Question about Amana SXD524VW Side by Side Refrigerator
Water leaking under refrig
Ever few days we see a puddle of water coming out from refrigerator to the front, my husband check the water line connections one day when there was no puddle and they were all dry. what could be causing this as if it was from water line it would be wet all the time since pressure for icemaker water dispenser stays constant. is there a drip pan under fridge if so how doyou get to it
    Genius:
  • 1,605 Answers
There is a drip pan under the freg. check the drain hole at the buttom fo the freeze side. make sure it is open.
you can get to the drain pan via front grill. pull the front grill. and you will see the drain pan.
Posted on Nov 07, 2008
Maytag mbf2258xeq leaks but it's not connected to a water line. Where's the water coming from?
water is coming from condensation from the compressor coil. usually this will evaporate fast enough to not puddle on the floor. check the plastic line running down the back of the fridge to see that it's not broken or pulled out. while you have the fridge out, clean the coil by blowing it out with compressed air and clean the pan under the compressor as best you can. Hope this helps
Nov 30, 2011 | Maytag MBF2258XEW
Drinking water from refrigerator stopped dispensing immediately
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , turn on the dispensor light for several hours , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . GE also has a dispensor heater , pt # WR49X10173 which comes with instructions , to keep this from happening again .
May 29, 2010 | GE GSS20IEP Side by Side Refrigerator
No water is coming out
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
Jan 28, 2010 | GE GSH22KGM Side by Side Refrigerator
The water reaches the filter but does not make it to the dispenser. Seems to be some water in the line in front of the refigerator but not much.
Try diagnosing this problem by : At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . There is also a heater kit for the water dispensor , pt # WR49X10173 , which comes with instructions .
Nov 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water stopped coming out of the front
There is also a dispensor heater , you may want to install , pt # WR49X10173 . This should keep the water line from freezing again , if it turns out to be that problem .
Nov 07, 2009 | GE GSL25JFR Brushed Steel Side by Side...
Why am I not getting any water from door dispenser for model GSS23KGSA BB
Pull refrig out , and remove the back panel . At the water valve (piece the wall water line connects to , push up on the white ring and pull the LARGER line from the valve . Activate the water dispensor and see if water comes out of the valve . If no water , replace the complete water valve . If water comes out , reinstall the hose by pushing back into valve , and remount valve and rear panel . Push refrig back into place . Remove the bottom kick plate and disconnect the water line about 6" under front , from the coupling (pushing in the ring and pulling hose ). Press for water again . If no water comes out , probably frozen resevoir behind the refrig crispers , so turn refrig temp slightly warmer for a few days , to unthaw (or use hairdryer) . If water shoots out from hose , then water line inside door is frozen . This would be a more difficult procedure to follow . You can try adjusting freezer temp slightly warmer for a few days to see if it will thaw . If it doesn't thaw , come back to this thread with " water in door frozen " and myself or another expert will be glad to help you .
Sep 09, 2009 | Refrigerators
Defrost line blocked and dumps water in front of frig once a day
Double door Maytag. Water frozen in the bottom and leaking onto the floor. Happened before and don't wish to pay the same repair person who "repaired" it 6 months ago to come out again. What can I do?
Jun 09, 2009 | Maytag MSD2756G Side by Side Refrigerator
I have a crosley refridgerator approximatly 8 or 9 yrs. old, and it has started leaking water on the floor. We will find a puddle on the floor about every 2 days. Yesterday, (march 24th), We noticed water...
First make sure than the drain hole in the freezer floor is not clog also check the water plastic lines under the front and back of the refrigerator
Mar 25, 2009 | Refrigerators
Water Leak around left front wheel
I would check the defrost drain inside the freezer. this is real easy to do on this model refrig.
  • remove bottom basket (if it isnt frozen in place) and the shelf above it.
  • in th back just below the coil cover in the freezer section there is a ledge that will most likely be frozen over remove this ice using a hair dryer or hot water which ever is conveinant for you
  • you should uncover a drain hole flush this drain with hot water I use a turkey baster or large syringe to forcefully push water thru to clear anything in the drain
  • put it back together and you should be good to go
when ever the unit goes into defrost (which is about twice a day) the water runs over the ledge and then out of the door by the hinge puddling up next to the wheel. this unit has a hard fiberglass drain pan that is built in and unless it has been dropped i cant imagine the drain pan being damaged.
Let me know if you have any other questions Peyton
Mar 07, 2009 | Kenmore 74192 / 74194 Top Freezer...
Amana SXD524VW Side by Side Refrigerator Logo
434 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
