Question about Gateway Computers & Internet
I need my firewall disconnected, and I need isp and password.. ? So netflex's Roku tv player can reactivate. 192.168.0.1 Cthrwh6@aol.com Catherine white
  • 1,879 Answers
For your ISP username and password - you need to ask your Internet Service Provider for those information.
Posted on Nov 07, 2008
Unable to find roku pin #
reset pin number: To reset the https://owner.roku.com and click Update under "Pin Preference".
Mar 02, 2015 | Roku Streaming Stick
Problem entering code
You may need to obtain a new code.
Go back to TV and select Help and then Get a new code.
Jan 13, 2015 | Roku Televison & Video
It's connected to my wi fi but it's telling me it can't connect to roku it says error code 011
The E011 error code is usually a router firewall problem. If you can turn off the firewall in the router when installing Roku that may solve the issue. This is not to be confused with the computer firewall in Windows which is left ON. When you go into SETTINGS/NETWORK your screen should look similiar to the attached picture. 25351243-jkwiv2v3rghcuytcwoewo3pc-1-1.jpg
Jan 02, 2015 | Roku Streaming Stick
How can I enter password in roku 3 I don't know how it connect and not work
I have created this document that will step you through the setup and also enter your password for your network. Hope this helps you.
Follow these steps to setup your Roku player 1. Connect to your TV
  • Use a HDMI cable. Connect one end to the HDMI port of the Roku player, and the other end to an available HDMI input on your TV.
  • Make note of the TV input used.
2. Power up key components
  • Open the battery compartment and carefully insert the provided batteries into the slots, following the correct battery orientation.
  • Power up the Roku player by connecting the provided power adapter to the Roku player and to an available wall outlet.
  • Turn on your TV and select the correct TV input.
3. Connect to your network
  • If you are using a wireless network, select "Wireless" as your network connection:
  • Select your network from the list of available networks.
  • Enter your wireless network password when prompted. (Note: passwords are case-sensitive)
  • If you are using an Ethernet wired connection, select "Wired (Ethernet)" as your network connection.
4. Complete guided setup
  • Get the latest software
  • Your Roku player will let you know if there is a software update available, and will restart after the update
    is complete.
  • Link your Roku player from any Internet browser
  • A link code should be displayed on the TV screen after restart
  • Using an Internet browser, follow the instructions to link your Roku player to a new or an existing Roku account.
Help for common setup mistakes and solutions
Symptom
Possible causes
Try these!
I don't see any picture on the TV
TV is OFF
Cable loose
Roku is OFF
Wrong TV input
Ensure TV is ON (it's more common than you think)
Check all connectors are snugly in place
Check power adapter is snugly connected, and wall outlet is working
Select the correct TV input
I can not connect to wireless network
Weak wireless signal
Wrong wireless name
Wrong wireless password Wireless name hidden
Move Roku player location (even a few inches may help)
Ensure correct network name selected
Ensure correct password entered
SSID can be hidden, use "Add Network" from wireless network screen
My remote does not work
Not in line of site
Batteries weak
Get closer and ensure there are no obstacles between your remote and the Roku player
Try a fresh set of batteries
Resolving wireless connectivity
If your Roku player isn't connecting to your wireless network, try the following:
Description
Do this
Tips
Repeat guided setup • •
Go to Settings>Network>Wireless•
If "Update connection" is available, select it to refresh your connection
If not, just select your wireless network from the list, enter your wireless password when prompted
If you were previously and just lost connection, you may not need to enter your password again
Passwords are case-sensitive
Restart the Roku player and • your wireless network
Unplug the power connector from • the back of the Roku player
Unplug the power connector from the back of your wireless router
Unplug the power connector from the back of your modem
Plug the power connector back into modem (wait a couple of minutes for it to fully boot)
Plug the power connector back into the wireless router (wait a couple of minutes for it to fully boot)
Plug the power connector back into your Roku player, and wait for the image on your TV
Follow repeat guided instructions above
Your wireless router and modem may be combined as one device
Factory reset the Roku player
From the Roku home screen, sele•ct Settings>Factory reset and follow the instructions
Note: You can also reset the Roku• player using the reset button. Find the reset button on your Roku player, press and hold for 15-20 seconds ( the front LED will rapidly blink a few times)
Factory reset should be used as the last resort, if all other steps failed to recover functionality
After a reset, you will need to relink your Roku player to your Roku account, and setup subscribed channels with username and password, if applicable
If you forgot your password, you can recover it here at this URL:
Forgot Password
A new password will be sent to the email account listed in your account. If you do not see the email, be sure to check your spam filter.
Sep 12, 2014 | Computers & Internet
Roku keeps saying i need to reactivate to have the same configuratin as my loopcom router
If those are the rules, then yes you have to, if you swap your router.
This is down to you ISP (ROKU).
Mar 08, 2014 | NetGear WNDR3300 - RangeMax Dual Band...
Can't enter code
Hi! If the information above is correct, your Roku player is a 2050X. It's one of the first generation Roku and it will give you a code to activate Netflix. To activate Netflix and the computer won't accept the code, it's possible that the code got expired. I suggest that you get a new code from your TV. Then access the link again on your computer and enter the code.
Mar 06, 2014 | Roku XD Streaming Player 1080P Wireless-N...
We want to movies from netflex on our emerson tv = what kind of device do i need
We want to ..............? movies from netflex on our emerson tv
Mar 07, 2012 | Emerson Televison & Video
Where do I enter my code for my roku netflex player?
If you have to activate ROKU player then go to www.roku.com/link
If you have to activate your netflix account go to
www.netflix.com/activate
Jan 11, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Computers & Internet Logo
55 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
