Question about Jensen VM9411 Car Video Player
Ipod and tv not working
My tv or ipod isn't showing pictures anymore. it use to now it stop. but my dvd works and other things work.
  • MARVOLUS May 11, 2008
    I JUST INSTALLED THE JENSEN 9411 EVERY THING WORKS BUT I CANT GET THE TV TO SHOW UP I TRYED UNPLUGING THE CORD THEN TURNING IT OFF THEN PLUGING IT BACK IN N STILL NOTHING. IT WONT SWITCH TO TV. WILL SWITCH TO CD, TUNER, CAMERA, AND AUX BUT NO TV. IF YOU CAN HELP WOULD BE GREATLY APPRECIATED. I ALSO TRYED TO PLUG THE CORD IN TO THE AUX AND CAMERA AND IT SAYS NO SIGNAL.
Turn the car off unpulg the ipod cable from the control module then plug it back into the module then turn the car back on.
Posted on Jul 15, 2007
Sound is working on the tv but the picture isn't
Is there a dvd or cd that came with it. I think you need to install the driver of the TV to your computer for them to work well.
David
Jul 26, 2013 | Televison & Video
VIZIO P50HDTV10A PICUTURE FLICKERS IN AND OUT CONTINIOUSLY WHILE WATCHING TV. PICTURE DOES NOT FLICKER IF WATCHING VIDEOS.
HI, you can do these troubleshooting steps and get back to me..
Instructions
Check the video connection of any devices plugged into the LCD television. If you can hear sound but are seeing no picture while trying to use something like a DVD player or cable box, the problem is probably that a wire is loose somewhere. Check the yellow video cables running from the DVD player to the TV and make sure everything is plugged in firmly and where it should be. Also check the coaxial cable running from the cable box (or cable outlet) to the television and make sure that wire is also screwed in securely.
Check the image settings on your television and make sure everything is set properly. Certain settings like "Picture" or "Brightness," if set to one extreme, can make the picture appear completely black. This could cause you to simply hear television shows but not be able to see them. Reset all picture settings on the TV to their original factory default settings to see if that fixes the problem.
Try another channel. If you're watching TV and not getting a picture, the first thing you should do is check a variety of random channels to make sure it is a problem with your TV and not with your television signal. If it is a problem with the television signal it is the fault of the TV station or cable service provider and there isn't anything you can do yourself to fix it.
Try the DVD on another DVD player. If you're trying to play a DVD and can't see any images, make sure the disc isn't defective. Try it on another DVD player or a computer DVD drive and make sure the disc works in the first place.
Hope it helped ..
Jun 17, 2011 | Televison & Video
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
When trying to play movies on tv through ipod using apple component av cable picture shows up double on screen
You may refer to the part 8 of this iPod tips, it will teach you how to connect iPod to TV and watch the iPod video on TV. It works pretty well for me.
http://www.mac-dvd.com/ipod-tips-and-ipod-faq.html
Hope it helps. Contact me if you have any other question.
Jan 30, 2010 | Apple iPod classic MP3 Player
Dish menu but no picture or sound
Try holding the power button in on the receiver until the picture goes away then turn it aloose it will reboot and your sound will usually come back. If you had rather and can get to it unplugging it from the electric outlet, the receiver, does the same thing.
Oct 21, 2009 | Televison & Video
Nothing works
i had exactly the same problem but not anymore. i called the haier co. and they told me to order a new remote control so i did. i got my new remote and i turned my tv on and pushed the tv/use and it worked thank god. so maybe you could try it. remote control only 20.00 good luck!
Mar 14, 2009 | Haier HP42BB 42 in. Plasma TV
No output from ipod
are you using the holder things that are supposed to hold the ipod steady in the dock, if so take it out. my ipod only works in there if its by itself.
although now it wont play any sound from my ipod (movies or videos) but will play sound from dvd and tv. any suggestions?
Jan 02, 2009 | Televison & Video
No picture, but can hear sound
hold down the stop button for 5 sec on your dvd player not the one on the remote control
Check your connections. Make sure they are hooked up correctly(ie yellow to yellow. Check both the connectoins on the dvd player and the tv.
Feb 11, 2008 | Cyberhome CH-DVD 300 DVD Player
Car Audio & Video Logo
41 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
