Question about Kenmore 76129 Air Conditioner
No power ac will not come on at all. it was the second summer i use it . i noticed that the numbers on digital display were flickering and sometimes going off. do you think the part is the problem. i checked the socket and its fine.
  • 42 Answers
Most likely the circuit board, part number 6871A20271A. I replaced this board last summer and it lasted about 4 months ($33/board). I am now trying to find out why the boards are self destructing.
Units belong to my relatives, they own two of them and they are both not functioning, I expect the same problem with the two of them.
Posted on Jun 05, 2010
How to set time
Plug in the unit.
First, the month and date appear, then the
year, and then the current Eastern Standard/
Daylight Time appears in the display.
Press
TIME ZONE
Area number "2" appears in the display.
If you live in the Eastern Time zone, you do
not need to adjust the area setting.
Area number
Time zone
Atlantic Standard/
Daylight Time
(default)
Eastern Standard/
Daylight Time
Central Standard/
Daylight Time
Mountain Standard/
Daylight Time
5
Pacific Standard/Daylight
Time
6
Yukon Standard/Daylight
Time
7
Hawaiian Standard/
Daylight Time
Press
TIME ZONE
repeatedly until the
desired number appears.
The display returns to the clock about 4
seconds after the operation is complete.
Note
During the shipment and your first use, a clock
error may occur. In this case, refer to "Setting the
clock and date" to set the correct time.
When daylight saving time
(summer time) begins
This unit employs Automatic Daylight Saving
Time/Summer Time adjustment. The DST
indicator appears in the display at the beginning
of the daylight saving time (summer time), and
disappears at the end of it.
Daylight saving time begins at: 2:00 AM on the
second Sunday of March.
Standard time begins at: 2:00 AM on the first
Sunday of November.
To cancel the automatic DST/summer
time adjustment and to set DST display
manually
The automatic DST/summer time adjustment can
be cancelled.
Press and hold
DST
for at least 3 seconds while
the clock is displayed.
A beep sounds, and "Aut
OFF" appears in the
display to show that the automatic DST/summer
time adjustment is cancelled. The display returns
to the clock.
Notes
Daylight Saving Time depends on the law in
each country/region, and your area may not use
it. In such a case, cancel the automatic DST/
summer time adjustment before using the set
and set the time manually as necessary.
To activate the automatic DST/summer time
adjustment again, press and hold
DST
for at
least 3 seconds. A beep sounds, and "Aut
On" appears in the display to show that the
automatic DST/summer time adjustment is
activated. The display returns to the clock.
To change the display to the daylight saving
time (summer time) manually, see "To change
the display to the daylight saving time (summer
time) indication."
Setting the clock and
date
To change the setting manually, follow the
procedure from step
Press
CLOCK
for at least 2 seconds.
You will hear a beep and the year will start to
flash in the display.
Press
or
until the correct year
Press
CLOCK
Repeat steps
and
to set the month,
day and time.
After setting the time, two short beeps sound
and the clock starts from 0 seconds.
Pressing and holding
or
changes the year,
month or day rapidly.
When setting the current time, time changes
rapidly by 1 minute-increments up to 10
minutes, and then by 10 minute-increments.
While setting the clock, you must perform each
step within 65 seconds, or the clock setting
mode will be cancelled.
To display the year and date
Press
SNOOZE/DATE/SLEEP OFF
once for the
date, and within about 3 seconds press it again for
the year.
The display shows the date or year for about 3
seconds and then changes back to the current
time.
If you connect the AC plug to an AC outlet while
this unit is powered from the backup power
source, the current date and time appears in the
following order (the same as when the unit is
powered on after a power interruption).
"month and date" (about 1 second)
"year"
(about 1 second)
"current time"
saving time (summer time) indication
Change the daylight saving time (summer time)
adjustment setting according to the following
procedures if you have cancelled the automatic
DST/summer time adjustment.
Press
DST
The DST indicator appears in the display and the
time indication changes to the daylight saving
time (summer time).
To deactivate the daylight saving time (summer
time) adjustment, press
DST
again.
