Question about Acer Ferrari 3200 Notebook
Wireless connection acer 2410
When attempting to connect this laptop as a second computor to my wireless router, the installer tells me it cannot detect a wireless component in the acer
My acer aspire wont connect to my centurylink wifi
Try re-installing the wireless card driver and the configure the wireless card to the wireless router's wireless settings. You can also have a look at the wireless card settings in the computers that is connecting to the wireless router/Internet and then apply these settings to the wireless card in the Acer.
Nov 08, 2012 | Acer Aspire 5253-bz692
I have an Acer laptop computer that stopped being able to connect to wife all the way. It says I am connected but then tells me I have limited or no connectivity. Why?
This error occures when your laptop has not been allocated an IP address from your wireless router.
To fix this, right click on your wireless connection on the Task bar and click Repair. The wireless router will then issue a new IP address to the wireless card in your laptop.
Jan 27, 2012 | Acer Computers & Internet
I bought a acer travelmate 220 How do I use it wireless do i need a card and router
hi
    Instructions
  1. Step 1 Navigate to Acer's support and driver download website at support.acer.com/drivers_download.aspx.
  2. Step 2 Choose "notebook" from the "Product family" list.
  3. Step 3 Select your product line (Aspire, Travelmate, etc.).
  4. Step 4 Select your model number to identify the exact machine you own.
  5. Step 5 Scroll down the "Wireless LAN" entry, under the "Driver" tab.
  6. Step 6 Click the yellow "Download" button located to the left of the "Wireless LAN" entry.
  7. Step 7 Open the installation file once the driver has finished downloading.
  8. Step 8 Follow the on-screen directions to install the wireless driver.
  9. Step 9 Restart your computer when prompted to do so by the driver installer. This will finalize the installation process.
  10. Step 10 Attempt to connect to a wireless network.
Jul 07, 2010 | Acer TravelMate 240 Notebook
Hello, hope you can help me. i have a perfectly good wireless router, but my acer aspire laptop cannot use it due to the built in adapter. can u give me instructions to configure so i can use the...
First your router has to picked up the signal in order for it to work.You may need to use an ethernet cable and connect it wired to the laptop..Then once done you will need to access the default router setting which would be something like 192.x.x.x and this would either be mentioned somewhere on the router or the manual..and would have a default username and password.Once in there you can add encryption type,network ssid name, change all sort of things...Make sure you make note of the key and use it when your wireless network ask for this key.Make sure your wireless network card is enabled and/or turned on....Hope this gives you an idea.
Dec 02, 2009 | Office Equipment & Supplies
Unable to print on wireless network or send e-mail
Recheck that the printer is shared by the computer it is connected to and that all PCs are on the same network. If no success try disabling the firewall on the pc that your printer is connected to. (If printing now works readjust the firewall permissions).
On the second open Internet Explorer; Tools; Internet Options; Connections and make sure that there is a selection for... Never dial a connection.
Jul 08, 2009 | Acer Computers & Internet
Acer Aspire won't Connect Wirelessly Even with Full Strength
do you have security on your wireless network, password etc. like WEP, WPA, WP2 and the likes. that would be the first thing you need to check, second is the type of wireless card and router you are using, on the laptop you might have a wireless N router and a wireless N card on your laptop which might require higher security. you'll need a WPA2 - personal for the key. that you can configure your wireless router manufacturer. hit me back.
Apr 27, 2009 | Acer Aspire One PC Notebook
Need to re-connect to linksys
connect to your linksys using ethernet cable try configuring your modem/router again. if this does not solve your problem reinstall your wireless driver in your computer.
Apr 23, 2009 | Acer Aspire 5315 Notebook
D Link DIR 615 and Acer notbook not talking
Run the windows wizard to setup a network connection from the control panel. Be sure you have the security type and code if you have security enabled on the wireless router.
BXH_5
Jun 17, 2008 | D-Link DIR-625 (790069292637) Wireless...
No connection to internet
What version of windows are you running? 98, 2000, XP, Vista?
Nov 15, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I cannot connect my laptop computor to my main computor
Bluetooth is not WiFi,   they are two seperate technologies.
you need a Wireless adapter 802.11b/g for your laptop,
you would connect the two to each other using an adhoc connection,
If you had a wireless router for your internet you could connect directly to the router, (and then you would not have to have your main computer on for you to access the internet.
BTW if your Main machine is near your phone point (for internet connection) you would not need a wireless card for your pc, as you could connect via LAN cable to the wireless router (make sure you get one with lan ports)
Oct 15, 2007 | NetGear - WG311 - 54Mbps 802.11g/b...
Acer Ferrari 3200 Notebook Logo
202 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
