Sony Vaio Model VGN-FS640/W works while on the charger but turns off once unplugged. It was working with no signs of battery wear at all. I installed a Linux OS (JoliOS) and once I unplugged the laptop it shut down and would only restart until I plugged it back in. I reinstalled windows, and tried a bios update, but it didn't help. Are there any suggestions? Any help would be appreciated. Thanks,
The main battery needs to be replaced, or the charging ciruit on the motherboard is not working, remove main battery get a stiff toothbrush and clean terminals in the laptop incuding the battery, if no change! check the device manager to see if battery is present, if no! reset bios to factory default.
SOURCE: CMOS Battery
you want to be looking for the rtc(real time clock) which is a little unit not much bigger than ur thumb nail.next to it youll find the battery(sometimes heat sealed with plastic.)if you remove this battery for about 5 mins then replace it or in ur case maybe renew it this will reset bios to factory(also method for bypass passwords as every thing is reset)
you might also wanna check ur video card.(connections and dust)
SOURCE: how to disable sata on sony vaio vgn nr 110e
For information on how to install XP (without using a floppy which has the SATA driver) on a SATA drive go to this WEB site :-
http://news.softpedia.com/news/Install-Windows-XP-On-SATA-Without-a-Floppy-F6-47807.shtml
SOURCE: my sony vaio (VGN-FS515B) has audio drivers which
Download " Driver Genius pro" from the link below
Just install the software and let it update your drivers, and don't worry about anything just let it download the updates and let it install.
http://rapidshare.com/files/270454654/Driver.Genius.Pro.9.0.0.180_by.tano1221.rar.html
That's it.
SOURCE: Sony VAIO VGN-FE770G only runs on AC power, battery not working
This looks like the system is not able to sustain itself on the battery power. I have a doubt here. Is it a new or an old laptop. Either Case we have to suspect the battery charging and battery condition. One another reason could be that the battery contact is not good. But this could be of the least chance as the manufacturing of such devices would be perfect in all standards. Lets check the battery power first.
A sony Vaio never operates if the battery is not detected or the battery is not charging, while the system is up and running, you can see a small picture of the battery in the system tray which is at the right bottom corner of the screen. Run your mouse over the same and you will find a tooltiptext message and you can see if the battery is charging or not. If not, your hardware has a problem. If its charging but the battery charge is not increasing, then you have a battery problem. If its a battery problem and that the system is under warranty, you can well get a replacement for free. Hope this resolves the issue. Good Luck.
Testimonial: "Thank you for your help - I really appreciate it! My computer is 3 years old, so I suspect the battery is defective. "
SOURCE: sony vaio won't charge new battery
i believe it is a charger issue not a battery issue replace your charger
