Question about Sharp AM-900 All-In-One Laser Printer
Driver Problem I have been using this printer for a while, and the scanner just stopped appearing in scanner list. When i search for it in programs, it doesn't come up. I tried reinstalling the driver - didn't work. When i go to control panel, system, hardware, device manage... it says that the driver is corrupt. However I don't think that's the problem because a friend has had similar with other hardware and I'm thinking that all this is because the computer updated, but the driver hasn't. Can someone please tell me how to fix this or tell me where to find the driver. Thankyou in advance.
  • 417 Answers
You could try www.sharpe.com for the updated driver if not www.drivers.com but there will be a small charge on this site.
Thanks J
Posted on Feb 17, 2008
Cc4 205 00000012
Sir/Madam
To solve this issue, please install the latest scanner driver. If you use MFL-Pro Suite Software,
  1. Click Start => Control Panel => Programs => Programs and Features.
  2. Select Brother MFL-Pro Suite from the list, click Uninstall and follow the on screen instructions.
  3. Once the uninstallation is completed, disconnect the interface cable and restart the PC.
If you do not use MFL-Pro Suite Software,
Make a temporary folder on your HDD to save the downloaded self-extracting file, e.g. C:\bront
Please click here to download the uninstall tool to remove the drivers.
Once downloading is completed, double click the downloaded file to extract it.
"ZIP Self Decompression" appears. Click DECOMPRESS.
"The decompression process was successful." will appear. Click OK.
A folder will be created in the temporary folder created in Step 1.
Open the folder and double click DelInf32.exe. "Brother MFC Uninstaller" dialog box will appear.
Select your model and click OK.
"Complete" will appear. Click OK.
Click here to download the latest "WHQL certified Printer Driver and Scanner Driver", and install it following the Install Instructions.
Or
Still Having Problem Then Go To Brother Printer Official Website :
When trying to scan using the Brother ControlCenter3 on Wind Brother
Or
Stll Having Brother Printer Problem Then follow Us For On:
Brother Printer Support
Jan 20, 2014 | Brother Office Equipment & Supplies
I'm trying to install a c4380 wireless printer with windows 7 but it won't take, says it's not supported by software
  1. First find out if you are using 32 or 64 bit
  2. Click Start
Collapse this imageExpand this image vistastartbutton.jpg , type system in the Start Search box, and then click system in the Programs list.
  1. The operating system is displayed as follows:
    • For a 64-bit version operating system: 64-bit Operating System appears for the System type under System.
    • For a 32-bit version operating system: 32-bit Operating System appears for the System type under System.
Method 2: View System Information window loadTOCNode(4, 'moreinformation');
  1. Click Start Collapse this imageExpand this image vistastartbutton.jpg, type system in the Start Search box, and then click System Information in the Programs list.
  2. When System Summary is selected in the navigation pane, the operating system is displayed as follows:
    • For a 64-bit version operating system: x64-based PC appears for the System type under Item.
    • For a 32-bit version operating system: x86-based PC appears for the System type under Item.
  3. Then go to hp website and download driver for windows 7 for correct bit version.
  4. Unistall old driver install new.
Nov 28, 2009 | Xerox DocuColor 12 Printer
How can i turn on the print spooler on my dell 922?
Please follow this steps
1. Disconnect the USB cable from the computer.
2. You need to stop the printer spooler service as follows:
a. Click Start.
b. Type ‘cmd’ in the Start Search box. -Search results should appear-
d. Right‐click on ‘cmd’ in the search results, and then select Run as Administrator.-The command window will appear- (black window)
e. Type ‘net stop spooler’ into the command window and press <ENTER>.-The Print Spooler service should now be stopped-
Next, delete the printer drivers from the system as follows:
---Warning--- These steps will remove drivers for ALL printers installed on the system.
1) Click Start.
2) In the Start Search box, type ‘C:\Windows\System32\Spool\Drivers\w32x86’ and press <ENTER>.
3) Delete all the files and folders in this directory.
---NOTE--- There may be some files that will not delete because they are being used by Windows.
Click on the Ignore button to bypass deleting these files.
With the drivers uninstalled we now remove the Dell printer software.
1) Click Start.
2) Click Control Panel.
3) Click Programs.
4) Click Programs and Features.
5) Click the software related to the attached Dell printer to highlight it.
6) Click Uninstall/Change.
7) Follow through the prompts in order to remove the software.
You need to delete the Dell printer from the printers list.
1) Click Start
2) In the search bar type “Printers” and press <Enter>
3) Select any and all Dell printers and press <Delete>
Now delete any OLD drivers from the Server Properties Window.
1) Click Start
2) Type Printers into the search bar and press <Enter>
3) Press <ALT> to bring up the file menu.
4) Select Run As Administrator then Server Properties.
5) if the UAC window appears just click Continue.
6) Click on the Drivers tab.
7) Select any Dell printer drivers listed.
8) Click Remove, and then select Remove Driver and Driver Package.
9) Select Yes to confirm removal of the driver.
10) The system will now scan to see if it can remove the driver.
11) Once it has finished scanning click on Delete.
-Repeat the last 11 steps for each Dell printer driver that is installed.
