Televison & Video Logo
Paul Gil Posted on Oct 18, 2006
DAV3102 not enough volume
I have a 6 month old Oritron DAV3102 and just recently (without any other changes) it won't give me any measurable amount of volume until the volume reads almost "max" where before I couldn't even go to 30% without it blasting way too loudly. I've disconnected everything and reconnected it but nothing seems to change it. It's almost like 0% got moved to where 70% should be.
  • 1 more comment
  • harjan Oct 16, 2008
    I have same volume problems - sudenly high and off anytime. Please let me know all solutions/suggestions you got that resolved your problem.
  • mmaz_snake Mar 08, 2009
    I just posted this problem on the site (without checking this post first). I'm using the speakers supplied with the unit, but I bought new wire because the ones they supply were too short. I've had this unit in storage for a couple of years (while my basement was being finished) and just installed it yesterday. Any fixes that you can suggest would be greatly appreciated.
  • rychor2005 May 15, 2009
    I have the same problem. Is there a solution?
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Dec 20, 2009
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
11
Questions
0
Helped
2080
Points
28
IS THE COOLING FAN WORKING PROPERLY OVER HEATING CAN CAUSE CRAPPY SOUND
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 23, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
360
Points
I have a DAV 3101 and the sound level is much better if the optical input is used. If you use other then supplied speakers you can blow the unit up. It uses 50uF electrolytic capacitors inside the front speakers (3) TO SAVE SPACE IN THE MAIN BOX. However, my unit will shut itself off. Standby light flashes and won't turn on until line cord power is reset over nite. Too bad Oritron doesn't support their products. Their web site is poor. I couldn't find an authorized repair service. Buyer beware! Tom H
1helpful
Is there any problem putting a second trans cooler "in-line"? Would adding enough fluid to fill the cooler affect the fluid recommended fluid level?
You can probably fill the new cooler with liquid and measure the amount it takes, then include that amount in total volume. For instance, when you measure motor oil to a crankcase, some include the 1/2 quart or so in the oil filter to the total volume needed.
I would not see any problem with adding a second cooler. There are some trans pans that have cooling fins or cooling tubes in them. It might accomplish what you want.
tip
Oritron DVD600 Region Free Fix
Oritron DVD600 DVD Player Region Free Fix
Would you like to unlock your Oritron DVD600 DVD Player to Region Free?
Follow these steps to unlock your Oritron DVD600 DVD Player:
  1. Press the Menu button on your remote control.
  2. Using your remote control, enter the code 1, 6 and 7.
  3. Press the Mute button on your remote control.
  4. Press the Okay button on your remote control.
Your Oritron DVD600 DVD Player is now Region Free.
I hope that helps.
on Apr 25, 2010 • Televison & Video
tip
I hope that helps.
White smoke coming out of tail pipe.
WHITE smoke? Or BLUE smoke? White smoke is usually caused by burning antifreeze (possible blown head gasket). Engine oil burning causes a bluish colored smoke.
Changing the oil two months ago means absolutely nothing to me. I have customers that travel 6000 miles or more in a month. Oil consumption is measured in volume over miles, not volume over months. It is normal for most 4 cylinder engines to use a little less than 1/2 quart in 1000 miles (even more than that for 6 cylinder and 8 cylinder engines).
2answers
Oritron DAV3102 No sound to speakers
I have the exact same problem. It stopped working a couple of days ago. Let me know if you find a solution.
Thanks, Nicco
[email protected]
Sound Fluxuation
When this happened to me, I trimmed the wire that came from the speaker to the dvd player. I had to much wire exposed and they were touching behind the machine.
7helpful
2answers
GO VIDEO DVD + VCR model: DV 1130 I want only the basic connection
Once the setting for Progressive Scan output is entered,
an image will only be visible on a Progressive Scan compatible
TV or monitor. If you set Progressive Scan to On in
error, you must reset the unit. Pointing the remote at the
player, press the STOP (x) button to stop any disc that is
playing. Next, press the STOP (x) button again and hold it
for five seconds before releasing it. The video output will
be restored to the standard setting, and a picture will once
again be visible on a conventional analog TV or monitor.
Top Oritron Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you an Oritron Televison and Video Expert? Answer questions, earn points and help others