May 24, 2015 | Sony SY-ICF-C414 Clock Radio
PANDIGITAL Digital Photo Frame works perfectly except the SCREEN Flickers Black after a few moments
Annemarie, I had a similar problem with an off-brand photo frame from Wal-Mart last year, although in my case the frame would shut down entirely after it had flickered a few times. In my case, I was able to remove the back of the frame's case by removing 4 screws (two were hidden underneath model number stickers) and inspecting the device's innards... what I found was that, as you surmised, there was a loose connection from the female end of the DC-in power supply. The ground connection to the device's circuit board had been poorly soldered, leaving the connection itself loose and a small piece of solder on top of the board and very near the positive connection.
While not being the best solderer in the world, with the aid of a magnifying glass, a solder removal tool, and a ColdHeat soldering wand, I was able to heat the offending piece of solder and remove it from the circuit board and then, as I was personally uncertain of my ability to re-solder the connection without melting the board, I simply held the connection in place and applied a dab of hot glue to keep it there. After the glue cooled, I reassembled the case and the frame worked for almost another year before something else finally burned out and it was left cold and dark.
Hope this helps, good luck!
Dec 03, 2013 | PANDIGITAL 7-Inch Digital Photo Frame with...
Rebel T2i won't power on
I had this problem and thank you to the gent that suggested there was a battery compartment closing detection mechanism. I have a battery grip and had removed that to register my t2i (needed the serial number on the bottom) and never checked operation after replacing. I toyed with the lever using a pen and noticed the red light flicker. I replaced the battery grip with batteries and all is well.
Sometimes we need a nudge to dig deeper... I had looked at the possibility of a door closed switch much the same as the the switch on the sd card door. I took a second look and found it. Thanks a million for jogging my analytical brain!
Dec 07, 2012 | Canon EOS 400D / Rebel XTi Digital Camera...
94 deville concours ac works sometimes then u here duct door close and digital climate temp numbers go to blank dashes and defrost comes on and is stuck wont turn off then digital numbers come back on
My first guess would be a wiring problem or the controller.
If anything goes wrong with the system, it will default to the defrost mode for safety.
Jul 10, 2012 | Cadillac Cars & Trucks
DELL Inspiron 5150 isnt booting
If it doesn't respond at all with no ram or hdd, it is likely that the board is in fact dead.....sorry. When you say you found a broken pin, I assume you mean one of the contacts from the power jack to the main board had a cracked solder joint and you resoldered it. If this is the case, try disconnecting and reconnecting the connector from the lcd panel to the mainboard. It may just not be making contact. Also, if you boot up with the hd installed, do you see the hd activity led flashing like at a normal boot? If not, sounds like a dead board. Try pulling the optical drive too if you haven't already. Try connecting to an external monitor too.
Hope this helps!
Aug 17, 2009 | Dell Inspiron 5150 Notebook
AC compressor has short cycle. Constant on/off every 2 seconds.
have you checked the compressor oil it may be seizing up
Mar 18, 2009 | 2002 Ford Explorer Sport Trac
My Averatec 3200 turns of randomly...
Check the CPU and Fan/Heatsink assembly. I have a pretty good feeling that the CPU is heating up too much and is not being cooled properly. There may be lint or dust clogged in the fan. You can get access to this pretty easy by removing a few screws on the bottom panel that houses the CPU/fan.
Feb 20, 2009 | Averatec 3200 Notebook
Failed on restart, had all lights, now no lights and won't do anything!
sounds like your ac plug to the laptop might be loose you can try ans see if you can resolder it back. the other problem is your ac cord might be broken wiggle it around see if the light flickers.
Jan 03, 2008 | IBM ThinkPad R50e Notebook
Hp Laptop screen flicker
Hi, i noticed that when I unplugged my HP the screen stopped flickering. I then re-plugged in the power, when to the Nvidia control settings, to PowerMizer, and changed 'ac outlet' to Maximum Power Saving.
Not the world's greatest solution, but hey, working laptop now.
Cheers,
Andy.
Nov 21, 2007 | HP Pavilion zd8000 Notebook
Kenmore 76129 Air Conditioner Logo
125 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
