Question about Memorex MLT3221 32 in. LCD TV
TV Automatically Turns Off
My TV is turning off on it's own. It has random increments and it may turn of 10 seconds within turning back on or 10 minutes. It sometimes goes days without turning on. It also automatically turns on which forces me to unplug it just so it won't disturb me anymore.
  • sr_hupia Jan 27, 2009
    I have the same problem with Memorex tv MLT 1921 but it shot down and don't turn on again automatically
  • Memorex Master
  • 5,568 Answers
There are so many different places where an intermittant problem of this kind could occur, it will be nearly impossible for anyone to give you any clear guidance on this one. The most common failure in modern sets is related to the power supply but that kind of problem is one that appears sometimes as a gradual decay of its time to power up or a decreasing length of operating time and finally a failure to turn on at all.
There is a section that is kept 'alive' by a small part of the power supply so the set can accept commands from your remote to power up the rest of the set and the receiver of the remote's IR output stays turned on as long as AC is connected. This section could have a semiconductor that is intermittant so that it sends a command to turn the set on or off without you using the remote to send the command. There are tens of thousands of individual active and passive components in our modern sets and only one single part needs to be randomly failing to cause your problem.
There is a slim chance that the remote is the culprit since they too are never completely 'off' and it could be sending commands on its own. To eliminate this possibility, either take the battery out of the remote or put a pillow on top of it so the IR signal is absolutely disabled.
If the set still does what it pleases, then the remote is OK and the trouble is then definitely in the set itself.
The remote receiver electronics in the set could be part of the main board or a separate item on a small auxilliary board so whoever gets this to repair will need the whole set available.
Posted on Dec 07, 2008
My TV randomly switches itself off and the red light flashes continously and i have to pull out the plug. its getting more frequent
Samsung TV Keeps Shutting Down - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - When I turn the TV on for the first time each day it shuts itself off within 30 seconds. ... green light flashing red light is [standby term] green light is [lamp]flashing. samsung plasma 850 picks up other remote signals?
Jun 12, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
Volume goes automatically to 0 on my Samsung LCD TV
Jun 10, 2015
Why TV turns off by itself?
Jul 12, 2012
More results from www.cnet.com
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. .... Samsung E6030 led tv hv blinkin red light ...
Dec 25, 2015 | Televison & Video
I have a 58 inch Sanyo flat screen TV, I turn it on everything works fine, shuts down in about 10 minutes! Sound stays on though. If I shut it off and turn it back on it does the same thing!
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the... the Sanyo DP47460 that I'm having an issue with. after ~ 40minutes of watching, if I attempt to change the channel or adjust the volume, the picture/screen freezes. ... After ~ 20 seconds, theTV will automatically shut off, then turn back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Hi, I've got a Samsung LED TV that switches off after20 seconds and remains off. .... after about couple of minutes, is this the same problem with the tv in the video? .... 10:32. How to repair a Samsung LCD TV with a flashing standby ...
TV Turns On, Backlight Inverter Immediately Turns Off TV ..
Dec 17, 2015 | Televison & Video
I have a Panasonic plasma TV model# TH-42PX75U --- here is a link to Panasonic web site for this model...
Unfortunately your going to have to have it serviced by an Authorized Panasonic Dealer. Independent shops will not be authorized to order parts without the consent of Panasonic. They are rough to deal with.
Dec 20, 2010 | Televison & Video
TV turns on/off automatically at 1-2 mins intervals.
Replace the power supply, PN: BN44-00206A
It's easy to locate, but requires adjustments once it is installed. Panel voltages must be adjusted according the the specifications of the TV. There is a sticker on the back of the plasma panel which provides each voltage setting. You can reference this sticker to make the proper adjustment. Using a DMM, connected between chassis ground and the panel voltage you are adjusting, turn the adjustments on the power supply very slowly, until you are measuring the specified voltage within 0.5v. I hope this helps and good luck.
Mar 15, 2010 | Samsung PN50A400 50 in. HDTV Plasma TV
Tv turns off randomly but turns on after 35 seconds.
How old is this TV and when did you replaced lamp last time?
Jun 09, 2009 | Panasonic Televison & Video
LG 52SX4D turns off randomly.
My Lg 52"tv turn off and on
Apr 29, 2009 | Televison & Video
Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
Aug 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Turns on but turns off automatically after being on 5-10 seconds, HELP!!!
The belt of the charge motor of the vcr are in bad conditions you gotta cnange it.Thats all the problem.
May 07, 2008 | Emerson EWC1903 19 in. TV/VCR Combo
Powers on and off randomly
one of your tubes are bad...call tech
Nov 26, 2007 | Toshiba TP55H60 55" Rear Projection...
TV turns off
It sounds like you might either have a bad power cord or you might have an over heating issue. Some times the TV will automatically shut off if it senses a fan issue or it starts to overheat. What technology is your set? DLP, LCOS, DILA...? If its under warranty I'd suggest to get someone out asap to take a look at it.
Sep 13, 2007 | Hitachi 57SWX20B 57" Rear Projection...
Memorex MLT3221 32 in. LCD TV Logo
179 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
