Question about Canon BJC 2100 InkJet Printer
Error Message - Used Ink tank full
I was given this printer with no manual....where do I find the used ink tank and how do I empty it...will not print. Help! Thanks all!
  • bethshan Apr 29, 2009
    notified about ink tank full. where is the used ink tank, and how do I empty it.
    Novelist:
  • 114 Answers
User manuals and trouble-shooting guides for this model can be found here: http://www.usa.canon.com/consumer/controller?act=SupportDetailAct&fcategoryid=230&modelid=7960
Posted on Oct 19, 2006
4 Suggested Answers
SOURCE:
SOURCE: "used ink tank is full"???
http://startcopy.ru/codes/canon_ip.htm
Posted on Dec 13, 2007
  • 359 Answers
SOURCE: ink cartidge problem
This proposed "beginning" solution assumes that you have already done one important thing. The printer will dislay the exact characteristics you have described if the ink tanks are not placed properly or are not in the correct order. I recognize this is a very elemental step, and no offense is intended, it is just that these basics should all be verified as it is easy for us to overlook the obvious!
Now, in accordance with your manual, a quickly repeating circular light (1-second intervals) is the indicator of the tank being either in the wrong position, or it being empty. The state of the ink lamp being off entirely - which is what you have stated - is intended to indicate that the tank is not set properly. Press the PUSH "icon" on the tank until you hear it click into place. I would suggest that if it does not click on the first or second try, you remove the tank and entirely reseat the tank, verifying again that all packing materials have been removed. (Always be careful not to touch any of the electrical contacts, as this may render the tank unusable.)
Perform print head cleaning. This is a three-step progressive process - in other words, if step one works, you can stop there. If your manual does not provide adequate instruction on this approach, go to http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=15596#SupportDetailAct, which is the Canon USA site. Canon typically does not allow going straight to the page at hand, so you will likely have to type in what you are looking for under the "Support & Service" tab. The name of the particular article focused on this process is "Performing Nozzle Test and Head Cleanings - Windows".
Canon further indicates that the print head may need to be replaced, or that the system may need to be repaired (by an authorized tech, of course...). If this is the case, given the length of ownership and extent of usage, you should be able to get service under warranty. One final question, in case we have not yet found resolution for you. When there is an issue with a printer component, e.g., an ink tank, the alarm lamp, which is directly below the power button on the right front corner of the unit, should be flashing orange. The number of these repeated flashes (for instance, three consistent flashes, pause, three more, pause, etc., all the way up to 16..) gives us guidance as to the actual problem. Additionally, do you use the printer status monitor, which gives you details regarding the printer's status and information regarding other items? If so, would you relay what is shown in the monitor, in addition to what is occurring with the Alarm Light.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Posted on Sep 15, 2008
komguy
  • 2306 Answers
SOURCE: how do I empty the use ink tank?
You can still order the ink absorbers for this model, but only a shop can access the diagnostic mode to reset the counters and clear the error code.
Posted on Jun 26, 2009
I keep getting this error message come up, 'The waste ink absorber is almost full - see manual'.what do I need to do as the manual doesnt give details.
According to the user's manual, "Ink used to clean the print head is absorbed by the waste ink tank. When this message is displayed, the waste ink tank needs to be replaced, or the machine requires maintenance". There is no information about how to replace or empty the waste ink tank.
In any case, you can try the following to clear upo the error, but eventually you'll need the waste tank to be emptied or replaced.
Turn on your MP130.
1) After that press: Menu - Scan - Copy - Scan or Menu-Copy-Scan-Copy-Copy in some models, it depends on the date it was produced)
2) Select TEST MODE.
3) Enter NVRAM ACCESS
4) Select SET ABS-M LEVEL TO 0
5) Select OK
6) Keep selecting OK untill you leave the TEST MODE
Then turn it OFF and again ON. Check if the error message is still there
The following is taken from the Canon website, regarding this specific error:
"Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
As I mentioned before, I have not found any way or procedure to replace the waste ink absorber nor the necesary replacement part
Mar 22, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Sep 14, 2009 | Canon i350 InkJet Printer
My error message says the used ink tank is full. How do I empty it?
You can't empty it, it's a set of pads covering the whole bottom of your printer. They only cost around $10.00 but you need a shop to replace and reset the waste ink counter.
Sep 02, 2009 | Canon BubbleJet i560 InkJet Printer
How do I empty the use ink tank?
Jun 21, 2009 | Canon BubbleJet i560 InkJet Printer
My Canon I550 quit printing.
An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action.
bullet.gif Two flashes: Out of paper or paper feed error
Replace the paper correctly and press the RESUME/CANCEL button.
bullet.gif Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, replace the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
bullet.gif Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. However, when printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it will be a cause of trouble.
See Replacing an Ink Tank
bullet.gif Six flashes: No print head installed
Install a print head.
bullet.gif Seven flashes: Defective print head
Contact a Canon service representative.
bullet.gif Eight flashes: Waste ink tank almost full
i_note_us.gif Note
Canon recommends to call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
bullet.gif POWER lamp flashes alternate green and orange:
An error that requires contacting a Canon service representative may have occurred.
Turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on.
If the problem remains, contact a Canon service representative.
Apr 14, 2009 | Canon BubbleJet i550 InkJet Printer
Used ink tank full
I have a error message on my Canon Multipass 390, used ink tank full.
Where the heck is the used ink tank?
Jul 13, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
I am not able to print and it shows this message. Can you be able to help me resolve this problem? The used ink tank is full. Cancel printing and turn the printer off and then back on. If this doesn't...
It seem that the error message is caused by non-user replaceable parts which refer to ink pads. This ink pads is a porous material that used as ink tanks for waste ink when printer is turning on and head cleaning. The best solution that we can advice is to send the printer to nearest service center in your area, probably authorized by your printer manufacturer, and if your printer manufacturer has ink pad reset utility tool you can run it to reset the ink pad counter to zero.
Jun 10, 2008 | Office Equipment & Supplies
I get an error message on Canon i960 printer that tells me the waste ink tank full. How can I empty this myself?
Read it all here.
Scroll about half the page, to:
WASTE TANK ALMOST FULL or FULL ERROR MESSAGE PROBLEMThere is explained how to get rid of the error message very easy, and how to clean the waste ink pad manually. The latter seems not to be necessary, though.
Mar 27, 2008 | Computers & Internet
Canon BJC 2100 InkJet Printer Logo
275 people viewed this question
Clive
Clive
old marine
old marine
