Question about Electrical Supplies
Touch lamp repair
I have a touch lamp that had a blown bulb, replaced the bulb and the lamp will still not light either by switch or touch. There is no identifying information on the lamp other than "portable lamp" and "Made in China", there is a few numbers but no brand name.
  • Anonymous Jan 12, 2009
    I have two touch lamps that won't turn on. After talking with the electronics guy he said that the triac (bt137) is usually the problem. If you take off the bottom plastic plate of the lamp you will find a small black plastic box. Inside this box you will find a small circuit board. On the circuit board look for a black three pronged triac. On the board itself it may be labellled tr-1. Now that you have located it unsolder it from the board and replace it with a new triac from your local electronics supplier (cost about $3.75 each). I hope this will be helpful.
    Scholar:
  • 127 Answers
Double check that the replacement bulb is good. If it is, then when the old bulb blew, it probably shorted and destroyed the touch sensor. The touch sensor is replaceable and is usually located in the base of the lamp. You may have to peel off some felt on the base to expose the screws that hold the base on. Touch sensors are generally available at hardware stores, electrical supply stores, or lighting stores and are around $10-15. They are easy to wire. Just follow the instructions and observe the way the old one was wired. You may need some small wire nuts if they don't come with the new sensor.
Posted on Dec 23, 2008
Dear Manager, We are now working out some small stuff,which can be a hit in your market.and own lots of profits. One of them is Magic touch lamp, Model No.: CL-600 Touch lamp repair - 1060(04-07-00-10-11).jpg Features: 64 colors changing automaticly. Touch switch. Romantic design Choose color according to color ring Compliance to RoHS FOB price for 2000pcs is 5.38 US$. similar product retail price in Europe is 59€ Contact us for sample to test.
Thanks & Best regards,
John Leung/sales superisor
Comet LED Co.,Ltd
Tel:+86-755-29229582
Fax:+86-755-86594079
Cel:+86-133-16549081
john@cometled.net
www.cometled.net
Posted on Apr 06, 2011
No power to left rear turn/ brake light
Check the display. Ask a helper to step on the brake pedal while you check the lights from the rear. If no lights appear, check the fuse that connects the brake lights. The owners manual will show the location of the fuse box and which fuse is for the brake lights. Pull out the fuse and look at the wire in the central window. If the wire is broken, replace the fuse. Make sure the new fuse is not blown, and carries the same amperage.
Take note of lights that are out, if any are working. The problem may be cured by replacing the bulb in a brake light that's out. A burned out bulb has a broken filament and a dark brown spot on one side. Check the owners manual for bulb type.
Check the circuit if replacement bulbs and fuses do not restore the lights. Find the wiring diagram in the vehicle assembly manual. The circuit for the brake lights runs from the battery to the fuse, to the pedal switch, to a connection plug, to the lights. The circuit has to be checked with a volt tester at all points.
Check the battery power and the light on your volt tester. Turn the ignition key far enough to activate the electrical systems. Turn on the lights to check for battery power. If the battery has power, ues it to check the volt tester. Put the black lead (the ground) from the volt tester on the negative battery terminal. Briefly touch the red tester light on the positive terminal. The light on the volt tester should flash brightly.
Test the wiring to the fuse. Clip the ground wire to solid metal near the fuse. Touch the light tip to both sides of the fuse. Both should light the tester. If neither side lights, the wire between the battery and fuse is bad. If only one side lights, the fuse is blown.
Test the switch and wiring. Touch the light tip of the tester to both terminals on the brake pedal switch without putting any pressure on the pedal. One should carry power and the other should not. When both show power, the switch is stuck and the brake lights are always on. If neither shows power, the wiring between the fuse and the switch is bad. Now check both switch terminals while the pedal is depressed. Both sides should light the tester. If not, the switch is bad.
Check the connection plug. Unplug the connection and refer to the vehicle manual to identify the brake light wire. Touch the tester light on the brake light wire at the inner socket on the battery side. If the tester lights, the power is flowing to this point. If not, the wire between the plug and the pedal switch is bad.
Check the socket. Plug in the connector plug and remove the bulb. Touch the contact inside the socket. If the tester lights, the socket is good. The socket and wire running to the plug should be replaced if the tester doesn't light.
Check the bulb with the ground wire. The bulb must be in its socket. The ground wire running to the socket should be black or brown. Stab the tester through the insulation. If the tester lights, the bulb is good. Replace the bulb if it doesn't light.
Check the ground wire. Remove some of the insulation around the ground wire. Twist one end of the extra wire around the exposed ground wire. Touch the other end to a solid piece of metal. If the brake light comes on, the ground wire is bad.
Best Offer 2013 11 MB SD Connect Compact C4 Star Diagnosis with WiFi
Oct 13, 2014 | 2000 Ford Expedition
How to replace bulb in front bumper turn signal housing 1995 jag xj6
hello,
  • Identify the blown bulb. Note that if a headlight bulb has blown, the dip beam is on the outside and the high beam is on the inside. Turn off the ignition switch and light switches.
  • Open the hood and replace any blown headlight bulbs. Press the plastic spring clips and remove the bulb holder from the assembly. Pull the bulb out of the bulb holder and replace it with a new bulb. It only fits one way. Be sure not to touch the bulb's glass. Replace any parking lights at the same time, they are in the headlamp unit too.
  • Remove the front turn signal light unit in the bumper to change the turn signal bulb. Push gently on the inside edge and insert a blade between the bumper and the lens at the outside edge. Compress the spring and remove the lens. Fit a new lamp by inserting it into the plug. The side marker light is changed using a similar process.
