Question about T-Mobile Wing™ Smartphone
T-Mobile wing wont answer calls.Everything someone calls it just keep ringing on and on until I completley cut the phone off.
  • 66 Answers
The phone need a new keypad assembly. www.fixphonenow.com can repair for $85.
Posted on Nov 16, 2008
How do i extend the rings before the answer machine cuts in on my BT6500
Set the answer delay
1. Select Menu, Answer Phone is displayed, press
Select.
2. Press (Calls) until Settings is displayed, press Select.
3.Press (Calls) to highlight either Ans. & record or
Answer only and press Select.
4. Answer delay is displayed, use < or > to display
the number of rings you want (0-9 rings or Time
saver) and select Save. Saved will be displayed.
Set the maximum message length
You can set the maximum length that an answer
machine message can be: 1 minute, 2 minutes or 3
minutes. The default setting is 3 minutes.
Select.
3. Press (Calls) to highlight Ans. & record and press
Select.
4. Press (Calls) to display Max. msg length and then
press < or > to select the length you want and
Billy from Hayward
It is in the owners handbook page 45 get it while the link last
http://www.shop.bt.com/content/uni2/documentation/8h3h/bt6500_user_guide.pdf
Jan 09, 2015 | Lands Phones
Phone wont vibrate
ok i dont know if this solves the problem for good, but i do know that it solves temperately. I went to phone settings and set the ring tone profile to vibrate. then i kept pressing the play button until the squeaking went away. It seems as though once the little moter in the phone goes at a constant speed it stops squeeking. the squeaking stops for a good while and is better than nothing. Someone tell me if this works for them. thanks ;]
Apr 17, 2009 | T-Mobile Wing™ Smartphone
T-mo wing won't allow me to answer incoming calls.
I had the same problem. Just make sure all your files are saved to your memory card and go to start, settings,system, then select clear storage. this will reset all settings to manufacturer default. It worked for me hopefully it works for you.
Jun 22, 2008 | T-Mobile Wing™ Smartphone
Answering machine wont pick up it just cuts off incoming call leaving line busy
just set the amount of rings higher on the back of the phone and make sure all you old messages are deleted and also make sure its not set to do not disturb
Mar 28, 2008 | Uniden Cordless Phone
Adjust ringer length Nokia 7250
Hi the only way you can make the phone ring longer is to goto settings scroll down to call select call then select call divert then select cancel all diverts after you have dont this then select divert if busy turn this on then divert if out of reach turn this on the select divert if not available now leave them like that then when your phone is switched on it wont goto answer unless your on phone to someone else or you hang up on someone.
With the settings like that it will goto answer phone if phone is off or if you have no signal or if you are on phone to someone else but now your phone will ring for aslong as someone rings you for.
Let me know if you need further assistance
Jan 15, 2008 | Nokia 7250i
T-Mobile wing problems
When I went to my local T-mobile dealer about the sudden absence of any sound from my Wing, he suggested I take the battery out, then put it back in. It worked.
Since then I have discovered that sometimes this fix works (why?) and sometimes it doesn't.
Not happy at all here, to have spent so much on the phone and then find out that when I answer a phone call, I've no idea whether I'm going to be able to hear anything or not, and I may or may not be able to "fix" it.
If anyone has more insight on this, I'd sure like to hear it.
Dec 20, 2007 | T-Mobile Wing™ Smartphone
My calls will get dead /cut off once in every 10 calls averagely N95
try to reset the phone,sometimes it works!
or use this reset code (*#7780#)
if it does'nt work try it manually go
to menu, settings etc..... :-)
or if still thesame
try this full reset code...
but backup everything first
specialy contacts....
code (*#7370#)
it will restore everything....
Nov 21, 2007 | Nokia N95 Cellular Phone
Nokia
that problam is uem dry soldaring jast soldaring uem
Feb 09, 2007 | Nokia 6230
T-Mobile Wing™ Smartphone Logo
47 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
