Question about Akai LCT2701TD Television
Akai Lcd TV
Hi I am working on getting an akai tv to power up. Previously the standby light would blink red but i replaced the zener diode at z3 and the capacitors at ec18,19, and 20. Now the standby light is steady red but when i press the power button the green light goes on for a second and a half then goes back to steady red. I have a multimeter but this is my first real experience working at the component level of electronics. Where should i be looking and what am i looking for, thanks. my power supply board model number is mlt166a rev 1.3
  • ahabidi Nov 18, 2008
    I got my Akai (refurbished) online about 2 and a half years ago.4 weeks ago, it shut off after 10 minutes. Then it started shutting off after fewer minutes. I did not use it much, but few days back .. it shuts off after 1-2 seconds. Any Soln?
  • mrkrypto13 May 11, 2010
    Looks like we're in the same boat. I'm also working on fixing my LCT2701TD. I did the same thing: replaced the z3 zener diode and capacitors 18, 19, and 20. The only difference is that for me, the red light is blinking and never turns green.
    Maybe we can figure this out together? Would you mind checking if you have a capacitor near the top right numbered EC12? It looks like there should be one there, but for me that spot is empty. EC3 under heat sink 2 (lower right) is also missing. Could you check if you have those two and get back to me?
    Also, if you need the repair manual, you can get it at:
    http://esi.fox-international.com/manuals...
    It is slightly helpful.
    Some TV repair guy suggested changing the zener diode under heat sink 2. Here's a link to a forum with his explanation (although poorly written):
    http://www.circuitwork.com/archive/TV/20...
    Let me know if you have any luck fixing the TV - I will do the same.
    Kris
  • 2,335 Answers
If Z3 was shorted, there are 2 surface mount resistors that were damaged when Z3 became shorted and they have to be replace as well. The reference designator for the resistors is R65A and R65B, their value is 10 ohms and 1206 is the body size of the resistors.
If you need further assistance or to get the power supply repair, write to jah2mil@hotmail.com
Posted on Feb 21, 2009
Delay light is flashing on tv, but wont turn on. Not sure if problem is tv or remote? Dont see light on remote when push in buttons?
The problem with the unit is power supply part number,MLT166A.If you can not find one you can try to fix yours.First you have to take out power supply,Replace 3 electrolytic caps EC18,EC19,EC20 all are 1000mf at 16 volt.Then find Z3 on same board,it is a 27 volt zener diode 1 watt,part number 1N4750A.Put board back in then unit should work.
Oct 03, 2009 | Akai LCT3701AD 37 in. LCD Television
AKAI LCT2715 will not turn on gives blinking
This series of TVs has a famous issue with the power board (part number MLT166A or similar). Several capacitors and zener diodes burn out causing some resistors to burn as well. If you are capable of doing component level repairs check capacitors on the board and zeners Z2, Z3, Z4, Z5 and resistors around them. If you prefer to spend hundred bucks and simply buy the working power board for it - ebay is your answer.
Sep 06, 2009 | Akai LCT2715 27 in. LCD Television
AKAI TV Repair Question
Jan 16, 2009 | Akai LCT2701TD Television
AKAI 27" LCD Power Supply - Replacing capacitors and diodes
Kris,
You can always replace a lower voltage cap with a higher voltage just don't change the rating... In fact you could replace the 16v cap with a 400v cap if it would physically fit.
As far as replacing a zener under the heat sink, yes you'll probably have to remove the heat sink itself if it's blocking. And as for any words of wisdom - if your repair is unsuccessful try replacing the module. Shop Jimmy usually has them used if you don't want to spend full bore and order a new one.
Good Luck!
Bill
Jan 07, 2009 | Akai LCT2701TD Television
Akai LCT2715 No Power
I have a different thread going, but saw yours and had a question. Is your light blinking steady and then off? or is it a blinking erraticly or even flickering? My bad caps (15 of them) were all on the secondary side of the PSU. I have been told (thanks to Jaimie Hernandez) if you have a steady blinking, then it is very likely that you have a bad zener diode Z3(27v/1Watt) shorted in the primary side of the power board. If that diode is shorted, it's very likely that 2 10 ohms resistors might be open, these resistors are connected to the cathode of Z3. Also check for bad caps on the Primary side.
I had a huge incentive to fix the TV, it is my wife's TV and she has been in my Man Cave since it died. How about that incentive.
Good luck
Gallagher68
Oct 19, 2008 | Akai LCT2715 27 in. LCD Television
TV ON STANDBY MODE
The blinking light on the front indicates a shorted part in the power supply. The power board will need to be replace or repair to restore the LCD functionality.
Let me know if you required further assistance.
Oct 06, 2008 | Akai LCT3701AD 37 in. LCD Television
AKAI MLT168A Power Supply
If I give you the values of Z3, Z4 and Z5, would you return the favor by telling me what are the values for R104, R106, R107 and C17?
I have posted this request 5 times for 2 months and no body gave me an answer. Would you be willing to work with me? E-mail me s69joe@hotmail.com and use MLT168A-fixya as subject
Thanks
Sep 27, 2008 | Akai LCT2715 27 in. LCD Television
Flashing RED Light
Our AKAI also shut off & the red light started to blink...got no help from AKAI, but did from COSTCO. We bought the set before the 90 day warranty they have in place now, so they referred us to COSTCO Concierge Services: 1-866-861-0450. We were referred to a repair service & after discovering what the problem was found out that AKAI not longer has parts for this model. COSTCO replaced our TV---talk about satisfaction guaranteed.
May 14, 2008 | Akai LCT2701TD Television
AKAI LCT2701td TV No Picture
I had the same problem; the blinking light problem is caused by a bad power supply. It try’s to power up but senses a failure so it shuts down and just keeps repeating this process. I troubleshot the problem and found that zener diode Z3 (27volt 1 watt) was shorted and zener resistor forgot designation (2 surface mount 10 ohm resistors in parallel) were open. The zener is under a heat sink so it is hard to see. Also there were 4 1000uf capacitors that were bulging so I changed them as well. I got the parts from digikey for 20 bucks and its now working fine. This was a lower cost TV at the time of purchase so it seem the manufacture used low quality parts and I would suggest trying to return the TV to Costco before fixing it. Good luck.
Dec 24, 2007 | Akai LCT2701TD Television
Televison & Video Logo
513 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
