Question about Microwave Ovens
GE Microwave/Convection Oven Model JE1390WV - 001
The magnetron no longer powers up. When we input any request for timed cooking, (whether microwave or convection) there is a quiet click, the interior light goes on, the LCD behaves normally (counting down and sounding off at the end of the selected time period), however no power to the magnetron, nor fan, nor turntable. Only the interior light and the silently counting LCD are getting power.
Immediately prior to this happening, the door abruptly became difficult to open and once it did open, wefound the upper hook had a range of independent movement that it didnot have previously.
The upper door hook (on the door) can now be pivoted up (by hand) about 30 degrees from its previously horizontal position. It now moves independently from the lower hook on the door. If you push up on the lower hook, this motion will still move the upper hook. The upper hook is still anchored on its pivot pin.
We are imagining there is safety lockout that is no longer being satisfied due to the new range of motion in the upper door hook. ie, it is no longer rigidly held in place and could not bear down on a contact to close it??
GE parts folks say there is no replacement door hook set, they say the entire dooris a replacement assembly ... door part number from GE is WB55X970... and they have discontinued it.
Is this why the magnetron is no longer powering up? The lack of asafety lockout being satisfied? If so, is it possible to 'break into'the microwave and glue, screw or hotwire the safely lockout into place? There are no children in this house nor are there ever any peopleunder 25 years of age ... so I would be comfortable bypassing thesafety lock out.
Many thanks for considering this!
Gay Wyn Quance
gwquance@gmail.com
801 319 2800
So ... is it possible to jury rig a fix here?
many thanks!
  • 5 more comments
  • gaywyn Nov 07, 2008
    Thanks for the quick response Scott. However, let me ask again: is the 'broken' upper hinge the cause of the problem, and if so, is there a jury rig solution possible. I am looking for a solution I can implement in my own kitchen with glue/wire or a screw, since (if the broken hook is the cause of the problem ) there are NO Parts available to repair anyway.
    So, please reconsider and give me your perspective on whether this broken hook could be causing the described symptoms and second, whether there is a jury rig possible.
  • gaywyn Nov 08, 2008
    ok, good observations ... however, I am still asking for help designing a jury rig that I can do myself. I have a complete workshop. What I do not have is the schematics or mechanical drawings that show how the safety lockout works and then what I would do to design/implement a jury rig around it. So, please provide technical support and instructions specific to what jury rigging would need to be done to either 1. take apart the door and refit new fabricated hook mechanism, or 2. enter the area where the upper hook enters the body of the microwave and do a jury rig to hotwire/screw/glue the safety feature that is not being secured by the broken plastic hook.
    I am looking for the technical support and instructions that your website said was available. I know a new microwave would be very affordable. However, I have a strong repair/reuse ethic and am not inclined to toss and replace. I have 10$ invested with you and would dearly love the technical specific advice that was advertised ... mechanical and schematic (wiring) drawings and advice on disassembly of the door (to repair the upper hook), and or advice on entering the body where the upper hook enters, in order to bypass the safety mechanism, or ... if the wiring diagram shows what relay gets sealed in by the safety lockout, I would love to know that as well, so I can deal with the relay directly. Again, thank you and I look forward to technical specifics.
    ok folks ... enough.
    I am asking for technical specifics and am getting well-intended grandmother advice.
    Please refund my money.
    MNTech, I acknowledge and appreciate your comments. Until I see a schematic/wiring diagram, I cannot tell if the safety lockout is a 2 out of 2 arrangements, ie, both hooks have to lodge correctly in the body of the microwave for the safety lockout to be satisfied, or if it is a single safety criteria, met by having only the upper hook correctly seating in the body of the microwave.
    If it is the former, then there is still a sufficient safety layer in place. If it is the latter, then I need to make a 'smart adult' decision on how to proceed.
    The bottom line is that I am trying to gather these facts from your company (for the 10$ fee paid) and I am not being provided with the specifics I am asking for from you.
    Hence, while I appreciate all of your efforts to provide me with apple pie advice, I am asking for technical detail. So, again, I am formally requesting a refund of my money, since the service (while prompt and well intended) has in no way met either your advertised deliverable, nor my expectations.
    I have already contacted this organization and they do not have the part, because GE has discontinued this part (door assembly). I have contacted 4 additional parts consolidators from all over the US and received the same 'not available' from each of them.
    I had paid $$ to get technical specifics from your company, again, the wiring diagrams, mechanical drawings, schematics. Since I cannot get the parts, I need to jury rig.
    Your company cannot seem to provide this level of technical detail.
    Please confirm whether or not you have access to these technical details and are able to provide them.
    I am starting to believe there has been deliberate misrepresentation of your capabilities. Please either provide the information requested in my earlier thread, or refund my money.
    Please Respond to the specific request.
    Please forward this to your Legal Department
    After multiple attempts to even get confirmation that your organization can supply technical specifics, I have been forced by the conduct of your staff to conclude that you have misrepresented the capabilities of your organization and are unable to deliver on your advertised capabilities. Please refund my money immediately.
