Question about Panasonic Lumix DMC-LC33 Digital Camera
Error message I have a panasonic DMC-LC33 digital. A system error message would show the minute I turned it on. The lens would come out. Then within 4 seconds the lens would go back in. I tried the on/off several time but the results were the same. I put the camera away for later. When I tried it the other day, it would not even turn on. The batteries are fully charged. Help!!!!!! I need my camera for my work.
  • 1 more comment
  • Kanzalia May 05, 2008
    Yes! Same Problem here! Trouble Shooting in Cam Manual suggests pressure to the lens. So I took an Air Hose to the lens numerous times during the 3-4 seconds the lens would come out before retracting back in and giving the "System Error" message...this did not help! I called Panasonic Tech Support at 1-800-211-7262 and they told me they charge flat rate fee of $111.50 + my states sales tax to fix cam and to send Cam TO: Panasonic Camera & Digital Repair Center 1590 Touhy Ave. Elkgrove, IL 60007......I am to send cam, a check or money order and my contact info....Hmmm, sounds to me like a standard operating system malfunction for them to make another 120 bucks off of me...Surely there has to be another way for me to bypass this malfunction!
  • murphy1770 Sep 02, 2008
    I am having the same problem what is the solution?
  • Anonymous Mar 14, 2014
    When i turn my camera on the lens comes out for a couple of seconds, but then goes back in & it shows me a lens error message. How do I remedy this?
*&%$@#%^&*&^% !!"It's working!!!! Turn your camera on and put it near your ear. Did you hear a softly motorized sound in the lenses area and the green LED is flashing? If you hear this sound do this. Do it under your own responsability. (any way your camera does not work). When you turn on the camera wait until the lenses come out, in that moment grab the lens with your hand and don't let it go back. The camera will turn off but the lens will stay out. With the camera off push in the lens with your hand. Turn on the camera and that's it. I had to do it 2 times, but now my camera it's working again. This system error could be caused because the lens get out of it rail and the camera can not set the focus system.
Posted on Aug 05, 2007
Another Solution: I let the Lense come out and then quickly take out the batteries.
With the lense out I gently tap the bottom of the camera on a table top. Next wipe both lense barrels with a clean cotton cloth.
Put the batteries in and the camera works great.
Repeat process if camera lense is not put back in it's track.
Posted on Aug 23, 2009
    Problem Solver:
  • 8 Answers
thanks a lot this trick worked for me on the second attempt
same camera same message
Posted on Nov 30, 2008
It sounds like your breaking it but it does work. thanks so much
Posted on May 20, 2008
Klomtrix's method is great and my camera now is ok!
Posted on May 10, 2008
Thank you klomtrix' it's done and it works!!
Posted on Sep 18, 2007
I just tried Klomtrix' solution, and it worked first time!!!!
Posted on Sep 13, 2007
2 Suggested Answers
SOURCE:
  • 8 Answers
SOURCE: error message
try Klomtrix trick this worked with my camera thanks klomtrix
Lumix DMC-ZR1
This is a lens mechanism fault. USe can of air and spray on surrounding the lens For cleaning the dust. and then try.
Aug 05, 2012 | Panasonic Lumix DMC-FZ28 Digital Camera
Camera lens will not retract - sistem error (focus)
Lens errors (system errors on Panasonics) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Aug 28, 2011 | Panasonic Lumix DMC-LC33 Digital Camera
Cannot format a maxwell class 2 4 gb card for my lumix dmc-lc33
The DMC-LC33 is designed to work with SD cards. Your 4GB card is actually an SDHC (Secure Digital High Capacity) card. While it fits into the slot it will not work. You need to use SD cards, 2GB and smaller.
Aug 24, 2010 | Panasonic Lumix DMC-LC20 Digital Camera
When i turn on my panasonic lumix dmc fz28 it shows system error
HI there the camera lens guide pin is damages and thats why not zoom the image properly . You got the system error message. So you need to replaced or repair the lens guide pin. Thanks.
Apr 01, 2010 | Panasonic Lumix DMC-FZ28 Digital Camera
When I turn the camera on, the lense expands and then retracts. The viewer then displays "system error"
there is no image formation,u cannot see image on ur lcd/veiew-finder,allienment of the lens unit is defective/sensors of the lens unit problem,so take to a camera tec.
Mar 16, 2010 | Panasonic Lumix DMC-LC33 Digital Camera
System error
What is the error message and the brand of camera.
Jan 05, 2010 | Panasonic Lumix DMC-LC33 Digital Camera
Error message
Oct 25, 2008 | Panasonic Lumix DMC-LC33 Digital Camera
hello,
i had the same problem , and i tried
Klomtrix solution on the same website, it worked for me thanks Klomtrix sethu
Oct 29, 2007 | Panasonic Lumix DMC-LC33 Digital Camera
Lumix DMC-LC33 system error
I had the same problem, just shake it abit ... I guess the camera is getting old and something is kinda of lose .
Aug 05, 2006 | Panasonic Lumix DMC-LC33 Digital Camera
Panasonic Lumix DMC-LC33 Digital Camera Logo
751 people viewed this question
Top Panasonic Cameras Experts
skyblue007
deton8 von Splosion
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
