Slow to take water
The machine is slow to take in both hot and cold water.
  • 5,911 Answers
Slow fill problems are usually attributed to a clogged inlet valve. If you live in an area that has hard water, or if you use well water, it is common for the inlet valve to become clogged with rust or sediment over a period time. Follow these steps:
- First, you need to make sure the fill hoses are not kinked. Many home owners push the washing machine too far against the wall in an attempt to save space and unknowingly kink the inlet hoses. Leave about a foot of space between the washer and the wall to prevent this.
- Next make sure you are getting the proper water pressure through the fill hoses by removing them from the back of the washer and placing them inside the wash tub. Turn on the water back on and see if water comes through the hoses unobstructed and forceful.
- If you have good water pressure, and the hoses are not kinked or clogged, check the inlet screens on the back of the washer (this is where the fill hoses connect). Clean them (if necessary) with cotton swabs to remove any debris. You can attempt to remove the valve and flush it with distilled vinegar too. Vinegar is often used to remove hard water deposits and can help in some situations.
- If all preliminary steps do not work, I would recommend replacing the inlet valve.
I hope you find this information helpful. If you require additional assistance, please post you make and model number along with any additional questions, so I may be able to assist you better.
Posted on Nov 08, 2008
My maytag washer model lat8006aae hot water flows in slow. I reversed water supply lines, no change, replaced water strainers and new water lines, still slow flow. supply lines, inlet water valve
It is possible the hot cold switch is flawed and stuck on mix of hot and cold I would have the inlet valve checked with a multi meter they can also check it for u at most appliance parts stores
Feb 07, 2015 | Maytag Washing Machines
Cold water filling is very slow despite good water pressure and taps fully turned on
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 03, 2011 | Hoover Washing Machines
COLD WATER RUNS VERY VERY SLOW
heatman101
Aug 09, 2011 | Kenmore Washing Machines
Water when filling has slowed down cold water is very slow hot is ok
heatman101
Jun 26, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Very slow filling of cold water. Hoover 5 Kg
heatman101
May 23, 2011 | Hoover Washing Machines
Hot water fill is very slow
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
heatman101
Feb 05, 2011 | Whirlpool Washing Machines
Cold water is slow when filling for rinse cycle
Turn off the cold water.
Remove the cold water hose from the machine.
Look inside the cold water inlet on the machine and clean the debris from the screen.
Problem solved.
Feb 22, 2009 | GE WJRR4170E Top Load Washer
Very slow cold water flow
soundslike either your cold water supply is not turned on all the way or the inlet valve is clogged w/debris. try removing cold water hose and checkin inside the valve, sometimed youll be able to remove sediment adn debris from valve from screen, if thats not the case youll need to replace the vavle itself
Apr 17, 2008 | Maytag MAV2755A Top Load Washer
Have model 88675 with slow hot water fill
I once had this problem. The solution was to remove the hot water hose connection to the washer and look at the filter/screen inserted into the end of the hose connection on the washer machine. This screen protects the washer components from foreign particles entering. You may find a badly-clogged screen, so clean it. I have seen a cold water screen clean, while the hot water screen was clogged...something to do with hot water and minerals or iron in water.
Jul 17, 2007 | Kenmore 88732 Top Load Stacked Washer /...
Washing Machines Logo
106 people viewed this question
Top Washing Machines Experts
