Question about HP Office Equipment & Supplies
Hp office jet j6480 all in one will not turn off.
    Master:
  • 638 Answers
Remove the power cord directly from the back of the printer.and then wait for a minute.then reinsert the power cord.and check it should.turn ON/OFF properly.
Posted on Nov 08, 2008
HP OFFICE JET J6480 ALWAYS SPEWS OUT EXTRA BLANK PAGE AFTER PRINTING
Check if your document has empty lines at the end. Use your keyboard down arrow to scroll past the last line of text. Then backspace until you get to the last line.
Mar 09, 2016 | HP OfficeJet Office Equipment & Supplies
My HP OfficeJet J6480 All-in-One is leaving black vertical streaks on each side of the page when using the document feeder. Does not leave streaks when using the flatbed scanner. How do I correct
Hi
Just remove the ink cartridge. Clean the print head by a soft cloth with rubbing alcohol to remove some sticky or ink residue. Then rub the printhead into a plain paper until ink flows. Then run the print nozzle for 2 times.
I hope it helps you. Regards
Apr 09, 2011 | HP J4680 Office Jet All-In-One Printer
Officejet J6480 won't scan. It indicates no
If you have the cd installer for your printer, try to install the driver for scanner... don't forget to disable first the connection of your printer from your computer when installing the driver...
If you don't know the location of the driver, try browsing first the cd installer..
May 26, 2010 | HP J4680 Office Jet All-In-One Printer
How do i get my hp officejet j6480 all in one to scan to my computer?
If you're already set up to print with J6480, you can use the drivers built into Windows XP or Vista.
For Windows XP
For Windows Vista
Sep 22, 2009 | HP J4680 Office Jet All-In-One Printer
I have a new HP printer Office Jet J6480 all-in-one. I've had it less than a week. I was doing a lot of printing and it began putting a vertical streak down the paper and then the display said it was low...
Check the rollers that move the paper. There is probably some ink on one if them. You can usually clean them with warm water. Just use a damp cloth and rotate the wheel slowly by hand while holding the cloth against the suspect roller.
Jul 02, 2009 | Office Equipment & Supplies
HP Office Jet J6480
HI,
Follow the steps to refrsh the USB connection which will resolve your problem.
=== Refresh USB Devices ===
1. Right-click My Computer icon on the desktop, and then select
Properties.
2. Click the Hardware tab.
3. Click the Device Manager button.
4. Click the (+) sign to the left of Universal Serial Bus controllers.
5. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
6. Click 'OK' to confirm the removal of the device.
NOTE: Repeat steps 5 and 6 until all the devices under Universal Serial Bus Controller are removed.
7. Shut down the computer.
CAUTION: Ensure that the Shut Down option is selected, instead of the Restart option.
8. Wait for 5 seconds and then restart the computer. When the
computer restarts, a "Windows has detected new or added hardware" message window will open.
May 23, 2009 | HP Officejet 5610 All-In-One InkJet...
Black line when using feeder
Not familiar with this model in particular, but if you lift the document feeder, as if to place an original on the glass, there is either a narrow filter glass on the left of the main contact glass, or in many cases it is attached (clipped on) and lifts up with the document feeder cover. Clean this glass. If it is clipped on to the cover, remove it, and clean both sides. I hope this helps.
Please rate solution :)
Apr 24, 2009 | Office Equipment & Supplies
MY HP WIRELESS OFFICE JET MODEL #J6480 ALL IN ONE PRINTER WILL NOT SCAN. ATTEMPTING TO DO SO RESULTS IN A POP-UP WINDOW WHICH READS "NO HP DEVICES HAVE BEEN DETECTED>" I HAVE ANHP TOUCH SMART PC RUNNING...
Here is one simple thing to try (not guaranteed but it fixes the problem sometimes):
  • Turn off your OfficeJet
  • Shutdown your PC
  • Turn on your OfficeJet
  • Turn on your PC
  • Try scanning
The reason this this works some of the time is that the software has an incorrect IP address for the OfficeJet.
You might also need to configure your firewall to allow scanning. Try the above first and see if it helps.
If this does not fix the problem, as a temporary work around, there is a way to scan using the web browser on your PC (e.g., Internet Explorer) and type in the IP address of your OfficeJet, which you can get from the front panel of the OfficeJet. You will see an option to scan.
Craig
Although I am an HP employee, I am speaking for myself and not for HP.
Jan 16, 2009 | Office Equipment & Supplies
Need to download the manual for the scanning component of the hp officejet j6480 all-in-one
Hi - You can download the manual by clicking the link underlined in blue below:
j6480
See page 42
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 12, 2008 | HP Office Equipment & Supplies
70 people viewed this question
Seeker5211
Seeker5211
