Question about Philips DVD729 DVD Player
DVD / VCR Recorder
It will not read any DVD. It tries loading and you can hear a clicking sound and then it says "Cannot Read disc The playback feature for this disc may not be available."
SOURCE: disc error "playback feature may not be available on this disc"
Hello arnita2211,
This error message is due to an improper format, that your dvd player can't handle. To correct this you need to use a program such as nero and in nero is a program called nero vision, that will recode the movie file into a dvd playable format.
You can download a trial of nero here
You will have to purchase a license when the trial ends. Sorry we cannot give you a serial key for this as it is Illegal.
Thank you for trying Fixya!
Posted on Apr 08, 2009
0 characters
1 Points
Panasonic DVD recorder #DMR-EH65. It will accept a blank dvd then go into read,I can hear the lens assembly go back and fort several times,then it says disc error.Did the lens life expire?
Hello timmy: The recording process on the dvd recorder side is done is done by a seperate lens from the playback, so there could be something wrong with the writable side of the optical assembly, another thing to consider trying is the cleaning disc if you haven't tried this, another brand of blank disc and finally a firmware update is available from panasonic for the specific model you have, I don't know if you have updated it but here is the overall description: DMR-EH55 DVD Recorder Firmware Update
  • Version UP-317
  • Compatible Models DMR-EH55S
  • Issues Addressed Issues Addressed
    1. Corrects DVD Recorder hang-up or freezing during DVD playback caused by connection to Scientific Atlanta cable box model # 3250.
    2. Resolves U71 error message caused by HDMI connection to Philips TV.
    3. Improves DVD-Video playback of DVD+RW discs.
    4. Prevents DVD Recorder from turning on Panasonic TV's power by HDAVI control (EZ Sync) when connected with HDMI at completion of copying or finalizing.
    5. Resolves SET CLOCK MANUALLY tab being grayed out after a power failure.
I hope this is helpful and the update is available from, all you need is to type the model number in the search windows after you click the support option. Thanks!
Jul 12, 2010 | Panasonic DMRES20D DVD Recorder
I don't know if my first REQUEST for Assistance was received, at any case, I REQUESTED to find WHY my GO.VIDEO COMBO Player is NOT READING any of my blank DVD DISC( SONY, IMATION, MEMOREX, DVD+R ), IT KEEP...
If there is nothing on the disc, it will read, "no disc". It will only read and/or identify discs with media loaded or burned onto it. Your unit is a player, not a DVD+R (recorder). Can record VHS, but not discs.
Jun 30, 2010 | GoVideo Go Video DVD/VCR Combo
Sony RDR-VX530 DVD Recorder / VCR Combo - cannot format DVD+R
is it possible to record dvd+r?
is this machine not only dvd-R
Apr 07, 2010 | Sony RDR-VX530 DVD Recorder/VCR
Dvd player wont play
Make sure that the DVD Disc is of the format that your DVD recorder can read. For example, if your recorder specifically requires a DVD -R type disk, it will puke on a DVD +R disk.
Apr 12, 2009 | Emerson EWR20V4 DVD Recorder/VCR
Dvd playback
Clean the DVD lens with isopropyl alcohol (rubbing alcohol) and a Qtip. Be careful not to press down too hard. Gently clean the lens all around. Changing Qtips if you see anty signs of debris or dirt on the tip.
Feb 06, 2009 | LG RC199H DVD Recorder/VCR
Disc Error, Will Not Read Any Disc New or Old
DVD players are ****!! This is my 5th time buying one. It's like the industry is running a big scam because that know that soon all movies will be digital mp3. All of my players give me the same error!!
Jan 04, 2009 | Sony RDR-VX500 DVD Recorder/VCR
Some blank DVD+R discs will not read on my DVD player
The JVC DR-MV1S DVD Recorder / VCR Combo does not suppport DVD+R, only DVD-R, -RW etc.
At least mine only supports these formats, as when I first bought mine, I got some blank DVD's they were DVD+R.
I recorded a movie onto one on my PC, then tried playing it in the JVC unit... no go!
Instruction manual (available for D/load online) proved to me that I could not play +R disks!!
Jun 11, 2008 | JVC DR-MV1S DVD Recorder/VCR
JVC DVD Player/Video Cassette Recorder Model HR-XV2EK
try to clean your machine by playing a lens cleaner disc coz the lens might be dirt enough not to pick on data from the discs you play. if it does not work then isuggest you change the lens coz it might be weak
Aug 01, 2007 | JVC DR-MV1S DVD Recorder/VCR
DVD player does not read discs anymore
the Laser is most likely defective. most likly it will need replacement. There is no correction that can made to correct the problem except to that of a replacement of the laser
Apr 06, 2007 | Toshiba D-VR4 DVD Recorder/VCR
Philips DVD729 DVD Player Logo
20 people viewed this question
Top Philips DVD & Blu-Ray Players Experts
Level 1 Expert
rugby prop
Are you a Philips DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
