Question about Casio Exilim EX-Z3 Digital Camera
"lens error" on casio ex-z3
When switching to record mode lense extends then retracts, with screen saying "lense error". there are no visible obstructions, it extends fully, stays there for 1 to 2 seconds max, then retracts with screen saying "lense error". ...very frustrating. in play mode everything is fine. camera is charged. help! --Big R
  • Anonymous Apr 01, 2014
    lense will not retract
  • 3 Answers
Sorry to say but a lens error actually is a problem that you cannot fix at home. When a lens error occurs, the motors inside that make the lens retract and protract were some how damaged, usually caused if the lens try coming out when you have it in your pocket or against a surface so it cant fully come out. You will have to send the camera in for service and you can do that by calling 1-800-706-2534, option 1.
Posted on Jul 14, 2007
SOURCE:
LENS ERROR and RETRY POWER ON
Unfortunately you DO need to send it in to the technician. Sounds like at some stage the lens has been extended and has been 'knocked'.
Believe me when I say 'knocked', it could be as simple as placing it down on the table with the lens extended.
Get a quote first because they vary from place to place and if there are technicians 'on the ground', they can have it back to you by the end of play. Otherwise it can take over a week.
Nov 25, 2013 | Casio EXILIM EX-ZR10 Black
My casio exelims lense wont retract. what do i do?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Aug 28, 2011 | Casio Exilim EX-Z750 Digital Camera
My EX-S5 says lense error
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 10, 2009 | Casio Exilim EX-S600 Digital Camera
Lens error of casio EX Z300
The lens error is usually caused by mechanical faults concerning lens assembly. This happens because there is dirt inside the lens (sand dust), or one part in the lens assembly is bad or went out of place.
Because of this he lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
If if does not extend tapping gently the back of the camera, and if it does not retract helping lens back in while turning camera respectively on and off.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 18, 2009 | Casio EXILIM EX-Z300 Digital Camera
Casio lens error
When I power up my Casio Exilim Z750, it begins to start up, the lens extends, and then it says, "Lens Error" on the screen and shuts down?
Robin
Jul 02, 2008 | Casio Exilim EX-Z750 Digital Camera
My Lens wont retract on my exilm zoom ex-z60
If it is under warranty Casio can fix it for free. other wise you end up paying the labor/parts. Can become very costly. I suggest open the case and replace the plastic housing that hosts the saw wheels. Should fix the problem
Jun 23, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
LENS ERROR 2 on my Casio Ex-V7
I read on the Casio website that this is due to an impact, meaning, the camera must have fallen or hit something really hard and strong.
Lens error 2 indicates that there is something wrong in the lens assembly. One possible damage concerns the image stabilization mechanism.
I also own a Casio EX-V7. My sister dropped it so hard that a dent has appeared on one of the front corners. Everytime I switch on the camera on record mode, LENS ERROR 2 appears for a few seconds.
Despite this, I can happily use the camera as usual. However, it's just annoying to see the Error.
I'm planning to bring it to a service center within a month from now.
May 26, 2008 | Casio Exilim EXZ75 Digital Camera
Casio Exilim EX-Z3 not working (accidentally dropped on carpet)
Does the lens retract when you shut the camera off? Or at least press the On/Off button?
It doesn't sound like there is a problem with the lens if your buttons aren't working, it sounds mostly to me that a cable got dislodged and that has disabled your buttons and zoom switch.
You can try sending it to this guy - www.darntoothysam.com he might beable to help you.
Nov 18, 2007 | Casio Exilim EX-Z3 Digital Camera
Casio Exilim EX-Z3 Displays turns off when taking a picture
I have the exact same problem. Casio wants the camera mailed in and charges $79 for a new LCD screen (if that is the problem). Any other suggestions?
Oct 14, 2006 | Casio Exilim EX-Z3 Digital Camera
Casio Exilim EX-Z3 Digital Camera Logo
259 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Parshiv Luthra
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
