Question about Epson Office Equipment & Supplies
Have an Epson Stylus CX3200.Four years with zero problems. Turned it on yesterday. Red error light comes on, followed by loud buzzing noise for about 30 seconds. Scroll line says "Printer error. see your documentation and call service if necessary." Unfortunatly, this was a gift from my son-in-law, who tragically died six months after it was installed. Have no documentation. I am a 75 year old semi-literate in software but total dunce about hardware.
  • Epson Master
  • 13,433 Answers
Hi, First thing, turn the printer off, turn it on. if the error comes again, turn off, unplug 5 minutes, plug back in turn on, does the problem come back?
If the problem is not fixed you have a hardware problem in the printer and here are the epson contact details
US (562) 276-4382
6 A.M.-6 P.M., Monday-Friday
(Pacific Time)
Canada (905) 709-3839
(Pacific Time)
Let me know if you need anything else, Thanks, Ekse
Posted on Nov 07, 2008
    Sergeant:
    Novelist:
  • 196 Answers
Its the fault in the cartridges .just replace the cartridges.
  • mmechanics Nov 07, 2008
    and before inserting the new cartridges please get your printer serviced from a near by priner engineer.as to avoid further problems.
    thanks.
Epson Stylus C3200 Red Error Light Stays On
Ink level at chip reach zero. Reset ink level counter using hardware resetter. Or Use CISS chip with autoreset.
Jun 15, 2009 | Epson Stylus CX3200 All-In-One InkJet...
EPSON stylus CX3200---printer error check documentation
I followed one of the solutions listed---and it worked!!!!
Jan 25, 2009 | Epson Stylus CX3200 All-In-One InkJet...
My scanner
Open the scanner lid and slide the transportation lock back to the hw_translock_1.gif unlock position.
I will appreciate a Fixya rating if I were able to resolve your concern.
Oct 22, 2008 | Epson Stylus CX3200 All-In-One InkJet...
My scanner
scanner error see ur documentation and callservice if necessery
Oct 21, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus CX3200 ( loud noise like paper is jammed) error message comes up.
By pulling the paper out backwards your sister may have caused a gear to jump. You could try pulling a piece of paper out in the other direction and maybe the gear will jump back into place. Otherwise you will probably have to have the printer serviced.
May 09, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Red light.
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=FAQ&oid=14082&prodoid=24875245&foid=31655
Mar 20, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Nazir
There is an error with the scanner section.
Feb 08, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Printer fails
Need more info. than this. What exactly is the issue - is the printer feeding paper? Is the ink not printing etc.
Aug 26, 2007 | Epson Stylus CX3200 All-In-One InkJet...
22 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
