Question about Frigidaire FGF366E Gas Kitchen Range
Error msg F3
I am getting an F3 error msg. I have pushed the clock in to set it, puched in cancel, nothing will stop the beeping, to include unplugging the stove. I attempted to do a self cleaning. also, I noticed the latch is loosened, so as to close the door properly. please help, starving here. Nolka
  • 1 more comment
  • Nolka Frampton Oct 19, 2006
    Nolka here, where do I find the oven probe?
  • Dlynn35 Dec 02, 2007
    my oven is giving me an F3 error after i have been bakeing for a while. sometimes 20 min sometimes 2 hours you just never know. I tried to clean it and the F3 error poped up and wouldn't allow me to continue. stove top works just having trouble with oven part. please Help.!!!
    Danie
  • jplasma56 Nov 28, 2008
    How do I stop the beeping and open the oven door
    President:
  • 878 Answers
Nolka, F3 has to do with the oven temperature probe out of spec. You need to change it out. Part number 316217001. Easy fix. Catriver..post back.
Posted on Oct 19, 2006
  • Ron Marek
    Ron Marek Oct 19, 2006
    Nolka, it will be in the oven compartment. Silver rod sticking out the back of the wall. You can look the part up on the net and see what it looks like. Should cost around 27.00. You can also go to your local appliance parts store with the number I gave you and get it from them. Turn the power off to the oven, remove the 2 screws holding the probe in and slowly remove it. The new one will have a harness on it that just connects. Sometimes you have to get at it from the back if the harness does not pull through the front....Catriver...post back.
  • FYI, I've had the same problem, I've got the F3 error code after toogling the hoven breaker. Unplugging and re-plugging the same probe fixed my problem.
What is F5 Frigidaire oven unit, it's beeping and
The F5 ERROR code means that the self check that the control (also called clock)board runs to check itself has failed and the control has detected a problem within itself and the control must be repalced.
Gene
Aug 10, 2011 | Frigidaire Ovens
F2 &F3 error codes, oven keeps beeping, I already tried turning off circuit breaker did not solve problem
F2
- E0 Shorted keypad (also called touch
pad) 1. Check keypad connector for firm
connection (keypad connects to control board).
2. Press CANCEL. If error code
returns after 60 seconds, replace keypad (also called touch pad or membrane
switch). Some models incorporate keypad in to control board as one unit. In this
case, replace control board (also called ERC or clock). F2 - E1 Keypad cable unplugged F2 - E5 Cancel key drive line open F2 - E6 Cancel key drive line open F3 - E0 Oven temperature sensor (RTD) opened (upper oven,
if double oven) Replace Oven temperature
sensor (RTD)
Note: Applies to all F3-E...
codes. F3 - E1 Oven temperature sensor (RTD) shorted (upper
oven, if double oven) F3 - E2 Oven temperature is too high (Cook
mode) F3 - E3 Oven temperature is too high (Clean
mode) F3 - E4 Oven temperature sensor (RTD) opened (lower oven,
if double oven) F3 - E5 Oven temperature sensor (RTD) shorted (lower
oven, if double oven) F3 - E6 Warming drawer sensor open F3 - E7 Warming drawer sensor
shorted
Dec 20, 2010 | Whirlpool Accubake RF362LXTT Electric...
Whirlpool electric range timer constantly beeps and displays E2-F3 I don't even use the oven I just want beeping to stop I press STOP which changes display back to clock, but soon it returns to E2-F3...
Hi
Thanks for using FixYa.
Error F3-E2 in your Whirlpool oven means oven too hot and to resolve this issue you'll have to replace the oven temp. sensor (probe). Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 06, 2010 | Whirlpool GS475LEKS Gas Kitchen Range
KitchenAid KEDT105V Electric Stove - f-5 beep Started beeping out of the blue, pushed cancel and it stops for 20 seconds then continuous beeping. If the oven is on the beeping will stop. Hope you can help,...
Hi, F5 means your control board may have suffered a fatal error. Unplug the unit for 30 seconds, when the power is re-applied if the error comes back you will need to replace the control board (ERC). Mike
F5 Board failure Replace control board (also called ERC or clock).
Mar 25, 2010 | KitchenAid KESC307 Electric Kitchen Range
Our oven started randomly beeping last night with an error message of what looks like "F1" and when we push a button it stops for only 5 minutes then starts up again. Any suggestions on how to get it to...
Hi. This Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be canceled, replace the oven control (also called clock or ERC), touch pad, or both.
Dec 08, 2009 | GE Ovens
F1 is displayed on Maytag Electric Oven I ran the self-clean cycle on my Maytag Model MER5530 oven yesterday; before it completed F3 was displayed and beeps sounded. I pressed CANCEL, the F3...
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad...
thank u
rate me!!!
Aug 14, 2009 | Maytag Ovens
I tried cleaning the oven and got the error F3.
Electronic control has detected a fault condition. Push CANCEL pad to clear the
display and stop the display from beeping. Reprogram the oven. If a fault reoccurs,
record the fault number.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 13, 2009 | Electrolux Kitchen Ranges
F2 and F3 code appearing along with annoying beeping
i think f3 error code has something to do with the temp probe maybe it is the problem. the temp probe is located if you open the door directly in the back wall. it looks like a prong. should read 1100ohms the f2 error code though usually has something to do with the keypad i would check all the connections maybe they are loose.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Jenn Air F7 error msg with incessant beeping
F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button
Dec 08, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Frigidaire FGF366E Gas Kitchen Range Logo
388 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Paul Carew
Justin Duby
Justin Duby
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
