Question about Denon DHT500SD System
Denon dht500sd surround system
Saying protect then switching to standyby
  • 34 Answers
You need to check your speaker wire connections at the speakers and at the amplifier. You must have a positve and negative speaker wires touching. If you check them and still same result you need to unhook all speakers from amp and speakers and hook up one speaker at a time to see if you get message for each speaker and when you finally do you will know which speaker wire and speaker is giving you a problem.
Posted on Nov 09, 2008
Denon dht500sd /when playing DVDs we get the sound but no picture,a new laser has been fitted but it is still the same
It's probably an electronic fault. You need to trace the path of the picture signals after it leaves the laser. You might need the circuit diagram for it. But suspect any major IC that deals with the picture.
Dec 03, 2016 | Denon DHT500SD System
System says no disc when I have put on ein
Is this a burned disc, or a factory-pressed DVD?
Apr 21, 2008 | Denon DHT500SD System
Every time I switch on my denon dht 500 sd it turns on then the word protected comes on then shuts off
My guess is you have uninsulated speaker wires touching, probably in the back of the receiver. If speaker wires touch (short) like that, it should put the system into protect mode to keep from blowing the amplifier section. Good luck!
Jan 06, 2013 | Denon DHT500SD System
"PROTECT" appears on my DENON DHT-500SD
Sounds like a speaker wire is shorting against either another speaker wire or something metallic. Check your speaker wires to make sure they're not shorting (touching). If that doesn't work, I'd take it to a repair facility. Good luck!
Feb 16, 2010 | Denon DHT500SD System
Schemat denon dht500sd
type in dht500sd schematic u should get excellent results
Aug 08, 2009 | Denon DHT500SD System
Can anyone help to explain why?
The output section has a problem and the amp is in "protect" mode. This will most likely require the replacing of the output transistors and a few other parts. Figure about $20 in parts plus your local labor charge.
Dan
Mar 19, 2008 | Denon DHT500SD System
PROTECT
I would say to check your manual, and if not, get it repaired (if you can). If you need to use a last resort, then just replace your dvd player with a new one.
Mar 09, 2008 | Denon DHT500SD System
Denon 500SD
HI
did you get this fixed? I have the same problem. Stuck on stand by doesnt switch on from remote or the unit.
please help
Dec 28, 2007 | Denon DHT500SD System
Denon surround saying protect on display
Make sure none of your speaker wires are touching, this will cause it to shut down instantly.
Oct 15, 2007 | Denon DHT500SD System
Denon DHT500SD System Logo
205 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
