I have a Samsung VR5803 VCR. Recently, the tape drive stopped working. (It would accept the tape, and then rapidly switch on and off for minutes at a time. Eventually, it would stay on with the tape inside.) Now, I cannot even get it to accept a tape. Can I get this fixed?
  • 275 Answers
SOURCE: Sony SLV-940HF VCR Will not accept tape
Dear Rob, There can be two reasons for your problem.Let us consider the simpler and most likely cause.....Belts!!! Unplug the Plug from the Power socket. Open up the top and bottom Panels.Check the belts. Most likely you will find a belt has snapped ( a 80% possibility) or become very very loose. Also check the Tape Loading mechanism,there is a small belt which connects from the Loading motor to the Loading Mechanism. Replace the belts as a entire set. Let me know if this worked out. Good Luck.
Posted on Jan 27, 2007
dodgecharger
  • 254 Answers
SOURCE: VCR won't take tape
Is it ejecting the tape when you set up for timed record, or any record mode for that matter? If so, check for the presence of the record lockout tab in the tape. If tab is there, machine should accept it. If machine ejects tape with the tab present, then the sensor which detects tab present or absent is probably afoul. this sensor is often a small switch. This tab, by the way, is on the backside of the tape, on the left, looking at the tape from the back.
Posted on Apr 16, 2007
  • 15 Answers
SOURCE: vcr not playing tapes, just ejects them
Not enough info. What is the product? Brand, model, how old?
Posted on May 13, 2007
premtech
  • 934 Answers
SOURCE: Magnavox combo vcr dvd
What you're describing is common when the center LED has failed / gone out. If you're really good at taking a unit like this apart and putting it back together - and not too bad with a solder stick you could attempt this one yourself... It is a pretty intensive repair but not difficult for a good shop just time consuming. The part isn't too expensive either, just an infared LED... In fact, we've run a bit short on stock once in awhile and bought one of the off the shelf versions from Radio Shack which worked just fine. Good Luck Bill
Posted on Jun 12, 2007
dodgecharger
  • 254 Answers
SOURCE: toshiba w528 vcr tape eating
Tape "eating" is usually caused by a no take-up condition, that is, the take-up spindle isn't being driven, and thus a certain amount of tape spools out inside the mechanism until the logic circuit senses an error condition and places the machine in an off or stop mode. Cleaning the head shouldn't cause this, assuming you knew what you were doing, and nothing was broken or bent in the process. Look down in between the spindles, and you will see an idler wheel which pivots between the spindles, depending if the mode is Rewind, Fast forward or play. This idler mechanism should pivot freely. If the grease is dried or sticky, or the idler is otherwise broken- gear teeth missing, etc. such must be corrected. If the idler needs replacement, one might be available from the manufacturer, or a parts supplier such as MCM Electronics.
Posted on Oct 08, 2007
Close when play vcr
Problem in the mechanism that moves the tape in play,ff,rewind and also winds tape back into cassette and ejects it.
Likely a bad or worn belt or drive idler(rubber).
Nov 04, 2012 | Televison & Video
Samsung v7000 DVD/VCR .....VCR ejects tape when record is pressed
Does this happen with other tapes? If so then the micro switch could be stuck in the open position, try to give it a clean with a blast of air duster first then check the contacts on the switch. If it is happening with just this specific tape the the record tab (although in place) may be "soft" try putting a piece of tape tightly across the tab & try to record.
Aug 13, 2009 | Samsung Televison & Video
Go-Video VCR Problem with accepting/ejecting tapes
As with any VCR, there are rubber parts inside that have become slick. This is a simple repair for any shop. The mechanisms are Samsung ones if I remember correctly. Expect a parts cost between $20-$40. Add in the local labor rate for the total cost. This is worth the repair cost as any replacement would not last anywhere near as long. This is also a normal occurrance as rubber parts harden with age. I have repaired many of these over the years.
Dan
Jan 05, 2009 | GoVideo Go Video DVD/VCR Combo
DVD stops recording after about 30 seconds
If the take up reel is not working properly the slack in tape drive will cause poor recordings and shut downs.
Sep 13, 2017 | Insignia IS-DVD1001 DVD Recorder/VCR
Can the Panasonic AG-DV2500 play 90 minutes Minidv tapes?
the DV2500 will not play LP (90 minute) tapes. when an LP tape is inserted, it will play for 2-3 seconds, and then eject.
Nov 28, 2008 | Panasonic AG-DV2500 DV/Mini DV VCR
Vcr will not accept video tape
A common problem on this unit is the Mode Switch. It gets dirty or sometimes breaks and must be replaced - definitely not a job for the unexperienced. If you mess up just a tiny bit, especially during re-assembly, your VCR unit will never work right ! Sorry for the bad news.
Jan 31, 2008 | Emerson EWC1303 13 in. TV/VCR Combo
VCR won't take tape
Apr 14, 2007 | Sony SLV-N750 VHS/S-VHS playback VCR
Jan 27, 2007 | Sony SLV-940HF VCR
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
Electro Med Services...
