Question about IO Magic Corporation GigaBank (I250HD35) 250 GB USB 2.0 Hard Drive
Doesnt work.. blinking but system doesnt see it.
Hello
Our hard drive has died. It is lit and blinking but and making a noise but the system isnt seeing it? any advice you can provide would be greatly appreciated. Thank you
  • 2 more comments
  • bruvolo22 Jan 02, 2009
    I have the IO Magic 250 GB USB 2.0 Hard Drive as well, and whenever i power it on, it makes a sound and then starts blinking, but my computer will not recognize it as well. Is there a solution to this problem? Thank you!
  • Anonymous Jan 06, 2009
    Mine does exactly the same thing! :( I have seen another thread on this same topic and one thing several people seemed to have in common is that they all turned it off for an extended period of time. I turned mine off, too. Did the two users who posted above also turn theirs off for an extended period of time? One post suggested it needs to "warm up" for something like 30 min. to overnight and another said it was the power cord. Any luck with these solutions, anyone?
  • Anonymous Jan 07, 2009
    My dirve blinks as well and I/O Magic had no response to my problem. They said to replace it. Easy for them to say but what happens to all my data. I will leave mine plugged in and maybe it will come back to life.
    I have the same problem with IO Magic 250 GB USB 2.0 Hard Drive, one year old. Too bad, I have lots of data in it. Any help ?
  • 3 Answers
I had the same thing occur to my I/O Magic 250 GB USB drive a couple of days ago. I did an online chat with I/O Magic tech support and the guy said you can RMA (return) it if it's in warrantee, but otherwise too bad. Mine is out of warrantee. Since the enclosure contains an ordinary hard drive inside, just carefully peel off the little metal plate at the back of the unit, undo the two screws and slide out the drive. The are two plugs and four screws to free the drive. To get your data back once you've got the drive out, you've got three choices: buy a new enclosure ($20+), buy a toaster ($50) (it's like an enclusre, but you just pop a drive into the top, like bread into a toaster), or open up your computer and connect the drive directly as any other. Oh and don't buy another I/O Magic product again.
Posted on Jan 09, 2009
Verbatim 62873
The first thing I would do is find another PC that has enough space to copy all those picture from your external drive. If you plug the drive in to that PC and it recognises it then immediately copy the files over to that PC so you have a backup in case the drive is dying. If that does not work try another cable to the drive. If the cable does not work then the drive might have some stiction problems causing the platter inside to become stuck. sometimes you can break those free by laying the drive on a flat surface and rotating it as quickly as you can. if this is the problem and it does start to work again, make sure you have enough space to immediately copy those files off of the drive on to a known good drive. Do not bang the drive on the surface. typically that will just cause more problems.
if you do get the drive to work then make sure you copy the files immediately and I would purchase a cloud based backup plan and start to back all those files up on the cloud. I use iDrive but there are many other options out there.
Mar 21, 2017 | Computers & Internet
Hi Guys, you must be getting this a lot, but i am going nuts! I have a Hitachi 5K320 250Gb Harddrive that for some reason I cant get in anymore. I have very important stuff on there that i need for my...
I know it sounds a little nuts but try it with the drive upside down or on either side or on end supported by some books, you can also try cooling it off in a fridge for a while. when a drive starts to go and starts making clicks and vibe noises you have very little time to get everything off. before you try anything make sure you have space to save the files if you do get in.
Also look into Puppy Linux it runs in ram without running the hard drive,
Puppy may be able to read your drive.
I'll check in with you later, off to work.
Regards
TickMagnet
Aug 16, 2011 | Hitachi Travelstar 5K320 320 GB SATA Hard...
I was copying an avi file from the 250GB lacie porsche hard drive (USB2) and the USB cable got removed while the copy was in progress. I tried restarting the computer but the hard drive isnt regonised. it...
hi.
maybe problem is caused by your Power supply.
so i recommend you to do these:
1- remove the main hard drive and only connect "250GB lacie porsche hard drive".
and see is it recognized or not.
2- go to the bios (with pressing "delete key" at start of turning on) and navigate to power center.
then enable power saving mode.
Jan 29, 2011 | LaCie (300728U) 250 GB Hard Drive
Im turining my drive on while its connected to my mac and its making a clicking noise and not ringing up on the computer/the computer doesnt show that its connected
When a hard drive makes a clicking sound, (its known as the click of death), The hard disk is faulty and it is unlikely it will work again.
If you need to recover data from this hard disk there are companies that can help you, but it will cost you an arm and a leg for their services.
Aug 29, 2010 | G-Technology G-DRIVE (90801201) 250 GB...
Its not getting recognized it doesnt show up in the desktop
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
Open the external hard drive cover, remove the hard disk inside, and fix it back. Try again and let's see what happens.
If it still does not work, insert the external drive into the computer, feel the hard drive if it spins/vibrate from inside or if it makes a cracking noise.
If it spins/vibrate, it means the hard disk is still working. In that case, you have to get another external drive case/cover.
But if it makes cracking noise, then it means the hard drive is damaged and you need to get another one.
Take care
Jan 08, 2010 | Computers & Internet
System inoperative. Keyboard lights are on, power indicator lights are lit, cant tell if hard drive is spinning computer makes buzzing type noise upon start up
There are Problem with your hard drive it has been crashed.so pls check with another hard drive if its working fine then pls calll vendor for the same.
Nov 22, 2009 | Dell Dimension 4600 PC Desktop
My hard drive is making funny noises and isnt recognized
If you get it going, you should immediately store all the data on another drive
Aug 19, 2009 | Western Digital My Book Essential Edition...
HDD makes noise?
not really bad, its normal when the hdd is in progress
Jul 16, 2009 | Dell Inspiron 1521 Notebook
My controller connection to my PS3 constantly dies after about 45 minutes whether its plugged into the USB port or not. How do I fix this?
hey i had my ps3 for about 8 months or so i got the message i did everything unplugged it didnt work held power button 10 seconds restarted it nothin- mine makes a weird noise and the orange light saying its loading wont turn off if it does that it pretty much means A. your hard drive is fried B. your hard drive isnt responding with system C. you turned off your ps3 while loading something and it fried it i think is what happened to me
Dec 11, 2008 | Sony Playstation 3 (PS3) Console
IO Magic Corporation GigaBank  (I250HD35) 250 GB USB 2.0 Hard Drive Logo
460 people viewed this question
Top IO Magic Corporation Computers & Internet Experts
Falling star
nuhu ibrahim
nuhu ibrahim
Level 1 Expert
John Lavis
John Lavis
Are you an IO Magic Corporation Computer and Internet Expert? Answer questions, earn points and help others
