Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
Panasonic PT-50LC14 has evenly spaced vertical blue lines aproximately 1 cm apart
My Panasonic PT-50LC14 has developed evenly spaced (parallel) vertical blue lines aproximately 1 cm apart on all inputs. The TV has worked beautifully for nearly two years ... this problem came on rather suddenly over the course of a week or two the lines got worst and worse.
This model has a LSXA0572-HB Light Engine; replacements are available for $1500 but that is more than I paid for the TV. All of the TV repair folks I've talked to so far would just swap out the light engine and charge me the $1500.
I expect this problem is due to a $1.00 component going out of spec ... how can I find someone who can figure this out at the circuit board level? I am not an Electrical Engineer but I can handle a soldering iron :-)
  • 37 Answers
It's not the light engine it'sd the bulb, replace that first, then clean it all out then go from there........
Posted on Mar 12, 2009
Should I replace my lamp for my Panasonic 1080i htd t.v. pt-50LC14
Replacing a lamp won't work. There is not even one lamp in your TV. I'm afraid the lightening has done more damage than can be repaired. Even when some tech manages to repair te error, the TV can have the next error in days or weeks.
Try reading something about ESD. Electro Static Discharge and what it does to electronics. Electrostatic discharge
Apr 25, 2015 | Panasonic Televison & Video
Tip
Panasonic PT50LC14 Manual Download
Download Panasonic PT-50LC14 HDTV Manual
Models: PT-43LC14 / PT-50LC14 / PT-60LC14
Have you misplaced your Panasonic PT-50LC14 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Panasonic PT-50LC14 HDTV Users Guide?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
on Apr 30, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Tip
I hope that helps.
on Apr 30, 2010 | Televison & Video
I need the service manual for the Panasonic PT-50LC14. Can u help. We have to change the Blue Filter and I cannot find my service manual. Thanks
It's $38.95 at Partstore at this link
http://www.partstore.com/Part/Matsushita/Panasonic/PT50LC14/Matsushita/Panasonic/SMPT50LC14/New.aspx
Sep 28, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Vertical lines across screen on my panasonic tv PT-61LCX65
Try setting a portable fan aimed toward the cooling vents on the back of the set. If this eliminates or reduces the occurance of the lines, this means a circuit that controls the off/on of individual pixels has developed a thermal problem. This circuit is ordinarily loacted on the main circuit board and is likely to degrade further. You might inquire at the Panasonic service center if they have an exchange program in place and they will probably be able to confirm my suspicions.
Aug 09, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
I have a PT-AE900E & have developed lines running vertically down the screen evenly spaced apart. What is causing this??
If these lines are coming with the input signal then you have to check the Cable connectors.
If these lines are coming without the signal then check the panels and service then recheck.
Regards
Viren
Jul 17, 2008 | Panasonic PT-AE900U Multimedia Projector
Grennish/yellow spots pt-50lc14
I received a new blue polarizer unit from Panasonic. I installed it and it fixed my problem!!!
Duane
Apr 09, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Plastic housing
moz-screenshot-1.jpgTry this link and download the manual. See page 81.
http://www2.panasonic.com/consumer-electronics/support/Televisions/LCD-Projection-TVs/model.PT-50LC14
Nov 16, 2007 | Panasonic PT-50LC14 50" Rear Projection...
Vertical lines
IF the area of the OSD (on screen display) displays the same vertical blue lines as the rest of the screen, then it is most likely the optical block assembly at fault. It's part number is A1606006A and should cost close to $2,000. I'm assuming the set is out of warranty. I know many people are hooked on Sonys, but as a technican that works on them, I wouldn't want one in my home.
Dec 08, 2006 | Sony Grand WEGA KF42WE610 42" Rear...
Convergence Problem
The convergence IC's have been known to cause similar problems and both would be replaced at the same time. Not an easy job for a DIYer. I would get a repair shop to fix it.
Dec 19, 2006 | Panasonic PT-47WX5347 47" Rear Projection...
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
305 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
