Question about Hyundai Q320 32 in. LCD Television
Hyundai Q320 LCD TV Picture problem
I was just starting up my Xbox and when the screen was loading up the picture went crazy. It turned a darker green like tint and about 3/4 to the right of the screen a bright 2 inch bar ran vertically through the screen. I immediately shut off the xbox and tried watchin jus normal tv. Its the same for every input. Like its burned into the screen. I have only had the tv for about 2 weeks and have not used it more than two hours. This SUCKS!!!!! Please help!!!
  • 3,130 Answers
Re: Hyundai Q320 LCD TV Picture problem
Sounds like you had a burnout in the TV set. if its onlt two weeks take it back where you bought it. They should exchange it or repair it for free. good Luck Ps please rate this thread.
Posted on Oct 19, 2006
0 characters
3 Points
What is wrong with my Sanyo TV?
T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Mar 03, 2016 | Sanyo Flat Panel Televisions
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from
Samsung LCD Loud Noise and Green Vertical lines at Start up ... > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
Toshiba sl738b
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
?Check the cables, connectors and connections.
Take it to a repair shop.
Apr 11, 2014 | Toshiba Flat Panel Televisions
I just turn my tv on and the screen was birght green then turn to a darker green i have sound but no picture this is on all channels i turn it off unpluged for awhile but still the same
I would check the t-con board. This is what transfers your picture to teh lcd screen.
You can get get parts for this tv at
Nov 16, 2011 | LG 42LG30 42 in. LCD HDTV
My LG HD tv screen suddenly went green. sound is
I disagree with info provided, if screen of your LG lcd tv becomes green that means inverter board is working and lcd tv does not have convergence ICs.
Please unplug tv from ac wall socket for minute to get it reset, replug back in and turn it On and check its picture.
If still showing green screen then change input source with remote, if tv shows same green screen on all inputs that means its either lcd panel problem or digital signal processor got bad loacted on main board. Local tv repairman is needed to confirm and fix it.
Jul 21, 2010 | LG 42LC2D 42 in. LCD HDTV
Flickering screen and lining-out on top inch at first
This sounds like tiling. are you using a cable box?
May 07, 2010 | Vizio GV42L 42 in. LCD Television
Dark shadow-like vertical streaks thru LCD screen (Sharp)
Hi, I have a Sony Grand Wega LCD Projection TV that has a blotted gray streak across the front of the screen. I only use a damp cloth to clean the window and that doesn't seem to help. It really shows up on light pictures and is unnoticed when the picture is a little darker. What can I do to fix this problem???
Aug 19, 2009 | Philips 32PF5531D 32 in. LCD Television
My Polaroid LCD tv picture is green!
if all r green meanns there is no use to watch the tv so for our support all should be in natural colours
Mar 14, 2009 | Polaroid FLM-2632 Television
Green Screen
my screen is green.  i can hear audio but no picture.
Jan 17, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Hyundai Q320 32 in. LCD Television Logo
326 people viewed this question
Top Hyundai Flat Panel Televisions Experts
Jay Seifried
Level 1 Expert
Are you a Hyundai Flat Panel Television Expert? Answer questions, earn points and help others
