Question about JVC HR-S9500 S-VHS VCR
JVC HR-S9500U The vcr flashes AUTO all the time now. It will turn on for a few seconds then turn off and start flashing AUTO again. If I put a tape in it only stays on long enough to load it and returns to power off auto flashing mode. I checked the child lock(holding the power button)and it's off. It allowed me to do that while loading a tape since that's the only way I can keep it on more than three seconds.
  • beeser750 Dec 27, 2008
    I have the same problem. Unplugging it for any length of time, 15-minutes or 15-days, makes no difference. When it's plugged in, it's on for 3-seconds, then goes to the flashing "Auto" mode.
OK, found the problem. Another website had the same question on the HR-S9600U, the 9500's replacement:
I checked my vcr, and, sure enough, there was a sort of clicking sound coming from the drum area immediately before the unit would go into "Auto" mode. I removed the complete drum assembly, and tore into the little gearbox, and found the two black, plastic gears with inside pinions that drive the metal screws to change the video head position had each cracked and were slipping on the shafts. This caused the gearbox to bind up.
Using a jeweler's screwdriver, I roughed up the metal shaft and the inside of the gears where they slip onto the shafts, and glued them on using a two-part epoxy. I then re-assembled it all, sorta setting the screws about two turns after their contact with the base of the upper drum. Now, upon power-up, the drum adjusting motor toggles one direction, then the other, and the unit stays on. Playback seems OK.
So, there you go. Yay me....
Posted on Dec 28, 2008
  • 979 Answers
Power down unit and unplug. Wait 15 minutes and see if all functionality comes back.    Accordianman
Posted on Oct 11, 2007
Tishoba vcr v-231 tape counter does not come on, no picture from vcr
Someone would have to look inside to see if the tape is not moving, no movement will cause it to shut down--have to look inside first.
Dec 10, 2012 | Televison & Video
The Air bag light flashes for a few seconds, then stays on steady. any pointers?
isuzu trooper 3.0 airbag light.comes on goes off and bk on again when started.. have had seats out and checked wires on reinstallation.but wont go out?
Jan 24, 2010 | 1996 Isuzu Trooper
Panasonic VCR 7350 displays error messages and cant insert tape
There is either some damage to the mechanism or the mode switch is faulty. If you know what to look for taking the top cover off might show what part of the mechanism is damaged.
If it is the mode switch then it will need to be replaced. This can't be done without the service manual as the vcr needs to be set up. And they are never set up in the eject position.
Sep 27, 2017 | Panasonic AG-7350 VHS/S-VHS playback VCR
CST In light is flashing green
I had the same problem. Aren't three-year-olds great? Mine had jammed several clothing tags into the VCR slot. Clearing them out didn't solve the problem, but I then took the outer case off (with power disconnected of course) and verified that there was no physical damage to the tape heads and that everything internally was clear. I put the case back on, and everything's back to normal.
Jan 06, 2009 | Sylvania SSD803 DVD Player/VCR
My Tv is turning off by itself
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Mar 11, 2008 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
What do I do when my Emerson TV keeps turning off by itself?
I had the same problem with mine turning off after 3-5 seconds. After much research I found a suggestion that on some combo units the vcr part could have a power supply cutout if it is not working correctly. I tried to insert a tape and found that the tape mechanism would not accept a tape. I used a little bit of force and managed to insert a tape. I then played the tape forwards and backwards and the power stayed on! I ejected the tape and found the TV then worked just fine. The power has now been on for over one hour. I hope this give you another avenue to try and fix your problem.
Nov 30, 2007 | Televison & Video
VHS player stops
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
Aug 22, 2007 | Zenith DVR413 DVD Recorder/VCR
if all you want to do is disable the vcr portion turn the set on , install a blank vhs tape it has to be blank or the vcr will try to read it .and the tv and dvd should work fine. this is a timing problem in the vcr deck its not hard to fix but it is a pain.
Nov 05, 2006 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
The problem is the tape mechanism is malfuctioning. It trys eather to load or play a tape and a sensor inside tells the microprocessor to shut down this mechanism before damage is done to the tape. BUT sometimes a malfunction causes a damaged tape too. this unit has NO user serviseable parts inside itself, so its time to take this puppy into a repair shop to see if its worth the repair , Unless this units more then a few years old?? then its time to buy a shiny new unit. Good luck
Jul 09, 2006 | Emerson EWD2203 DVD Player/VCR
1,556 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
