Question about Pioneer SD-P5795W 57" Rear Projection Television
Tv runs through vcr only. What can we do? Also need a manual. Where can we find one?
The tv will only run through the vcr and is set for channel 116, instead of the normal channel 3. What can we do? we tested the cable out on our old television and it worked fine.
Also need a manual for a SD P5795W. Do you know how we can get one, and how old is our tv? We just bought it used.
  • 905 Answers
Try to resolder the tuner first and see if that makes a difference , otherwise you may need to replace the tuner
does video inputs work ok?
Posted on Nov 08, 2008
Bought new samsung dvd/vcr. have an older admiral tv with just a cable hole. this is the second tv on a dish network, so this tv only has a cable, the box is in the living room. so how do I hook this...
The easiest way to make it work is to:
1- run your cable into your new VCR to CATV IN.
2-Your VCR should have come with a short length of cable. Connect it from the OUT jack to the TV.
3- Set the TV to either channel 3 or 4- you need to check the VCR manual to see which channel you have to use. Some VCR's have a small switch labeled "channel select"- if so, set it and your TV to the same channel... your choice.
4- Leave your TV on the channel you set above all the time. You will now change your channels using your VCR. You will be able to record whatever you are watching.
Feb 12, 2011 | Televison & Video
Looking for user manual for philips magnavox tv. 9P6044 C104, 3911Q1716. Trying to find out how to hook up my VCR to this tv. It has s viedo, video, L audio & R audio holes on front side of tv. I want...
Barb..be sure you run a TV signal through the VCR first. And then a coaxial from the VCR to the TV. This is the easiest solution for now. And set the vcr to tv/video {channel your movie is on}hit record and hit tv/video and watch your tv for another movie!
Feb 06, 2010 | Philips 9P6044C 60" Rear Projection...
I can't manually setup the Channels on my Panasonic PV 9451 VCR
In the Menu go to manual channel set-up not auto. When you're in manual set-up change channels until you get to to L-1 and L-2 (should be below Ch 2) and save both to memory. On some TV's the L-1 and L-2 are selected with a separate button labeled "input".
Aug 15, 2009 | Panasonic Televison & Video
Can we tape digital feed on a VCR and play it on an HD-ready tv?
You should be able to accomplish this. Run the antenna to your converter box. Run the video and audio outputs of the digital converter box to the inputs on your vcr. Your vcr should then be able to record the program (select line-in as the channel when setting up the recording). Hook your vcr audio and video output to your tv.
It's best to use a converter box that has an event timer - this allows the converter box to turn on at a specified time and channel. Otherwise you will need to manually set the channel you wish to record on the converterbox, and leave it turned on.
Mar 10, 2009 | Mitsubishi HS-U560 VHS VCR
I have an RCA converter box hooked up to an RCA TV and a Sanyo VCR. The TV and VCR are set on Channel 3. The converter box is set on Channel 4 and the TV is also switched to CH 4 when viewing digital...
Basically, you cannot use the coax connections for both the VCR and the RCA converter box. I would hook up the phono/cinch connectors from the VCR to the TV if you can (these are also called RCA connectors, but I'm avoiding using that name so we dont confuse the digital receiver with a cable/connector name that is the same here). There should be a yellow one for video and red/white ones for left and right stereo. I believe the RCA converter comes with a three headed cable that can do this for you. With this configuration, you can set the TV to input on these connectors and the VCR should always output there. Once that is set, you can still use the converter box to receive the signal from your antenna, then run the coax to the VCR. Now, the VCR will always have to be set on channel 4 in your setup and you will need to manually change channels on the converter box for it to record a show. Does this make sense so far?
Feb 27, 2009 | RCA Televison & Video
Connecting Hitachi VCR to my Direct TV.
Connect your Direct TV to the Ant. In connection on your VCR. When you want to watch TV, just tune the TV to channel 3 (or whatever channel the Receiver is set for). When you wish to record, set your VCR to that same channel and set your TV to the channel that your VCR outputs to. For simplicity sake, I would suggest setting both systems to channel 3 and just watching your program through the VCR. If you are still using an "off air" antenna, then connect that antenna to the ANT. IN connection on your Direct TV receiver and when you turn off the dish, it will pass the signal through just like the VCR would.
Jan 28, 2009 | Hitachi VTF392A VCR
Is my Toshiba 27AF42 TV bought in 2002 capable of receiving digital signals? And whether it is or not, how do I integrate my VCR into the TV and my converter box? Right now the TV is hooked up with the...
This is probably way too late an answer, but I just ran across your post. No TV made in 2002 has digital tuning, so you would need the converter box to watch off-the-air digital broadcasts.
To hook up the pieces, take the converter box output and run it to the VCR antenna input jack. Then run the output from the VCR to the TV's antenna input. Leave the VCR and TV both on channel 3 (or channel 4 if that's what you have the converter box output set for).
To watch TV, leave the VCR off and the signal from the converter will pass right through to the TV. You'll do your channel changing with the converter box, so the TV stays on channel 3. To record a program, just remember that the VCR will always need to be tuned to channel 3 (4), since it will have to be on the converter box output channel. Again, you pick the actual TV channel with the converter.
Note that this arrangement will allow you to program your VCR to record while you are out, but there are some limitations. You can't record things on different channels, since you won't be home to switch channels on the converter. The VCR is always recording on channel 3 (4), and the program you'll be recording is whatever channel the box is set for. If another program comes on on a different channel later, you won't be around to switch. But you could program different recording times on the same channel, anyway. You also can't record one program while watching a different channel, unless you had a second converter box.
Hope you can still use the information provided here. If this has been helpful, please take a moment to rate this a fixya. Thanks for asking here!
Dec 16, 2008 | Toshiba 27AF42 27" TV
Philips dvdr3575h/37 Initial setup
Do you have two cable inputs going into your player?
May 01, 2008 | Philips DVDR3575H/37
Not able to connect Sharp Model 25h-M60 to Laptop or DVD player
Use a VCR as a A/B switch. Run Cable signal into VCR. Run coax cable out of VCR into television. Connect DVD to VCR (line in) using RCA cables. To use DVD, set VCR channel to L1 or L2 or AUX, depending on VCR type. Set VCR to channel 3 or 4 to watch television. VCR must be powered up to watch DVD.
Apr 10, 2008 | Sharp 25H-M60 TV
Need help getting PIP to work
You don't have a problem except you need two tuners. You say you have a VCR, which this has a tuner. Set your VCR to TV and and start the PIP and choose your VCR as the second source. You will now be watching two different channels, one from the TV tuner and one from the VCR tuner. Also just to clarify, you should have the cable wire from the wall running to the INPUT on the VCR and then a cable running from the OUTPUT on the VCR to your TV to make this all work correctly.
May 24, 2007 | Philips 42PF7320A 42 in. Plasma HDTV
Pioneer SD-P5795W 57" Rear Projection Television Logo
177 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
