Question about HP OfficeJet 7310 All-In-One InkJet Printer
Carriage jam I need help clearing a carriage jam
  • Wepichotta Nov 12, 2008
    I have gotten carriage jam errors and now the print quality is horrible. I have tried aligning and cleaning print cartidges to no avail. The letters are printed on top of each other and anything that shows in a box, the perimeter box lines are jagged, similar to what you would find on an "etch a sketch." Also, as it moves further down the page, the margins move over to right about 2-5 spaces on each line.
  • 679 Answers
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.
Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Posted on Feb 03, 2009
How to clear carriage jam?
Hi there! in order for you to clear the carriage jammed of your 7410.. kindly check this link below..
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00304007&tmp_task=solveCategory&lc=en&dlc=en&cc=us&site=null&key=null&product=391194
if the steps didn't help you on how to fix the carriage jammed then there's something wrong with the printer itself.
May 17, 2011 | HP OfficeJet 7410 All-In-One InkJet...
I just changed the (2) ink cartridges in my HP PCS 1610 All-in-One HP printer and now get an error message "CARRIAGE JAM - OPEN DOOR. CLEAR CARRIAGE JAM, AND THEN PRESS OK." I don't see any jam...
Have you tried moving the carriage to see if it really is jammed? Maybe you haven't put the levers down properly on your new cartridges....remove them, see if the carriage slides, then refit them and check the carriage again. You wont visually 'see' a carriage jam,; you have to try moving it. By the way, if it doesn't move, DONT force it to try and overcome the jam try and reason out why it doesn't move.
Hope this helps!
nicam49
Jan 18, 2011 | HP PSC 1610v All-in-One Printer
I get a message carriage jam and told to clear jam. However there is no paper jam. It tells me door open and it is not open. It seem the door does not go all the way up. I keep getting the message that...
It seems you mistook Carriage Jam as Paper Jam, but they are different issues. Carriage jam means the carriage that carries the cartridges is jammed which needs to be moved or be cleared manually after opening the door.
Please follow the instructions mentioned here (Click Here) [source HP Support].
Good Luck.
Let me know if you need further help.
Jan 14, 2011 | HP OfficeJet 6210 All-In-One InkJet...
What is a carriage jam
here are some solutions for your carriage jam error.
1. Clear any jam...remove loose paper.
2.Clear the jam from the back of the printer
turn off the printer...remove the rear access door..
pull the paper out of the roller and return the rear access door.
3. Clear the paper jam from the front of the printer..while printer is on..open the carriage access door..
disconnect the power cable from the back.. remove the paper output tray.
look inside the product..check for torn papers..gently pull out the paper fromthe roller...return the paper output tray and the carriage access door. plugthe power corn and turn on..
4. Make sure the carriages move freely...while the printer is on.. open the carriageaccess door.
disconnect the power cord from the back..remove the paper output tray...lookinside if the carriage is stuck and if there is no papers or object that restrictthe carriage to move..return the output tray.. return the carriage accessdoor...
And lastly after doing this steps try to reset the printer and try to print..
To reset the printer....press the power button to turn on theprinter..disconnect the power cord from the product..disconnect the power cordfrom the wall outlet.. wait for 15 seconds.. plug the power cord to the wallsocket....plug the power cord at the back of the printer.. press the power onof the printer.. try to print the test page...
http://www.fixya.com/support/t6088190-hp_7400_displayshttp://www.fixya.com/support/t6088190-hp_7400_displays
Good luck! hope this solve the problem
Much appreciated if you rate this help.. thanks
May 10, 2010 | Office Equipment & Supplies
Officejet G85
For the paper jam you remove the back cover and clean the 4 rubber rollers with alcohol, you can rotate the rollers forward while you clean. For carriage jam you start by cleaning the encoder strip that runs across behind the carriage unit, the clear strip with black bars on it, you can wipe with a Q-tip damp with alcohol. If no help you may need to take apart and clean dried ink off of the service station on the right.
Feb 01, 2010 | HP OfficeJet G85 All-In-One InkJet Printer
Paper Jammed. Have appeared to remove all paper. But I keep getting "Carriage Jam, open door, clear carriage jam then pres OK" message. Message on my computer screen says "The print cartridge carriage is...
HP support has extensive documentation for both paper and carriage jams for your model:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00304007&lc=en&dlc=en&cc=us&lang=en&product=391182
I hope this helps!
Dec 10, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Clear carriage jam -hp d7460
Carriage jam usually comes from ink on the clear encoder strip that runs across behind the carriage. You need a damp Q-tip to clean from one end to the other, The other thing, on the HP is the cleaning station on the right gets gummed up with old ink and won't go toward the back fully, stopping the carriage.
Sep 17, 2009 | HP Photosmart D7460 Printer
HP 6110xi -clear carriage jam
LOOK BEHIND THE CARRIAGE IS A SEE THROUGH CALIBRATED RIBBON WHICH NEED TO CLEANED, IF IT DOESN'T WORK THE SENSOR BEHIND THE CARRIAGE MUST BE CLEANED
Nov 06, 2008 | HP OfficeJet 6110 All-In-One InkJet...
How do I get fix a "carriage jam"?
I was able to run run a piece of photo paper through a couple of times and printer now seems to be working again. The theory was that running a heavy piece of paper through might help clear little piece of paper that was not visible. The photo paper is less likely to tear if it gets jammed too.
Apr 18, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
139 people viewed this question
Ben Johnson
