turbo....... Thank u Mike
  • 341 Answers
If you have oil running out of turbo it could be the gasket between the oil lineand the turbo or it might be the ceramic seal in the turbo
Posted on Nov 08, 2008
Tip
How To Replace Silverado Sierra Crew Cab Replace REAR Inside Door Handle 99-02...
How To Install Replace Silverado Sierra Crew Cab Replace REAR Inside Door Handle 99-02 1AAuto.com<br /><br />This part is available on <a href="http://www.1aauto.com/1A/DoorHandleExterior/GMC/Sierra/1ADHS00104?utm_source=fixya&utm_medium=youtube&utm_campaign=1ATony">1aauto.com</a><br /><br /><utube src="aldIbCsoK3k"><br />
on Jun 23, 2011 | Chevrolet Silverado Cars & Trucks
Lack of power when accelerating
You really should have a code check done. There are numerous items that can give you similar symptoms. Two places to look are the fuel filter (usually overlooked till they gum up, and the throttle position sensor (but test it first with an ohmeter. You will need a manual (vehicle specific ones are available at most larger parts stores and most of those stores also do code testing free)
May 27, 2009 | 2006 GMC Sierra
Altenator draw
This engine has a heated intake and glow plugs. The heating element draws alot of juice from the batteries. After the heater cycles, the volt gauge wil jump back up. This is normal. Good luck
Apr 25, 2009 | 2003 Ford F250 Super Duty Crew Cab
Injectors problem
Injector maybe but i'd check the glow plugs if they are not working in some cylinders it could act the same way, only allowing a couple cylinders to preheat the fuel mixture for easier ignition, if it runs fine after it warms up the injectors are probably ok
Mar 15, 2009 | 1997 Ford F350 Crew Cab
Turbo problem
if you can take off the air hose on either side of the turbo. check if the blades still spin. if its damaged in any way. it won't spin properly. time to replace or rebuild turbo.
Stereo revomal
Chevy was creative with their placement of securing screws. There are others you are missing that probably are not obvious till you look real hard.
Feb 20, 2009 | 2004 Chevrolet Silverado 1500 Crew Cab
Air Tools & Compressors Logo
53 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
