Question about Microsoft Xbox 360 Console
Hhd how do you take the HHD off?
  • 344 Answers
Press the tab on the front of the hard drive and lift the unit from the console.
Posted on Nov 07, 2008
I have a 500GB Maxtor hard drive and it is emitting a beep when plugged in and nto being recognised by the computer
a hhd have 5 years of warranty so u can replace the hhd and get new hhd , if u need some files then tell them to restore the files
Dec 05, 2011 | Maxtor Hard Drive
Hi I have a Acer Travelmate 4050. The MB bios does not pick up the HHD. Wen I startup using my Windows XP cd It does pick up the HHD I can then Format and the installation will copy the files to the...
If the BIOS does not detect the hard disk and Windows XP cannot detect the hard disk to install Windows, then the hard disk is faulty.
To get your Acer working agai, you need to replace this hard disk with a new one.
Apr 21, 2011 | Acer Computers & Internet
I have a serial ATA mobile disk drive, model # HD-338-SSC. My computer no longer recognizes the device and the power button on the device displays the standard green light. I tried connecting the device to...
Most of these problems are associated with an I.C. on the board that governs the HHD. Unfortunately, the chip gets pitted (overheats) on the GaAs and is ruined. The green light (LED) on the HHD will turn on as it is getting power but the main chip that controls the HHD no longer works thus rendering the HHD inoperative.
Bottom line, get a new external drive. Should you get the same model or something similar to what type of electronic hardware you have, you can remove the new HHD and put your old HHD in its place and you will see that all of your data is still intact.
Apr 12, 2011 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
I Have toshiba tecra a2 cm101e when i install
You need to partition and Format this drive before you can do what you want.
Apr 01, 2010 | Toshiba Tecra A2 Notebook
My PC hard disk is always out of space why
Windows Xp itself requires 4-4.5GB plus any other applications softwares, basiclly you should have 6GB for all of the software before any other software.
for WIndows Vista that requirement is around 7GB.
you need to clear up the HHD via accessories>>system>>disk clear. select all of the item listed. defrag the HHD after cleaning.you may have to perform the defrag serval time before yu get to a reasonable area. ideally you should have 15% of free space on your HHD.
if yu can't create enough free sapce, tehn you should consider buying a larger HHD.
Mar 27, 2009 | Microsoft Windows XP Professional
How to replace operating system new hard drive netvista 2292 22u
jsut pop in the recovery cd and follow the direction.
make sur eyou remove the old HHD.
you can copy all of the files from the old HHD after the new HHD is in working order.
Mar 24, 2009 | Computers & Internet
Error Message???
sound like the hhd is going .
backup all your files to some external hhd or to another computer.
use the Window Xp Cd to reformat eh hhd and reinstall Xp. if the format encounter hhd problem it will stop. in that case, you need to buy a new hhd and replace it. if not the format will go throught, do that twice and reinstall XP.
Jan 14, 2009 | Acer Aspire 5050-3242 Notebook
Duel boot system first xp then vista
Wow....
First I would check the BIOS settings. Make sure that the slave and master jumpers are correct on the drives.
Wouldn't it be easier to make one drive Windows XP on one drive while running Vista on the other?
It would make things easier to troubleshoot.
Jun 12, 2008 | Computers & Internet
Toshiba Satellite A65-S126 Notebook will not boot
Locating the HHD in Toshiba will be the most difficult. They have put them in several different places in the machine over the years. First try any access panels on the machine (look for a small rectangle shaped panel aprox. 1x3, probably on the side), then check under the keyboard, on a couple of models they put them under the touch pad. It should be in a HHD caddy, that will slide out. The caddy will have at least one screw holding it and there will be two or four screws holding the HHD in the caddy. Also check to see if there is a connector on the end of the HHD, you'll need that. Once you've found it, put the new HHD back in the same as the old one and you there.
Jun 11, 2008 | Computers & Internet
E67 solution not working...
I think it might be the HDD. Try using a different HDD.
Also try this -
http://forums.xbox-scene.com/index.php?showtopic=484726
Feb 17, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
16 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
