I have a serious problem with my Trinitron 32" KV32S42 blinking on and Off all the time. I got tweeter technician to fix the problem. He said said ".the tube is defective not worth fixing". I brought the problem to Sony Customer Service. I spoke to 9 people. All I got is running around. for 13 days I got no where. The Sony President office said the TV was made October 199o. We purchase the TV 2002. The do not support 6-7 years old TV. I appreciate any help or suggestions. Sincerely, C. Sahely
Hi there Jomaru, I also have the same set and experienced the same problem, Never recieved a true fix . But,What i have found is that if you remove the Video fiie cable from the KSB And re-seat it, it seem's to solve the problem. At least temporarly, The problem has not re-occured on my set. I hope that have the same result.
I have looked on the net for a similar problem. It seems a common failure but yours is slight. If you can use a voltmeter and can find where to check voltages, then try to find a (low) voltage which is going lower periodically. You may be able to hear a relay clicking where the trouble is. The cause which is common to these sets is probably a bad soldered component. Use well insulated finely pointed probes to avoid shorting anything.
You can find the date of manufacture in the back label,if the set is a 1990 maybe then is not worth repairing but is only a 2002 set is only 4 yeras old and the set has most likely a good picture tube,the symptom you are giving us does not indicate a bad picture tube,you should get a second opinion ,it might something as simple as a loose conection in the horizontal drive transformer.Let Us know how it goes or if you need more information.
i got same tv pic is all rainbowish and no it wasent dropped or next to a speaker
I just got a Sony Trinitron KV 32S42 but I dont have the remote and I am not getting a picture from it ..just sound.I got it from the improv who are upgrading with newer TVs.What should I try to do before trying to fix it?..without the remote that is.
TV turns off by itself
