Question about Compaq Presario Notebook
Network and security alert problems after intel driver update vista home premium
After folloowing links to update intel ide ata/atapi controller i am getting security alerts about not detecting antivirus software, that windows defender is turned off when it says it is on and i cannot explore or connect to a network.
    Problem Solver:
  • 7 Answers
There might be a virus attack try detecting and correcting it then it might work
Posted on Nov 18, 2008
My Intel RST is NOT running every time I boot up each day. Your answer didn't solve the problem. It shows in Services, it is running and on Automatic??? This just happened recently...
open control panel and select administrative tools
now select services
find intel rapid storage...
double click and open go to startup type and select automatic and click ok
Dec 05, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Acer Extensa5620z originally had Vista, I wiped the hard drive and installed W7. Its not as simple as I thought. Now I need to update drivers and Acer.com doesn't have anything listed. In the det
Windows 7 should automatically install device drivers for the Audio, Video and Network, If you are unable to find/download a device driver that works on your computer and your computer is connected to the Internet then - 1. Remove the driver that isn't working if it was installed.
2. Set Win-7 "Windows Device Installation" to 'AUTO'
3. Windows will automatically search the internet for the driver.
4. Reboot your computer.
Mar 19, 2013 | AU Optronics Acer Extensa 5620-4801...
When i instaled win 7 os to my system it displays a window as load driver. tel me a solution to solve tis problem.
Seeing as a lot of people had the CD/DVD driver missing error that I was stuck with I'll list the steps that I took to get it to run. Before I did anything, I downloaded a free copy of Hiren's Boot Disc with Keyboard Patch just in case I had any issues (freeware and fairly easy to find if you google it). I only ended up using it for the DOS prompt but hey-ho...
Some of these steps may seem redundant but ultimately it was what got the OS running for me:
1. Partition and reformat HD from DOS with the FDISK and FORMAT C: commands
2. Install a version of Vista 64bit which, in-turn, re-partitioned the drive itself
3. Once Vista was up and running (didn't put in a code since I knew I wouldn't be on it for long) inserted the RC 64bit DVD
4. From the installation window, I ran the on-line compatability check tool
5. It told me that my ITE IT8211 ATA/ATAPI Controller must be updated in order to install
6. Ran Vista Update Wizard which found a new driver for the ITE IT8211 ATA/ATAPI
7. Rebooted Vista 64 to finalize the updates (removed the RC DVD Disc while rebooting)
8. Once booted, reinserted the RC DVD, clicked install and went through all the steps of normal installation.
Again, some of this may seem unnecessary (like the FDISK / FORMAT) part, but ultimately it's what worked and from what I experienced, the problem that people seem to be having with the CD/DVD driver not found is that the ITE IT8211 ATA/ATAPI Controller is not up to date. I couldn't find a place to just "download the driver" and put it on a flash drive or something, I had to allow windows to do that which hopefully won't set people back. I'm not savvy enough to know if you can install the driver in another way.
Nov 13, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I NEED DRIVER UPDATES BUT I DONT HAVE A REG.KEY....
hiiii ther
how r u ??
go to acer.com u will findall the vista update to ur driver
but 1st u need to check if ur machine is compatible with vista if it is
u will find all the update on the acer.com under ur laptop model
if u need any further assistance email me
u take care and have fun
salammmmmm {bye in arabic }
p.s rate me thanks
Nov 22, 2008 | Acer Aspire 3680 Laptop
Controller Driver Issue on Armada M700
I am running a Armada M700 with a Hitachi HTS541060G9AT00 60GB Hard Drive - Ultra ATA-100, 5400 RPM, 8MB. The driver that is loaded in mine is on both primary and secondary is atapi.sys. This driver is also installed on the Intel 82371AB/EB PCI Bus Master IDE Controller, along with intelide.sys. The main difference is I am running Window XP Pro SP2. But I believe that they should use the same driver.
Hope this helps.
dferguson64
Sep 09, 2008 | Compaq Armada M700 Notebook
Compaq D510 sff Dma problem
Those might have been your specs but if you have updated windows some of your drivers autamatically change. Try rolling back the drivers or updating them again. The drivers change frequently when windows hot fixes are dowenn loaded your setting that you had and are trying to set it at are the ones when the system was new.
Dec 17, 2007 | Compaq Business d530 (PB185US) PC Desktop
Pioneer dvd-rw dvr-k17a
Hi, the error code that you have on the CD/DVD drive is a known issue from Microsoft. The error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)".
Since you are using a Toshiba laptop; you can click on this link http://tinyurl.com/toshibadvd and click on the repair tool on the resolution. This is applicable on both Windows Xp and Vista and will delete the upper/lowerfilters on the registry.
In case that the error code still exist you need to manually delete the upper/lowerfilters under the registry by clicking on this link http://support.microsoft.com/kb/929461/en-us . You need to go the "Run" screen then type in "regedit" and click OK or hit the enter key.
This will surely fix the error code that you have on the CD/DVD drive.
Thanks
Nov 13, 2007 | Toshiba Satellite A100-S8111TD Notebook
Compaq Presario Notebook Logo
78 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