At this point, you should be able to install the latest printer software for Vista from http://support.dell.com and be able to print successfully.
-NOTE- It’s been reported that some driver installations in Vista can take up to 10 minutes. Be patient and please wait for the driver to fully installed.
Hope this steps will resolve the problem
Sep 21, 2009 | Dell 922 All-In-One InkJet Printer
Lexmark x3350-4500 scanner doesn't work
Please follow the steps given below to update the scanner driver:
1. Right click on My Computer and select Properties.
2 Click the Hardware tab and select Device Manager
3. Right click on the scanner entry that is displaying a conflict.
4. Select Update Driver from the drop-down menu that appears. The Hardware Update Wizard appears.
5. Select Install from a list or specific location, then click Next.
6. Select the Don't search... option and then click Next.
7. Click Have Disk. The Install from Disk dialog appears.
8. Click Browse and select the Lexmark CD from the Look in drop-down list.
9. Double-click on Drivers.
10.Double-click click on Scan, select the lxbksxp file, and then click Open.
11.Click OK. The following screen appears:
12.Click Next to start the scanner installation.
13.When the installation is complete, click Finish to close the wizard.
Aug 23, 2009 | Lexmark X5470 All-In-One InkJet Printer
Cannot retrieve application list
Apr 28, 2009 | Office Equipment & Supplies
Help me pleaze
check if it connection issue
check all cables if it is connected directly
check device manager for imaging device see if there is a conflict update the driver
if same hotswap, then try another cable
if connection ok then same issue
trash and reinstall and reinstall the epson scan: follow this
Scanner Driver Removal
If you see a window that says User Account Control at any point, click Continue.
  1. Disconnect the USB cable from the printer and close any open windows.
  2. Click Start, then select Control Panel.
  3. In the window that opens, click Uninstall a Program under the Programs heading.
  4. Select Epson Scan, then click Uninstall/Change.
  5. Follow the on-screen instructions to complete the removal and restart your computer.
Once the removal is complete, please do the following:
Scanner Driver Download
  1. Go to www.epson.com select your contry
  2. Under All-In-Ones, select Flatbed, then select your model from the list.
  3. Click on Windows under Drivers & Downloads.
  4. Download the most current version of the Scanner Driver for your Windows operating system to your Desktop. Make a note of the file name in order to easily retrieve it.
Scanner Driver Install
  1. Double-click the downloaded file on your desktop.
  2. Click OK, Unzip, then OK again.
  3. Follow the on-screen instructions to complete the installation and license agreement. The installer will copy the files to the system.
  4. Click Finish when prompted.
  5. Turn your unit on and reconnect it to the computer after the installation is complete.
  6. Windows should detect new Hardware and complete the installation automatically.
  7. If a New Hardware Wizard appears, allow it to search automatically.
  8. If a message appears indicating The Scanner has not passed Windows Logo testing, click Continue Anyway. Then click Finish.
  9. Restart your computer before testing the scanner software.
Oct 09, 2008 | Epson Office Equipment & Supplies
How to scan from dell926 printer
Hi here is the user guide for your printer
Download it here
http://support.dell.com/support/edocs/systems/prn926/en/ug_en.zip
How to Scan
Scanning Single-page Documents or Photos
  1. Turn on your computer and printer, and make sure they are connected.
  2. Load your original document or photo.
  3. Click Start® Programs or All Programs® Dell Printers® Dell Photo AIO Printer 926.
  4. Select Dell All-In-One Center.
    The Dell All-In-One Center opens.
  5. From the Send scanned image to: drop-down menu, select the program you want to use.
    note-dell.gif NOTE: If the program you want to use is not listed, select Search for more... in the drop-down menu. On the next screen, click Add to locate and add the program to the list.
  6. Click See More Scan Settings to customize your scan.
  7. When you finish customizing your settings, click Scan Now.
Scanning Multiple Photos or Multiple-Page Documents note-dell.gif NOTE: Some programs do not support multiple-page scanning.
  2. Load your original document. For more information, see Loading Original Documents on the Scanner Glass.
    note-dell.gif NOTE: You can also open the Dell All-In-One Center from the operator panel on your printer. For more information, see Using the Dell All-In-One Center.
    note-dell.gif NOTE: If the program you want to use is not listed, select Search for more... in the drop-down menu. On the next screen, click Add to locate and add your program to the list.
  7. Click the Advanced button.
    The Advanced Scan Settings dialog box opens.
  8. On the Scan tab, select the Scan multiple items before output check box.
  9. Click OK.
  10. When you finish customizing your settings, click Scan Now.
    After you scan the first page, a prompt appears requesting the next page.
  11. Place the next sheet on the scanner glass, and click Yes. Repeat until you finish scanning all pages.
  12. Click No when asked for another page.
    The program opens with the multiple pages scanned.
Oct 06, 2008 | Dell Photo 964 All-In-One InkJet Printer
Scanner will not scan to certain programs
Try reinstallying the printer driver, but first remove the printer program.  Then, reinstall everything and try it again.  Unplug and plug the printer in.
Jan 28, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Sharp AM-900 All-In-One Laser Printer Logo
54 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
