Optimus lab1100 ok ive never had to change the belt on my turntable before.how exactly do i do it maybe u have a diagram or something.please email me at clutchitup750@yahoo.com thank you very much.
  • Anonymous Nov 24, 2008
    please someone tell us where to find a diagram ...
    Problem Solver:
  • 7 Answers
First you should set the turntable on fire then put it into the washer, the microwave it. that works
Posted on Nov 08, 2008
Need a diagram of the belt configuration
Check out YouTube there are some standard videos on belt replacement that might apply to your model.
Oct 14, 2015 | Teac P-A688 Turntable
HOW TO INSTALL A BELT ON A OPTIMUS LAB-1100 FULLY AUTOMATIC TURNTABLE
See:
http://www.youtube.com/watch?v=FTJd_WbEhEs
If you have difficulty lifting the platter off, raise it as far as you can and gently tap the spindle with a sift-faced hammer.
Sep 23, 2014 | Audio Players & Recorders
I need a diagram to re-install belt on Sony turntable PS-LX250H
I'm sorry for the difficulties you're experiencing in installing the drive belt. Please click hear to get the instructions to install a drive belt. Please click on the sub links on the page to view the diagrams.
Thanks for understanding. Please let me know if you require any clarifications.
Aug 01, 2011 | Sony PS-LX250H Turntable
Turntable is slow, especially noticable on 33 1/3 rpm
hi,
your turn table is a belt driven one. The speed turns down when the belt become expanded. you should replace the belt of your turn table. Also put some lubricant in its center shaft ( not from the top lubricate it slightly after removing the plater).
I have here added some video related to the replacement of belt for turntables.
Not the exact for your one,for all the belt driven turntable the procedure is the same
ok
Jan 17, 2011 | Crosley CR248 Turntable
Is there a belt diagram for Optimus LAB-460 turntable
try radio shack website,,or optimus site,,,for it,,should have manual
Nov 03, 2010 | Radio Shack Audio Players & Recorders
Optimus 1000 belt drive automatic turntable
Usually, for most turntables, the belt goes on the bottom of the platter first. Then you put the platter back on the turntable. From here you should see an opening on the platter where you can 'grab' the belt. Pinch the belt, and then wrap it around the rotating motor's shaft. This is usually at the top left side - around the 10 o'clock position.
- OPTiC
Turntable Technician
www.1200s.com
Aug 17, 2008 | Audio Players & Recorders
Optimus lab 1100 Turntable won't turn!
The mechanics in your arm postion is throwing the switch. A mechanical postion switch has sliped out of postion, a arm from the toner arm post has moved to an encorrect postion, or if your turntable has a multi-album play abilty your 'next to play record' post postion sensor switch is out of postion. Last or first is your belt could fool ya. Your belt may have a weak spot on it in turn no friction underload.
Aug 07, 2008 | Audio Players & Recorders
How to remove platter on Optimus Lab-1100 Turntable
on the shaft in the center where the hole of the record goes there is a locking washer on it . you can carefully remove this with a thin knife of something similar . you may need to use a little force , it is on there pretty tight however it can be removed .good luck
Jul 21, 2008 | Audio Players & Recorders
Will not turn on (no rotation of turntable)
theres not much to a turntable if belt is on and you can turn the table freely then i would guess there be a blown fuse inside
Dec 31, 2007 | Denon DP-29F Turntable
Emerson NR303TT Turntable won't work
http://www.archive.org/details/Turntable_Belt_Installation
above is a generic video that applies to almost all belt driven turntables including yours that will show how to install the belt and a few other things. maybe something in the video will clear up exactly how to get the belt on right.
if motor won't spin, spin it with your fingers, sometimes a "dead spot" developes on these motors. if it then starts on it's own, just let it run for a few hrs and the problem may solve itself for a long long time.
Dec 12, 2007 | Emerson NR303TT CD Shelf System
168 people viewed this question
 Grubhead
Grubhead
