Danfoss thermostat control frozen at 20 degrees showing room temperature 25 degrees when room temperature not that hot
See the link on the Danfoss site.  This has helped me http://heating.consumers.danfoss.com/xxNewsx/5dbcb2f9-e888-4d2d-9761-7470786749c9_CNP1.html
Posted on Dec 09, 2008
My thermostat is set on 68 degrees and it shows room temperature is 68, but the furnace still kickson, Honeywell said it has a 1 degree difference. so what's the problem then?
Yes there is a one degree tolerance, in fact my heater just kicked on and it is set to 67 and the inside temperature reads 67. It is also a Honeywell.
Dec 28, 2016 | Heating & Cooling
What causes the top 2/3 of the evaporator coils to get frozen over, but leaves the bottom 1/3 clear of any frost?
no the defrost thermostat only need be checked at cold temp and at room or reg temp it should not show any continuity have u checks ur heating element out as well and defrost timer ? I still suspect a faulty thermistor the freezer has more than one thermistor?
Mar 31, 2016 | Refrigerators
My thermostat showing on screen 76F when really room temperature is 70F and I HAVE MEASURED PROPER room sensor resistance OHMS to real room temperature. Why thermostat showing higher temperature and n
Where is the thermostat in relation to the return? Is there air flow or is the air stagnant in the area of the thermostat. Have you placed a thermometer in varios locations where the thermostat is located? Try these locations and see if the thermostat needs to be placed in a location better able to reflect room temperature. Also how long have you lived in the house? If it is a newer home I suggest that you contact the builder or the air conditioner/heater installer to see if they have a schematic of the placement of the thermostats.
Nov 25, 2014 | Honeywell TH8110U1003 VisionPRO 1H/1C...
Dyson hot and cold fan only works in hot mode
Hi there, it's Jack at Dyson.
When you adjust the target temperature of your Dyson Hot fan heater (shown on the LED display on the base), you're setting the target temperature you would like the room heated to. The actual temperature of airflow produced by the fan heater will not vary.
If the heater won't run below 25 degrees, this is likely to be because the temperature of the room you're in is equal to or warmer than 25 degrees. The heater will only turn itself on if the temperature drops below 25 degrees, and once the room temperature reaches this target once again, the fan will turn itself back to monitoring mode.
I've attached our Getting started video below which shows how to adjust the temperature, using the remote or the controls on the base.
I hope this makes sense. It sounds as if your machine is working correctly, but if you'd like any further advice from our experts you can reach us at 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Nov 09, 2012 | Dyson AM04 Hot Cool Fan Heater White
I have a Kenmore Electric Dryer #76974150. It only works right the higher heat setting. Will not heat at all on the low heat settings? Any ideas?
If the dryer is running then the thermal fuse is okay.
The temperature is controlled by three parts. There is the operating thermostat which is on the blower housing and is rated at 150 degrees. This is high heat.
The operating thermostat sits in a thermostat heater which is controlled by the temperature switch. The temperature switch controls how much voltage passes it to the thermostat heater. This is how we achieve lower temperatures. There is about a 15/20 degree difference between high heat and low heat.
The restricted vent may have caused the appearance of the dryer running hot.
I would suggest you check the temperature coming out of the exhaust. It can be checked with the vent hose pulled off. Any thermostat with a range between 120 degrees and 160 can be used. With the vent removed check the temperature of the air in the exhaust. At high temperature it should cycle between 135 degrees to approximately 155 degrees. This is high heat.
If you turn the temperature switch to a lower setting such as delicate you should see a lower temperature in the exhaust. It may only be 15 degrees lower but it should show a lower temperature.
I hope this information helps to resolve this problem.
Jan 08, 2011 | Kenmore Dryers
Self defrosting fridge/freezer
Good day,
That is normal if the room or area is too cold. If the room temperature drops below 55 degrees Fahrenheit then that problem will start to show up.
All manufacturers state the machine will start to unbalance below that temperature.
Mar 13, 2010 | Bosch Refrigerators
Honeywell Chronotherm III Lowest temperature setting is 45F Any way of getting it lower thanks
If you are successful in setting it lower , you will end up with frozen pipes and large plumbing bills. Since the internal walls of a building can be as much as 20 degrees lower, that the room.
And the location of the thermostat, may be even warmer, that that of the areas where the plumbing is.
Now what is your reason for wanting the thermostat operate at a lower temperature?
Jan 31, 2010 | Honeywell Heating & Cooling
Digital oven temperate is wrong
Yes, that is the probe that sends info to the controller.
If it's not bad, then the controller is, but normally it's the probe.
Check that the controller has not been incorrectly calibrated before you change the probe out, although most do not allow a swing of more than 15-20 degrees. Yours may allow more though.
I am guessing you measured the actual temperature, to the set point temperature, with a know good thermometer.
Jan 30, 2009 | Frigidaire FGB24S5A Gas Single Oven
My heat is turning on but the fan isnt working. my honeywell thermostat is showing a flame and a blinking battery, and i know nothing about this thermostat, we just moved in . Can u help?
This is not a PC problem
Symptom
Heating comes on, but sometimes it
gets too hot, sometimes too cold.
Neutral not connected
Cure
Check wiring in room thermostat. Look for a
connection to the Neutral terminal (N 2 on
the Honeywell T6060, T6160, and T6360).
Make sure that it is connected (check
continuity).
If there is no neutral available, replace with a
two-wire thermostat, e.g., CT200, CM61 or
CM67. These will also offer extra energy
savings, (Without a neutral connection, the anticipator within the room thermostat does not work,
so the temperature control reduces from ± ½ºC to ±3ºC. People can feel a six degree
temperature swing. Then, if they try to adjust the room thermostat to overcome the
problem, the temperature swings become even worse.)
Mar 16, 2008 | Computers & Internet
Heating & Cooling Logo
850 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
