Sony Receiver makes popping noise in speakers
Hello Folks,
Please...tell me what keeps mappening to these things. I'm only second Sony in 5 years and the problem of popping in the speakers has come back.
I've narrowed down the possible sources with the following steps:
  1. tried all source options, even those without signals
  2. plugged in headphones
  3. tried A and B channels
The noise is a faint pop kind of like you would heard with a record player, but it occurs every 30 seconds or so. You can't hear it when there is music or action on a dvd, but during quiet times, it is evident...and right in my ear :)
My system is the previous generation of this system
Jexx
  • 148 Answers
SOURCE: 2nd Room Source RCA Plugs
It sounds like the jack just needs to be resoldered is all. Open it up and resolder it. Simple, yet beautiful.
Posted on May 17, 2006
melnavz
  • 1226 Answers
SOURCE: Cracking and poping with Yamaha surround sound system
Try put a ground line from any metal of your stuff to the any metal direct to the ground. these eliminate noise of the speaker.
Posted on Jan 04, 2008
  • 104 Answers
SOURCE: popping noise from speakers
sounds like the digital input and the component input are casing inteference , try removing the component video and see what happens
Posted on May 23, 2009
  • 6771 Answers
SOURCE: sony receiver made pop noise
It sounds like the output ic's may have failed, because of the complexity of system I would have a professional come and look at the unit for an evaluation, chances are he will need to take it back to the shop for service.
Posted on Dec 30, 2010
michaelhi580
  • 62 Answers
SOURCE: Pioneer VSX-1015TX 7.1 Receiver AMP ERROR I just
I would recommend checking your speakers polarity ( + on the + - on the - ). Also check to make sure the wires are not touching each other where they connect to the speaker or amp. Also check your input connections if you are not using HDMI or Optical. Worst case is you have to send it in to get serviced. Hope this helps
Posted on Mar 15, 2011
Jan 03, 2008 | Pioneer VSX-54TX Receiver
I have the same exact problem as didierb
Hi
Thanks for using FixYa. You can try and reset the receiver by Unplugging it for 2 minutes and then plug it back in. Also make sure that the speaker wires are not shorted and there are no burnt components on the control board of the receiver (If you have disassembled the unit you'll be able to see the burnt components).
If the problem still persists, after checking the above things then please describe the issue more clearly and also tell me what all things have you tried to fix the issue.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks Rylee
Oct 04, 2009 | Yamaha RX-V800 Receiver
(Dv6000) Sorta frequent loud popping noise.
This happened with a DV9000 recently and the speaker assembly had to be replaced. I found one on ebay for 5 bucks. Need to remove the power button plate and unscrew the speaker assemblies and replace.
Jul 22, 2009 | Gateway GMAX 2100 Computer Speakers
Popping noise from speakers
May 23, 2009 | Sony STR-DE695 Receiver
Onkyo digital reciever has poping noise when in dolby sound
I have the same reciever, and had the same problem.  Contact Onkyo, this is a known issue where defective DSP chips were used and manifest problems with a popping / clicking sound when using surround settings.  These receivers also have a Dolby Digital input issue that can cause audio dropouts when watching cable or SAT broadcasts that encode DD using a 'newer' broadcast encoding methods.  Onkyo is covering the cost of that repair for me now, even though the receiver is 5 years old now....
Jan 02, 2009 | Onkyo TX-DS797 Receiver
Sony receiver DA5ES. Unit start arc and shoot off.
Marko,
I own the same unit (since 2001) & have had no problems. I would get it looked at & see what the issue is & what it would cost to fix. Would it be worthwhile? Well you'd have to ask yourself how much $$ you'd be willing to spend on a replacement vs repairing this unit & based on how much you'd be willing to spend, would the specs on a replacement unit measure up. You'd have to ignore things like HDMI inputs to keep it apples to apples.
I've owned various Sony components for a long time. I only had to get one unit fixed one time (a CD player that my one year old decided to do a chin-up on :( ). The unit was 7 years old at the time and my son is now 12!!. the unit still functions flawlessly since being repaired. Sony builds their stuff to last, even after beiung abused.
Dec 11, 2008 | Sony STR-DA5ES 6.1 Channels Receiver
Receiver making alot of clicking noises.
I Have a son STR DE 845 and the speakers make a popping sound when it is in DTS mode what is the problem.
Thanks,
Larry
Jan 20, 2008 | Sony STR-DE845 Receiver
Das TV make cracking and poping noise when you unhook it from receiver?
Sep 30, 2007 | Sony STR-DE197 Receiver
Yamaha RX-V2400
Get another receiver! I had the same problem and had the power supply replaced $250 and after 3 months it started doing the same thing.  I just purchased a Pinoeer Elite VSX 90TXV.
Jun 04, 2007 | Yamaha RX-V2600 Receiver
329 people viewed this question
 Grubhead
Grubhead
