Question about Kenmore 64254 / 64252 / 64259 Top Freezer Refrigerator
Door sags so it does not close without lifting. Can it be adjusted?
  • jassmine1998 May 11, 2010
    How would you know it is the right position if you are holding it open. Jassmine
  • 903 Answers
If you have access to the screws//bolts that are holding it in place, ask someone to hold it into the correct position (whilst open) and adjust it from there.
Posted on Nov 07, 2008
2003 Lincoln town car doors won't close properly
Are the door hinges sagging? open the door and lift up on the door is there a lot of up and down play?
Apr 05, 2018 | Lincoln Cars & Trucks
Frigidaire affinity door sag
Good Afternoon Mr. T,
I understand that you are having trouble with your Frigidaire Affinity dryer and the door sagging, making it difficult to close and latch the door. I suggest contacting your local authorized technician for assistance with this. They should be able to realign the door without any complications. Hope this is helpful.
-Best Regards-
WP
Mar 12, 2014 | Frigidaire Dryers
Prado 120 back door sagging
you can only do limited adjustments, First open the door and grab it by the back edge, see if it moves up and down, if it does the hinges are worn and need to be replaced. If no then open the front door and you will see the hinges of the back door, Loosen the bolts and have someone lift the back of the door slightly, Tighten then re-check. if needed keep trying until it sits right. You may also have to adjust the rear latch which is simply a matter of loosening the screws and adjusting as required.
Mar 11, 2012 | Toyota Land Cruiser Cars & Trucks
Driver side door sags.
If your door sags it means the bushings in the door hinge are worn out, but there is a way to adjust it without replacing the hinges if they aren't too bad. If you open your door there are bolts that attach the door hinges to the A-Pillar, most of the time they are accessable from the outside. First get a car jack and position it under middle edge of the open door, put a small piece of wood on the jacking point to protect the door. Loosen the bolts to the hinges and raise the jack so it raises the door up. tighten the bolts on the hinges back up and open and close the door to determine if the door was raised enough to eliminate the sagging.
Jan 25, 2011 | 2002 Pontiac Sunfire
Left side french door seem to have sagged,and now wants to bind when closing.how do you adjust it upward ??
ck the cam ( plastic ) it lifts the door and also causes it to close tight . they ware out and the sometimes just brake and fall out . .. part # 12395501 b -- this is a blk bushing . for your model .. mm
Sep 02, 2010 | Jenn-Air JFC2089H Bottom Freezer French...
97 dodge dakota driver door sag, repair.
Likely nothing to adjust.
With the door open, see if the door can be lifted up and down while looking at the hinges. If there is play, the door hinge pins/bushings are worn out, and on some vehicles, the hinges are not serviceable, and replacement will be needed. G/L
Oct 02, 2009 | 1997 Dodge Dakota
Garage door chain is sagging
If the chain is adjusted properly the chain will sag slightly on one side when the door is closed and on the other side when it is open. It should not sag enough that it is dragging on the T-rail. You can adjust it at the trolley. If you over tighten it you will hear a clicking sound when the opener opens or closes.
Jul 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door sagging
put a hammer in between bottom hinge and close door slightly this will lift the door
Dec 05, 2008 | 2001 Oldsmobile Bravada
Kenmore 64254 / 64252 / 64259 Top Freezer Refrigerator Logo
165 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
