Question about Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony KV-32HS510, worked perfect, turned on the next day and all I got is flashing red light.
When I turn on my TV there is a click like it want to start, but the red light keeps flashing. It flashes six times, waits a second and then repeats six more flashes. It keeps going through this pattern and it will not let me re-set-it. Is there something I could purchase and replace to re-set my set? It is less than three years old, it is too young to die. Please advise. Thank you, Matt ☺
  • 5 more comments
  • squalodon Feb 06, 2008
    My Sony KV-32HS510 started doing the same thing last week, except sometimes the red light flashes 4, 6, or 7 times.  I am able to get it to turn on if I keep hitting the on button on the remote or TV over and over, but that seems to take longer each day.  I haven't turned it off for the last few days for fear of not getting it to come back on.
  • Anonymous May 16, 2008
    I'm having the same problem too. i had mine for at least 5 years. did my research and a lot of people are having this problem
  • Anonymous Jun 08, 2008
    red flashing light six or seven times
  • jsamp Aug 07, 2008
    Having the same problem. TV is 5 years old. Have extended warranty through Circuit City but have had no luck with their repairman. He is coming back to rediagnose the problem tomorrow (for the third time)! Can anyone let me know what to tell him?
  • karenedotson Jan 06, 2009
    I have the same problem and have tried to "reset" the thing with the remote and power button and it is not working. Has anyone found out what needs to be done to repair and what that cost might be. I do not live near a repair tech and would have to travel. I will do that if it is worth it b/c I don't want to purchase a new television when this one is only 5yrs old. I know one thing if I have to buy a new one it will not be a Sony. This is the second one that has broken on me way too early in its lifetime.
  •  Giusseppe G
    Giusseppe G Jan 15, 2009
    I also have this same problem. I got the tv from someone who said It still worked and got it since that person did not wanted the tv no more. yesterday it was working ok. And it does blinks 6 times.
  • crystal dash Dec 15, 2013
    me to what can i do to get the tv on
I think I have the solution for you. I have the same tv and it does the same thing when you turn on the power button on the remote when the tv turns on you hear a click then the red light flashes about 5 to 6 times then the tv comes on. on the remote there should be two buttons on top of the remote one says power and the other one says system hit the power button to turn on the tv when you hear the click and see the red light flashing then hit the system button which will turn off the tv then hit the power button again and it will turn the tv on without the red light flashing it should work
Posted on Jan 10, 2009
    Problem Solver:
  • 6 Answers
Just get out your original remote and hold the setup button on the remote while pushing the On/Off button on the TV. Worked right away for me!!!! Here's the link that I got the instructions from: http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=http--esupportsonycom-perl-tutorial-displaypltutid297templateid1regionid1KSMFlag7370&sliceId=&docTypeID=DT_TUTORIALS_1_1&dialogID=53101564&stateId=0%200%2053105132.
(I was about to send my Sony KV34HS510 (Trinitron 32") out for repair but there is a snowstorm right now. Would have cost me $100 just for diagnosis. I decided to go back on Sony website for solution. I clicked on a different string on their website than I had previously gone to (even though the problem was stated exactly the same but other solution just said to unplug it and wait - didn't work). My TV is back on and I'm so happy it's snowing right now!!!)
Posted on Dec 31, 2008
    what string website you went on
    President:
  • 3,130 Answers
Im sorry matt, its a solid state set and has no user replaceable parts inside the set unless your frained in solid state repair and printed circuit board repair. not as easy as to replace a module like the good old days. Its most likly in the sweep or the sweep power supply. it could also be a small of a problem like cold solder connections on the driver transformer, or the main high voltage transformer. Not a job for the untrained. Please be safe and call in a pro to assist you in this repair... Good Luck PS please rate this thread.
Posted on Oct 19, 2006
  • 73 Answers
Replace ic8001 and ic 8002 on main power board.Generic part# mcz3001d.
Posted on Jul 14, 2009
I have Sony Wega DRC KVHR 29M 91 about three years in use suddenly TV is on after few second red light is flashing about 10 times and put off the TV I disconnect the power cord and after one day I again start on TV was working properly and next day same problem repeatedly again I checked all connection are normal. Please help me what problem in the TV and its solutions.
Thanks & Regards
Khaleeq Ahmad
India
Posted on Nov 27, 2008
What would it cost to replace th b board or the m board?
Please reply to akchas1955@yahoo.com
Thanks, was just wondering if it is worth it to fix my kv-32hs510 or buy another TV
Chas
Posted on Jul 15, 2008
  • 97 Answers
The power supply is easily replaced. This model is the D4 chasis and ALL of the boards are swap out repairs. I have been a tech for 18 years with different companys. thsi model is proned to the b board and M board going bad.
Posted on Mar 28, 2007
What is the life span for the Sony Wega KV-32HS510?
10,000 continous woking hours is calculated to most of the CRT based TVs.
It is only calculation, but the life span might be much more that that. I've repaired a Sony TV recently, which was released by Sony Corporation Japan. The model is KV1820, an 18" Trinitron TV, still works perfectly. Just see, it is an '80 model one.
Jul 31, 2014 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Tv wont turn on and the light keeps flashing red
Your video path is defective,check IC301....hope this helps...
Mar 10, 2010 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Tv shuts itself off randomly
hi
you have defective power oscillation in power section
this needs to diagnose for a qualified technician
Thanks!
Feb 25, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Dec 12, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Kv-32hs510 6 blinks
This just happened to me. I was all set to send it out but there's a snowstorm right now. Thank goodness I checked another thread on Sony.com. Hold the setup button on the original remote while pushing the ON/OFF button on the TV at the same time. This worked for me. Here's the link I got this from: Good luck! http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=http--esupportsonycom-perl-tutorial-displaypltutid297templateid1regionid1KSMFlag7370&sliceId=&docTypeID=DT_TUTORIALS_1_1&dialogID=53101564&stateId=0%200%2053105132
Nov 04, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
Sony Trinitron blank tv/no picture
When I turn on the TV I hear the click sound and the TV powers up. Immediatly the red (standby) light begins to flash 6 times on and off. this happenes only in the morning, but after 5:00PM when youturn on the TV as if nothing is wrong.
what is the problem?
Feb 08, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Please Help
Is the red light flashing a code ? exaple 4 blinks pause 4 blinks ?
Apr 07, 2007 | Sony KV-27FV16 TV
Sony KV-32HS510, worked perfect, turned on the next day and all I gat is flashing red light.
Your tv does not need a reset,what happened something went bad inside the set and it needs to be replaced,if you are familiar with tv service you can start by checking the horizontal output transistor for a short,if he went bad it likely made the fuse or safety resistor open.If you are not too familiar with tv service be safe and call for assistance froma servicer.If you decide to go in looking for problems make sure the set is not plug in.Let Us know how it goes or if you need more information.
Oct 19, 2006 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony FD Trinitron WEGA KV-32HS510 32" TV Logo
1,237 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
