Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA P56812BL big screen porblems
The red green and blue colors are really off and there is a bow in the top and bottom of the screen. is there anyway i can adjust this myself? thank you for your help
  • mike6002 Nov 07, 2008
    i have picture it just looks off, and the fuse is good. is there any way to adjust the lights on the board itself?
    Genius:
  • 1,030 Answers
This is a complete loss of convergence. FIrst question do you have the convegence option under setup in customer menu... if you dont then it might be the fl231 fuse problem common with these sets. if you do then try autoconvergence... if fails then you probally have a bad convergence power board. there are three diffrent boards that can affect convergence. convergence power, convergence amp, and small signal board..
Posted on Nov 07, 2008
TV has bow on top and bottom of screen and convergence is misaligned or off with red, blue and green, which should created the laying of R, B, and G to create B/W or Color...and of course, there is no...
Thats a very easy repair that has a repair kit available called the ITC222 and ITC222A convergence option missing repair kits. Its available with instructions from www.tvrepairworld.com its listed under the RCA repair kits.
Jul 14, 2011 | RCA HD52W59 HDTV Projection Television
Screen lookes like colores separating
Here's all I find regarding bad convergence from the techrepairCD:
RCA ~ITC222 D52W20~Convergence bad~~~ITC222~Replace leaky DL032 on
deflection board~~~~~~
RCA~D52W20Y ATC221~Convergence goes out/bowed after on for a few
minutes~~~ATC221~Problem may be on the deflection board. Was unable to
pinpoint where in this case.~~~~~~
RCA~D52W20BYX1 ITC222~Convergence way off after replacing small signal
board~EEPROMS were transferred over to new board~~~IK210 was
defective..transfer the new EEPROM back over.~Remember on these
sets*when replacing the SSB* if there is a small P on corner of
screen*hold volume on remote for 8 seconds after it reaches minimum.~~~~~
RCA~D52W20BYX1 ITC222~Can not align blue convergence* bottom really
bowed* possibly either color after replacing SSB.(Or no auto
convergence.~(Service menu: turn power off for 30 seconds* press vol dn
and ch dn* simultaneously for 8 seconds* set turns on with service menu
options)~~ITC222~In service menu* select convergence. If sensor
calibration was performed when convergence was too far off* it will not
alighn.~Get crosshatch with straight lines* perform sensor calibration*
then attempt convergence alignment again. Be sure to store settings*
then do sensor calibration again.~You must get a green flash of the
screen after sensor cal and a check in the box. RED flash indicated
convergence settings are too far off~~~~
RCA~D52W20BYX1 ITC222~no convergence correction~~~ITC222~LP650
(259271) DP670 (259246) & RP632 (259564) 4.7 3W on convergence power
supply board~~~~~~
Oct 28, 2008 | RCA R52WM24 52" HDTV Projection Television
My 52" RCA P52937SG screen bows on the top and on
What you are describing can be due to a number of different settings.
Focus on the red and green guns
Sharpness on the red and green guns
Horizontal position and size
Vertical position and size.
Please consult a professional for adjustment on these items as they are all near or connect to parts that have Hazardous Voltage.
Mar 22, 2011 | RCA P52937 52" Rear Projection Television
the part is called the convergence ic. replace those ics.
Mar 22, 2011 | RCA 32F531T 32" TV
Wont autofocus, bow in blue color at top, cant adjust blue convergence
hello it's the convergance chips my be the problem get a quote from an engineer its a big job 2 do yourself trust me i've repaired a few my self i hope you get it fixed good luck
shaun
May 21, 2009 | Samsung Televison & Video
Big screen tv
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jul 05, 2008 | RCA P52937 52" Rear Projection Television
Rca tv r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
rca t v r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
Apr 05, 2008 | RCA Televison & Video
Rca d52w2052 d523c10df itc222
The issue is the Deflection board. The Fl1231 is open. The Deflection board needs replaced
Nov 11, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Lost the picture
RESOLDER CIRCUIT BOARD LOOK FOR CRACK SOLDERING AT TRANSISTORS FOR CONVERGENCES
Oct 22, 2007 | RCA P56812BL 56" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
62 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
