Question about Samsung TXK3276 TV
"Jumpiness" at the bottom of the picture
In the last few days, my Samsung TXK3276/TXL3276/TXK3676/TXK3676 (I am not sure which one it is but the visible diagonal is 36") has started to have a bit of "jumpiness" at the bottom of the picture. The area is about 3" high and extends across the picture tube, It appears that the scan lines increase in thickness and you can see the black between them more clearly. The phenomenon appears whether we are watching a cable program or a DVD. This makes me think it is a problem with the TV rather than any of the deviced connected in the system. Also, the problem will vary in intensity and sometimes even cease completely.
The owner's manual is, of course, silent on the issue.
Can anyone suggest a cause and solution? Thank you.
Rick
I contacted the dealer and found that the picture tube is failing. To have it fixed will cost almost as much as a new TV. We are pondering our alternatives.
Posted on Nov 08, 2008
Txl3276 does it have a memory battery to keep settings
Its main system memory IC is faulty. Replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
May 21, 2015 | Samsung TXL3276 32" TV
I have a Samsung TV Model TXL3276 it an older set built around 2000. and I have sound but no picture WHAT COULD BE WRONG? I FIRST NOTICED THE PICTURE GO OUT A FEW TIMES THEN RETURN ., BUT NOW ITS GOONE FOR...
This is CRT 32 inch tv and most probably horizontal/ vertical deflection section got problem that is why tv wont show picture.
Problem could be dry/ cold solder joints/ connections or vertical output chip failure, visual check by professional is required to get it repaired. It is not bulb problem in this tv because it wont has any bulb.
Let me know if you have additional question.
Thanks.
Jan 12, 2011 | Samsung TXJ2554 TV
I just purchased a Samsung UN46C6300 LED TV. The picture is cut off on top and bottom no matter which picture option is selected. Is there something I can do to fix this?
I had the same problem for a few days with my samsung tv which is the main reason why I am posting this solution though I am sure you, dvought, have found a solution by now. Hopefully. for all you other folks out there who have just made a desperate search on the internet like myself to solve this problem and have a cable box/satellite connect, please check your picture size settings for the cable box and change it from zoom back to normal. once i did this i was able to see all the writing and sports scores that were previously not showing before because they were cut off.
Dec 23, 2010 | Samsung UN46C6300 TV
I have a samsung model hlr4667wx/xaa picture freezes
analog board can cause that symptom especially if the pic is freezing .
Jun 26, 2010 | Televison & Video
I just hooked up my new Samsung 55" LED LCD TV it has 1920 X 1080 resolution and 240Hz speed. Initially the picture quality was fantastic, sharp clear great colors...almost jumped off the screen at you....
Try the Direct TV connected to the TV via component cables and see if the picture is clear and stable at the same time. If it is normal check the Samsung website for support on your model of TV to see if there are ANY known issues and or software updates. Please take a moment to rate my answer. Thanks..
Nov 26, 2009 | Televison & Video
Picture doesn't fit the screen
Try locating the aspect ratio adjustment on your cable box if you have one.
Mar 05, 2008 | Samsung TXL3276 32" TV
WHERE CAN I GET A SAMSUNG TXK3276 OWNERS MANUAL ON LINE?
most of the ones i found you have to pay for check these out.
https://www.ued.net/ued/addItems.do?itemCode=SSGOM-TXL3276
http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=OM-TXK3276&search%5Fmodel=TXK3276
http://www.tradebit.com/filesharing.php/1/22
Dec 05, 2007 | Samsung TXK3276 TV
Picture is to dark
On the CRT PCB, there is a ceramic capacitor attached to the screen voltage circuit. Disconnect it and the voltage may come up. If it does, replace it. check your 200 volt line and see where it is, also. If this doesn't help, let me know.
Jan 13, 2007 | Samsung TXK3276 TV
Samsung TXK3276 TV Logo
79 people viewed this question
Henry  Thomas
Henry Thomas
