Question about Honeywell Heating & Cooling
How do I unlock my honeywell Pro 7000 commercial thermostat
4 Suggested Answers
  • 4 Answers
SOURCE: Honeywell Commercial PRO TB7220U Touchscreen
That one is fun. Touch the system cycle button. then touch the two spaces on both sides of the center button at the bottom hold them down at the same time. After 5-10 seconds the screen should flash and show numbers int the center of the screen touch the screen til the numbers 670 appear. then change the numbers beside it to 0. then click done. now you should be able to adjust temperature as needed
Posted on Apr 15, 2008
SOURCE: unlock Honeywell TB7220U1004 Ultrastat Commercial
Press the system button once and when you see the system and done displayed over the right and left buttons hold them both down for five seconds and that will take you to the setup menu, dont change anything in here just keep hitting the next button till you see the number 670 on the display, once you get to 670 just hit the up or down arrow until the number 0 is displayed next to the 670 your options are 0,1,2,3. after changing it to zero just hit done, you are now unlocked!
Posted on Oct 12, 2008
  • 252 Answers
SOURCE: need wiring for honeywell pro 3000 in trane xe1200
the pro 300 is a single stage thermostat and can not be wired to control 2 heat stages seperately
Posted on May 16, 2009
Visionpro problems
Remove the batteries and remove the R or RED wire from the thermostat's sub base R/ RED terminal for 1 hour, if this does not work, replace it.
1-800-honeywell
www.honeywell.com
Dec 14, 2013 | Honeywell Programmable Thermostat Heater
ST 7000 honeywell programmer
Recommend the Honeywell RTH6580WF WiFi thermostat. You can buy this @ RadioShack for $100
Nov 20, 2013 | Heating & Cooling
How to unlock screen
Change battery located on back of thermostat??
Go to google
Search for your model number 1234XX .pdf
Add .pdf in search parameter.
Honeywell posts most their thermostat manuals.
Open pdf file, and then Use Ctrl+F for search feature
Word-Search manual
To find model number on thermostat, remove from wall.
Model number appears on back.
Don't forget to replace battery while you have back exposed.
Dead battery can also cause lockout and malfunction
Apr 18, 2013 | Honeywell TB8220U1003 Commercial Vision...
How to lock a Honeywell TB7220U Thermostat
With directions go to system. Then hold down 2 blanks on either side of middle for 30seconds this shows you Advanced settings . Read through and find the proper settings
Jul 02, 2009 | Honeywell Electronic Programmable...
Thermostat is in the locking position, need to unlock
The Thermostat Wizard is an interactive tool that will guide you through wiring and troubleshooting your thermostat, as well as programming it to the most comfortable settings for you and your family. Simply answer the questions from the Thermostat Wizard to correctly connect, troubleshoot and/or program your Honeywell Thermostat. You can even print the instructions and bring them right to the thermostat to help make things easier.
Go to: http://yourhome.honeywell.com/Consumer/Cultures/en-US/Support/Thermostat+Wizard/
Please rate my answer!
Mar 04, 2009 | Honeywell Electronic Programmable...
Y1 W1 Wire from older Honeywell to new RTH honeywell
Y1 means for cool and W1 means for heat. Connect accordingly.
Aug 11, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
130 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
