Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Automatic Transmission is squealing and bogs down when under load
When going uphill, or when I have my bagger on, the auto trans squeals real bad, and the tractor slows right down. I have to bring the speed lever to a crawl make it move at all. It acts like a fluid problem in hydraulics. Is there a way to add or check?
  • Anonymous Jan 04, 2009
    I have the same problem where my Craftsman 20 HP 42 inch cut tractor barely moves after I shutoff the mower and move the throttle to the higher speed positions. I need to slow it down to keep it moving. Is it a motion belt issue - the tractor is 9 years old and in very good condition. How do I fond out how to change out the motion drive belt?
  • chris killeen
    chris killeen May 11, 2010
    what make and model is your mower?
  • 17 Answers
Check the trans drive belt, most likely that, or a worn tension pulley. check easy things first. Try pulling back on foot pedal to give belt a bit more tension.
If the trans looks clean and no leeks start with the belt.
Posted on Jan 12, 2009
What causes a high pitched squeal in the dash of my honda crv 1998 2 wheel drive automatic transmission. It happens periodically when I have the blower turned on
That is the blower motor. It is a small electric motor under the dash that mounts on the plenum. When it starts to go bad, it squeals. They are about 100 dollars at autozone.
Feb 28, 2015 | Honda Cars & Trucks
Why do my transmission squeal
If the vehicle is high milage, it could be a bearing going bad. Good Luck
Sep 01, 2014 | RTO Automatic Transmission And Engine Oil...
Transmission squeals when changing gears.
Check the fluid to see if the radiator oil cooler is bad &
ruined the trans
VERY VERY Common & WELL Known problem with pathfinder
& frontiers from 04 to 08
You may need a new radiator,bypass the trans cooler lines to it
& go to the front cooler only, then rebuild the trans
There are at least 8 updates to do to the valve body alone
Check Sonnax.Com for that
There is more info on all that on the internet,than you could read
in an evening & NO Nissan is out of the picture.
It is up to you to educate yourself before & during ownership
of any & all vehicles & check for govt recalls,it's all there
on the web
Mar 19, 2014 | 2005 Nissan Pathfinder
I have a 1998 Chevy S10 automatic, rebuilt transmission with about 9000 miles on it. I have already changed the transmission fluid and filter, have done tune-up and put on a new fuel filter. When driving...
I would go with a clogged exhaust converter
Also possibly a bad fuel pressure regulator & spyder
poppet valve assy under the intake manifold
That is a common problem if you smell gas
Replace the front oxygen sensors every 100,000 miles
Nov 21, 2012 | Cars & Trucks
Squealing sound when making ice
most of the time it is the water pump is going bad. It squeals real loud.
Sep 25, 2012 | Hoshizaki Freezer Commercial Ice Machines...
Front of car squeals when turning .Feels like a tire was wobbly going on the highway. Real screachy sound ....any idea what may be going on it or possibilities ???
There are several possible causes, varying in severity, that could be responsible:
  • Lack of power steering fluid
  • Bad or worn serpentine belt - would slip when turning causing a squeal and/or difficulty steering
  • Bad wheel bearings - this would cause the wheel to wobble, and squeal on turns
  • Bad ball joint(s)
  • Bad steering box
Mar 24, 2011 | 2000 Hyundai Accent
My 2005 Freestar 4.2 has 88,000 miles. Trans. replaced at 75,000. Recently, the engine would stall at idle when going down side street. When going down a faster road, there would be a slight squeal under...
You should open the hood,put someone else in the car and have them rev the engine while you observe the engine because pinpointing it will really help.Even though you are not running the A/C,the compressor is still being turned by the belt.Also,right now I would make a diagram of the belt routing in case it breaks.Some cars do have a sticker with the diagram under the hood,usually toward the front.If you do not use your A/C much,the bearing may be hanging up as well as any part belt driven which you have not replaced and may be making it squeal.Also,if your compressor ends up seizing,and you do not use the A/C much,and is expensive to replace(which also happened to me),I searched and found another car with the same exact engine but was made with no A/C.I had a Buick and the substitute was a Chevy.Most of my answer is for future possibilities but for now just try to pinpoint it and go from there.Some cars just do squeal after time but you also had bogging and stalling which is not normal(obviously).Also inspect your belt.Check the edges for fraying.Check the width for cracks.Many small cracks fairly close together or a few large cracks a couple inches apart is cause for concern.If any of these are present,you should at least get a belt to keep in the car in case it snaps.I would put off replacing for now until you can figure out what is happening.My answers are usually lengthy because I try to inform,educate,and give almost every scenario which could happen so there is no surprise.
Good luck! Greg
Sep 21, 2010 | 2005 Ford Freestar
High pitch squeal when going up steep inclines
what kind or vehicle? manual or automatic trans, 4 wheel drive or 2 wheel, could be clutches straining. some u joints make sounds under a load as well
Sep 07, 2010 | Ford F-250 Cars & Trucks
91 GMC Siera 4x4 1500 automatic transmission slipping
Yes the trans can wipe out the crank bearings or the spacer behind the crank(forget what its called) it can let the flexplate move and the bolts can hit.That may be what your hearing. Does it still have good oil pressure?
Oct 17, 2017 | 1991 GMC C1500
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
708 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