    President:
  • 2,712 Answers
Try this number: 1-877-477-7278 they may have the door replacement assembly part number WB55X970 or can get it for you.
Posted on Nov 08, 2008
  • Swilin Sampson
    Swilin Sampson Nov 08, 2008
    To replace the outer door frame, you would need to use putty knife (the
    one you use for dry walling) to remove the inside door frame by prying
    against the inside metal frame. Once you remove the inside door frame,
    you will see two screws that secure the door handle. Unscrew them to
    remove the door handle. Once the handle is out of the way, you will see
    (from outside) there are 2 more screws that secure the outer door frame
    to the door assembly. Unscrew them (be careful not to let the outer
    door frame drop because there is the glass attached to it) and use the
    putty knife to remove the outer door frame. From this point on, the
    removal and installation should be straightforward.
    Once again, as is our duty and responsibility towards our customers, I have to warn you to take care when repairing microwaves. Improperly fitted parts can and will cause serious damage to health, if not death.
    Be careful.
    Genius:
  • 2,035 Answers
Please click here and check if they have the parts you require.....
Good luck...
  • 1,543 Answers
Hate to post an answer to this because it's not what you want to hear. In this case, Scott is 100 % correct. Don't try to bypass safety items with microwave ovens, or most other products. Life is too short. You can replace a microwave, it's a lot harder to replace a person. Junk the micro. No service tech worth asking is ever going to advise you to bypass the safety devises !
Posted on Nov 07, 2008
  • Carl Schulzetenberg
    Carl Schulzetenberg Nov 08, 2008
    Of course we could tell you how to bypass a safety devise, but that would make us liable in court. We cannot be a party to safety hazards.
    Sergeant:
    Novelist:
  • 196 Answers
Going for the new oven is much advisable.as the part not available with the company is very much hard to get.still you can call a local technician at your place and with the help of him.try to expriment with that old broken part.and may be with his advise it could be proper and you can use it further.but using the oven in such condition is very much risky.so care should be taken about that.
hope this helps you...........
thanks.
    Scholar:
  • 155 Answers
Yes it is due to the broken door assembly.as the part is not available with the company.but it can be easily get repaired at a local repair center.because they have scrap  of all types of models.and they can exchange your broken assembly with that old scrap machine good assembly.and it can be made proper to use it again. it will charge u heavy as per the service center rules. thanks.
    Guru:
  • 558 Answers
Its repair will cost you more than a New one, so better to purchase a new.
You can make a new choice just looking at this site:
http://www.naaptol.com/buy-online/WO-shopping-best-deals-W115O/kitchen_appliances/cooking/microwave_oven.html
Make the old one ur locker for keeping Jewels.
  • Puneet Jain
    Puneet Jain Nov 07, 2008
    Surf this site:
    Naaptol.COM
    Thanks for using FixYa.
    Scott
  • Puneet Jain
    Yes, offcourse the broken hinge which can not be repaired almost make it useless. And it can not be repaired and used anymore.
Sharp convection microwave oven model R1875F. It's cooking on the left side faster then the rest of the oven. It seems to burn on the left side and not cook in the middle.
see the next causes. God bless you
Diode The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven.
Door Switch If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food.
Thermal Fuse If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Oct 03, 2012 | Sharp R-1870 Convection/Microwave Oven
Problem with the GE Advantium (model sca1001fss01) Convection / Microwave Oven Everything works except the microwave. It makes a sound like its working, table turns, but does not heat or cook.
sounds like the magnetron. Youll have to have a technician replace it. if you have a warranty just call the company and they should take care of you.
Jan 29, 2011 | GE Advantium 120 Convection/Microwave Oven
Oven is not heating or cooking in microwave setting, but does heat in convection setting. Manual does not give enough input for troubleshooting. Is it time to call a repair person, or is this fixable on my...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 21, 2011 | GE Advantium 120 Convection/Microwave Oven
When I type in the time to cook food, the microwave will run for about 2 seconds and then turn off and beeb 3 times. what causes that?
Boy, this sure sounds like a GE with a failing leaky magnetron, but that's not possible since you posted this under Whirlpool MH1160XS.
But it may still be a bad magnetron...
Aug 19, 2010 | Whirlpool MH1160XS Convection/Microwave...
Not heating up anything
Tat would be a magnetron problem. The magnetron is what provides the heat
Apr 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave won't heat
you will need the magnetron replaced $150-$180 price range part and labor
Feb 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My sca2000bbb the convection works fine and the microwave does everything but heat up the food thanks for any help
If the microwave side is not cooking, it may be the magnetron has died, if so, it may be expensive to repair and you may have to consider another purchase.
Oct 05, 2009 | GE Advantium 120 Convection/Microwave Oven
Convection Oven has stopped working
magnetron may be defective . replace d magnetron
May 29, 2009 | GE JVM1790 1000 Watts Convection /...
Microwave ovens
The Magnetron has failed, causing the waveguide to become damaged. If the waveguide is damaged/burned the microwave can not be repaired and should be replaced.
Dec 25, 2008 | GE Advantium 120 Convection/Microwave Oven
Microwave Ovens Logo
166 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
