Question about HP Office Equipment & Supplies
When the printer is plugged into a/c and the start button is depressed the unit runs through a few cycles and then turns off.
  • Love 13 Nov 07, 2008
    What can be done to insure the printer staying on?
    Sergeant:
  • 306 Answers
U stil dint mention the model of ur printer..
Posted on Dec 08, 2008
  • AbdulRahiman S Dec 08, 2008
    unplugging the printer and then plugging it after sometime may solve any prob initially.. else may be some internal prob in t printer or in the power board!!
  • HP Master
  • 6,487 Answers
Can you please provide us the model of this printer so we cna help you better..
Posted on Nov 07, 2008
  • HP Master
  • 13,433 Answers
Can you please post the model of your printer?
  • Ekse Nov 07, 2008
    Unplug it for 5 minutes and try again, you possibly have a hardware problem, so whats the model of the printer?
I have a LG Tromm it starts running in wash mode then a few mins. into cycle it shuts off no codes there is nothing on display
Here's a reset that could work:
To fix this:
  1. Press POWER, and turn the machine OFF.
  2. Unplug the machine.
  3. With the power being disabled, press and hold the START/PAUSE button for 5 seconds.
  4. Plug the washer back in.
  5. Power the unit back ON.
  6. Press-in on the door firmly.
  7. Select any cycle, and press START/PAUSE. Good luck
Mar 07, 2018 | LG Washing Machines
E3 error on LIfesmart heater
Even after replacing thermostat and motherboard offered from company, my heater would trigger e3 error code and shut off. After several (maybe 100!) different attempts to plug in and operate, here is what worked for me!
Depress the power button on the heater while plugging in to wall circuit. Continuously depress power button. It will run through a test cycle and attempt to start. Keep depressing the power button as the heater tries to start, then shuts down with e3 error. While the power button is still depressed, unplug the unit from the wall. When I plug back in the wall the E3 error is gone. Good luck
Nov 03, 2012 | Lifesmart DYNAMIC 1000 to 1100 Square Foot...
Dish washer does not turn on CL light stays on when reset count down 6 appears then goes to CL
Hello and welcome to Fixya,
I have a ton of service info on Bosch so it`s best I post you an exert from the service pdf`s I have on my PC which will explain the meaning of "CL" and then go from there. This is not a common indication of a control problem, but it could be a problem with the plastic casing which houses the control, we`ll deal with that later.
I`ve underlined the section pertaining to the "CL", this is for the SHU68** dishwashers only.
TO OPERATE:
First depress the On/Off Button until it locks in place.
Once the On/Off Button is depressed the LED above the previously used cycle will illuminate.
To change the cycle, simply press the desired Cycle Button twice. The LED above that cycle will then illuminate.
The Cycle Countdown will display an approximate run time for the cycle chosen.
This run time will depend on incoming water temperature and the turbidity of the pre-wash water.
Note: It is normal for the Countdown Display to remain at a time increment for more than one minute, or skip a time increment depending on the calculations of the Control Unit. Also, with continued use the Control Unit will learn the wash and temperature patterns for the most commonly used programs and will then reduce the overall start and running times.
At the end of the cycle the display will show a CL, indicating that the cycle is complete.
**TO CANCEL A CYCLE:
Press the Scrub Wash and Delicate / Econo Buttons both in at the same time. The unit will then drain and the figure CL will appear in the display.**
DELAY START:
The Delay Start feature allows the unit to be delayed for up to nine hours. To program, start the unit as described above, but after selecting a cycle push the Delay Start button. The display will show a 1h, or one-hour delay. Continue to depress the Delay Start Button until the desired delay time is reached (up to nine hours, 9h).
The unit will begin automatically once the delay time has elapsed. To reset the delay, press the Delay Start Button until it reaches 0h.
TOP RACK ONLY:
The Top Rack Only feature can be used in conjunction with any cycle. To active, press the Top Rack Only Button after selecting a
cycle, the Top Rack Only LED will illuminate and all water will be diverted to the upper wash arm for the complete cycle.
REFILL RINSE AGENT LED:
The Refill Rinse Agent LED is activated via a Reed Switch on the Detergent Dispenser, Section 4, Fig. 8-3. The LED will
illuminate when the Rinse Agent Dispenser is empty.
Service note: The Refill Rinse Agent LED will also illuminate when the dishwasher door is opened and then
closed even if the Dispenser is full, but will only remain lit for a few seconds.
“F” CODE:
An “F” in the display window indicates a filling fault.
Please note: If the door is opened during the cycle, the On/Off Button will be reset to off and must be depressed again to re-active the cycle. The cycle will resume from where it left off.
Now that you are equipped with this info, what I`d suggest is trying the **cancel option. ( ** see above )
Once you`ve tried the cancel option, select a Regular Wash and post back what happens and I`ll try to assist you from there.
Good luck.
macmarkus :)
May 14, 2010 | Bosch 24 in. SHU6802UC / SHU6806UC...
Zebra LP 2844 Prints 30 pages of junk instead of a Dazzle mailing
Turn off the printer and place your finger on the green feed button. With the button depressed, turn the printer back on. Let the light flash2.gif (ONLY!) four times and release the button. Printer will cycle through 2-3 labels. Press the feed button one more time.
You've just set the printer back to factory default.
Jul 23, 2009 | Zebra LP 2844 Thermal Printer
My compressor will not start.
There are a few more things to try, in the control unit of the AC there is Cold Control/Freeze Switch. Take down the control unit (inside unit, remove inner shroud) and remove the cover, The freeze control is plugged into the blue plug on the board. Remove the plug and install a jumper wire in its place. Does the compressor come on? If so, you have a bad freeze control. If not, then we need to check and see if your AC power module is sending power to the Compressor. Check power across the relay in the control unit, Black to Blue. If the blue wire is hot, then you need to go upstairs to the top of the compressor and check the thermal overload. If the blue wire is not hot, the comfort control center may not be sending a signal to turn the compressor on. If it is not, do a reset of the CCC. For a five button system, turn the tstat off and hold down the Mode and Zone buttons simultaneously. While holding them down, turn the CCC on and hold the buttons until FF appears on the screen. Release the buttons and try the AC.
Four button reset -
Depress MODE switch to activate annunciator light.
Simultaneously depress the bottom two buttons
(temperature UP and DOWN) and hold.
While holding these buttons down, depress the
MODE button once and release.
Release the two buttons previously held down.
Depress the MODE button once again.
At this time the light should extinguish, and the mode
should register “OFF”. If not, repeat Steps 2 through
6.
Retest system ensuring that all functions are present
and operational.
Hope this helps,
Jeff
Rate me please!!
Jun 28, 2009 | Dometic 57915531 Air Conditioner
Cannot engage RESET Button on plug to power the 220v AC unit
The reset button is a voltage leak detector it is possible the unit has a short in it or the cord has a short
Apr 28, 2009 | Heating & Cooling
Noise
The top of the unit that covers the coffee beans has a plastic point that must depress a button on the main body of the unit when it closes to show the unit that the lid is closed properly. If this is broken (as was mine) I inserted the end of a piece of tooth pick replacing the plastic point in the lid and this now depresses the recessed button on the main unit. The beeper goes off and the on light comes on.
Jun 19, 2008 | Cuisinart Thermal DGB-600 Grinder
14 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