  • Open the trunk to replace the rear fog light, stop light, tail light, reversing light and turn signal light. Remove the rear light cover and turn the bulb holder fastener 90 degrees counter clockwise. Remove the expired bulb, fit a new one and replace the parts, turning the bulb holder clockwise.
  • Thanks..
    May 21, 2011 | 1995 Jaguar XJ6
    Just replaced the lamp, worked for about 3-4 days, tv won't turn on, green light flash about 3-4 times then a red light flashes, waited about two days, tv came on and worked for about 1 month now the same...
    I have the same TV and had same problem . Try taking the bulb and assembly out and reinstall , there are some sensors on the assemblies that might not be getting good contact . It fixed mine .
    Jan 20, 2011 | Sony KDF-50E2000 50" HDTV
    The head lights becomes brighter, then a big flash, and its blown
    If lense is cracked this can occur from water or rain on a hot bulb. this can also occur from oils on your hands when replacing bulb. Make sure you don't touch bulb when replacing. If bulb is touched wipe it off with tissue or a towel. If non of this is an issue check to make sure that the correct type fuse is in place, and make sure voltage at head lamp is not too high. Also check for ground problems.
    Jul 18, 2010 | Ford Laser Cars & Trucks
    Hera Touch Dimmer not working
    if what you are refering to is a touch lamp where you touch the base and the lamp changes brightness ... if it just stays on full brightness all the time .. then thats a shorted triac .. that a transistor like part inside the unit .. they frequently go bad when a light bulb burns out ... when you see a bulb burn out you will someitmes notice a very bright flash ... thats the tungstun filiment evaporating and making a highly conductive atmosphere for a second .. huge amount of current can flow for this brief period .. that often damages solid state devices like yours ... unless you are handy with these kinds of repairs then you might just want to purchase a new touch dimmer replacement circuit ... usually available at large hardware stores ..
    Oct 04, 2009 | RTO Hera 4-Level Touch Dimmer 110 Volt
    I have a OK Lighting touch lamp and three of the glass planels are broken do you kow whenere I can get replacements
    Hello there:
    here is several links that will definatly help you in your quest to find touch lamp glass ok? look below mainly # 3
    best regards michael
    1. Lamp Shades - Glass Lampshades - Silk Replacement Lamp Shades - 2000 item catalog of glass lampshades, silk replacement. ... Finishing Touch - Finials. Tulip - Lilly - Large -Small. Oil Lamps & Fonts ...www.specialtylampshades.com
    2. Speciality Lamp Shades Add a finishing touch to your shades. Reverse Painted & Dome Glass Shades ... Replacement Glass Lamp Shades- Reproduction & Custom ...www.specialtylampshades.com/lampshades.html - Cached
    3. Touch & Glow Replacement Kit | LampsPlus.com 3-way touch lamp. Saves energy. Extend bulb life. ... Glass Shades. Light Bulbs. Night Lights. Under Cabinet. View All Categories. Bathroom Lighting ...lampsplus.com/.../Touch-and-Glow-Replacement-Kit__35098.html - 110k - Cached
    4. Elegant Touch: Brown's Lampshades ... a special accent for your special lamp and replacement lamp shades. ... Glass Small Tear Drop Lamp Finial. c3-finial $12.95. Crystal Gothic Cross Lamp Finial ...brownslampshades.com/store/ctgy/elegant-touch.html - Cached
    5. Nec Display Solutions 50016683 Replacement Lamp - Yahoo! Shopping Yahoo! Shopping has Nec Display Solutions 50016683 Replacement Lamp. Quick Links: Specifications - Description - Compare Prices shopping.yahoo.com/p:Nec Display Solutions 50016683 Replacement Lamp... - 126k
    6. Replacement Shade for 2198 Floor Lamp - Shop.com Shop for Replacement Shade for 2198 Floor Lamp and Floor Lamps at Shop.com. the 2198TA lamp was designed by fontana arte in 1954. a very dignified modern touch to an...shop.com/replacement_shade_for_2198_floor_lamp-59830151-7...
    lamp
    Sep 24, 2009 | Electrical Supplies
    Replaced the projector lamp 3 weeks ago. Reset
    If the lamp is working it should be fairly obvious but stand to one side of the lens and see whether there is any light coming from the projector. If there is you know that it's an input problem. If there isn't either a fuse has gone, the bulb has blown or the filters might need cleaning. If the bulb has blown it's probably because you handled the bulb. It's vital not to touch these bulbs with your fingers. If you do wipe it with methylated spirits.
    Aug 21, 2009 | Sharp Office Equipment & Supplies
    Our touch sensitive lamp no longer responds to touch
    The sensors do not wear out as such, the fault probably is in the electronics and you should not attempt a repair unless you are suitably qualified as mains voltages are involved.
    Nov 22, 2008 | Optics
    MICROWAVE BULB
    Hi There!
    Most microwave ovens today requires you to remove the cover to replace a lamp. Normally situated next to the Magnetron. Check the inside cavity for tiny holes where the light is suppose to shine through. This will indicate where the lamp is situated. Remember to unplug from mains before opening the unit and try not to touch the High Voltage components. They may still be charged. Good Luck, JUS004
    Feb 26, 2008 | Microwave Ovens
    Electrical Supplies Logo
    7,244 people viewed this question
    Top Electrical Supplies Experts
    Craig Butler
    Craig Butler
    Steve
    Gene Haynes
    Are you an Electrical Supply Expert? Answer questions, earn points and help others
