Question about Apex Digital GB51HD09 51" Rear Projection Television
Double picture When you first turn on tv you see double image. When it first started after 5 min. it cleared up. Now it takes 1.5 hours too clear up, so I leave tv on 24/7.
  • Apex Digital Master
  • 3,459 Answers
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
double picture - bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on May 30, 2010
When I turn on the set, the right half of the screen is distorted. It flickers, different colors move from center to far right of screen, double images that appear as negitives and sometimes that half of...
Symptom shows problem with lcd panel (screen) however, t-con board that is part of lcd panel could be defective and cause of these symptoms.
T-Con board is located at top center of cld panel at rear and would be covered with metal shield. There are three type of t-con board utilized according to lcd panel and are available in shopjimmy.com
Please check what t- con board is similar with your tv board to order it. If you are not handy with electronics stuff repair then local tv repairman will help you to replace t-con board that might solve your tv picture problem.
Thanks.
Jan 29, 2011 | Samsung LN46A550 LCD TV
How do we set the clock on Sharp logicook R-7N76?
Press stop/clear pad to remove 88:88 from the display.
Press auto start once for 12 hour clock and twice for 24 hour clock.
Enter hours first using 10 minute and 1 minute pad (i.e. for 12:00 - press 10 min button once and 1 minute button twice)
Press auto start.
Enter minutes as before using 10 min pad and 1 minute pad (i.e. for 35 mins press 10 min button 3 times and 1 min button 5 times)
Press auto start.
Jan 22, 2010 | Sharp Office Equipment & Supplies
Phillips big screen tv model 60PP9209/17F
I have seen this before--This set uses 2 convergence chips--usually they are STK-392-120 CHIPS--sometimes they will be flaky when cold--both chips need to be replaced and the set adjusted.
You can buy both chips on Ebay with shipping for less than 20 dollars. The chips are located on (usually) two metal heat sinks side by side and are about 2 1/2 inches wide and 1 1/2 inches tall---they will be black and have the STK number printed on them in white. If you open the set and locate them confirm the number that is printed on them.
Sooner or later if you keep using the set this way it will damage other parts around the chips.
MOST shops charge 300-400 for this kind of repair; I have done hundreds of these sets here for about 200-250 including parts, labor, house call.
If you cannot do the repair yourself look for someone in your area to do it--takes about an hour and any good tech can do it right in your house.
Make sure whoever you get to do it changes BOTH CHIPS--if not you will soon have the same kind of trouble again.
If you have any questions or need help reply to this post here.
I do this here for free so if this has helped you take a minute to give me a vote here.
Usually in this situation--just the 2 chips need to be replaced and the set adjusted!
Sep 07, 2009 | Televison & Video
32in Westinghouse lcd / picture scrambled
my westinghouse has the exact same problem....i have noticed it will catch sometimes when the screen changes from one picture to another that is totally different and one right after another......
Jun 30, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Picture clear, then "grainy" can hit TV and will clear up
sounds like a cold solder joint in the tuner circuitry. Unless you can do it yourself it's probably not going to be worth the repair bill.
Feb 08, 2009 | Toshiba 36A40 36" TV
Hitachi 53UWX10BA separated colors.
replace the convergence ICs you can get replacement ICs at the following link with free installation instructions. Use two STK392-150 ICs they are good durable ICs for your model,
Heres the link.
http://servicemanuals.vstore.ca/
Jan 17, 2009 | Hitachi 53UDX10B 53" Rear Projection...
I am getting double images while watching TV;
There maybe some loose components on the circuit and that needs resoldering. Bring it to the repair shop to done.
Dec 02, 2008 | Zenith C27A24T 27" TV
Fogging problem (i.e.) screen is foggy at start up but clears 20 to 30 mins use.
what is model number of your Sony tv to provide you info about foggy picture problem.
Oct 05, 2008 | Sony XL-2100U Projector Lamp for...
I have lost instruction book for Sharp Compact R250A microwave oven-how do I reset the clock?
May be a little late, but... 1. Press Power Level button for approx 5 seconds - you get the 12 hour clock 2. Press again for 24 hour clock 3. Set hours using the 10 min and 1 min buttons 4. Press Power level button 5. Set minutes using the 10 min and 1 min buttons 6. Press Power level button And you are done
Gert
Aug 05, 2008 | Sharp Microwave Ovens
Apex Digital GB51HD09 51" Rear Projection Television Logo
137 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
