Question about Kodak Easyshare M753 Digital Camera
Locked lense lense (optical aspheric lense) is locked and wont open and close normally and now i cant even turn my camera on or charge it or get pics frm the camera on the computer..! help me please..
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
Try these procedures.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Posted on Oct 14, 2012
3 Suggested Answers
SOURCE: optical lense stuck in the "out" position
My camera had this problem too. Try replacing the batteries. That worked for me.
Posted on Dec 31, 2007
lock123
  • 6831 Answers
SOURCE: When I turn on my camera I am getting error like
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 27, 2010
Camera S5200 nikon said battery exhausted when i went to take pic so I plugged it in to charge. light blinking but even though it looks like it is charging I cant turn it on to close lens
give it some time to charge up maybe? Ive seen electronics, even tho plugged into a power source, wont power on until theres a bit more charge on the battery, Idk why, but thats my only suggestion
Nov 01, 2013 | Cameras
Ex-s770 start to turn on then turns off
hi the problem is going to be with the lense motor jaming and not letting the lense come out all the way to switch the camera on to take pictures what should happen is the lense should come out all the way the go in just a little bit so that it focuses it does this so that it resets the lense for when the screen comes on.
If the camera has been put down with the lense out and any pressure has been put on it and put the lense out of line then this will cause the problem your having.
But the even bigger problem is their is no way of repairing it as most shops dont repair the smaller digital cameras so the chances of getting someone to look at it is a bit remote.
The only thing you could try is when the lense comes out try and pull it gently a bit further and see if that lines it back up as their a sensor on it so that when the lense comes out it switches the camera into the mode to take pictures but you can acess the pictures with the lense in so you know the batterys fine and that the circuit board is also fine.
It just the lense i know you cant get replacement parts for your make and model the only spares you can get is batt and cards so gently pull the lense if you can you cant damage it anymore than it is anyway can you.
Let me know how you get on ok.
Jan 29, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Sometimes my viewfinder goes dark and the lens' autofocus stops working. What does this mean, and how should I fix it?
In all probabilities, the mirror lock-up feature of the camera is on. When the mirror is locked in the upright position, the optical viewfinder will go blank. This will also prevent the AF from working. If the mirror lock-up feature is not on, then the camera's mirror box could have been damaged. If this is the case, then the camera would require a minor repair (alignment of mirror) by a service center.
May 12, 2010 | Sigma HF 28-80mm f/3.5-5.6 Aspherical...
My Kodak af 3x optical aspheric lens camera won't turn on. it was fine yesterday but today it wont turn on. I've charged it and everything but it doesn't do anything. Help!
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
If issue persists, call 1.800.235.6325 for repair.
Sep 24, 2009 | Cameras
I own a sony cybershot dsc w35 when i switch on the screen displays "turn the power off and on again" help?
Hi. I had exactly the same problem with my Sony Cyber-Shot DSC-W7. The problem started after while lense was fully open, the battery became 100% empty. I did not have access to new batteries and did not have my charger with me so I put the camera on my car seat and went home. After charging the batteries, I turned the camera Off and the lense retracted 100%. Later on I tried to transfer some pictures to my PC. After connecting the camera to my PC with the dial in the P position and lense fully open I turned the dial to play in order to transfer photos. After transferring the pictures, I turned the camera off and disconnected from the computer.
I turn the camera on to take new pictures next day, The lense would go up, and and turn with lense fully open. It would never close. The screen was black with a message "Turn the camera on and off again". I tried 30 times or more and the same thing would happen again.
Here is what I did to fix my camera and it has been working normally since then.
1- I cleaned around the outside of the lense with lent free cloth
2- I used dust OFF to get raid of the remaining small dust particles from around the lense.
3- While turning the camera off, I pushed (down, up and turn) the lense in (NOT TOO Hard) by my hand. If you push the lense too hard, you may damage the mechanicall moving parts of the lense.
4- After a few tries, the lense retracted 90% +. I then pushed the lense a little harder all the way in, the way it normall retracts. The lense cover also closed 100%.
5- I turned the Camera on and off a few times. It was opening and closing exactly the way it used to. My Cybershot has been working okay since then.
I read a lot and here is what cause my lense to malfunction.
While lense was fully open and battery died, some small particles got on the lense and prevented lense from fully opening or closing.
In summery: two things could have caused your camera lense to malfunction.
1- if you had dropped your camera hard, some mechanical parts may have got damaged or dislocated. In this case you have to open the lense and replace the damaged part, clean and put it back on the camera. This is too risky for most ordinary people. You would most likely make it WORST.
2- If you did not drop it, most likly, some how some small dust particles got on the outside of the lense and they prevent the lense or the lense cover from fully opening and closing. If this is your case, please follow exactly what I did and your camera would be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 25, 2009 | Sony Cameras
Lens keep extended in an out
Jun 25, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
My Sony Cyber-Shot DSC-W55 camera does not turn on properly. When I press the gallery button, everything runs smoothly. When I press the on button, the lens opens and closes several times, making a little...
Jun 25, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
When i turn on the camera the lens wont pop open even when the battery is fully charged.... i was taking pictures and it working fine turn the camera off and on again then the lens wont open anymore? i can...
The problem is
1- some dirt somehow got on the outside of the lense. After it was retracted fully in, it prevents the camera from opening again. When you turn it on, if it opens a little bit, try to pull it out NOT too hard and let go a few times. If it opened, clear the outside of the lense. Your camera should be back to normal.
2- If you droped the camera, you probably damaged or dislocated a mechanical part of the lense. You may have to take out the lense by unscrewing it and inspect it for damged parts or disconnected cable. Make sure clean the lense and test it by moving it in and out a few times, before puting it back on the camera.
Good luck!!!!!!!
Jun 10, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
My sony camera displays Turn camera off and on again
I had exactly the same problem with my Sony Cyber_Shot. Here is what I did and the problem was fixed. While I turned the camera off, I pressed down the lense very softly (some up and down motion). After a couple of times, the lense retracted almost completely. Then I pressed a little harder until the lense retracted 100% as normal times. I turned it on everything was back to normal. If the lense does not have mechanical problem, you should be able to do what I did.
If there is no mechanical problem, most likly some dirt got on the sides of the lense while it was open. Try keep it very clean always.
Good luck;
Jun 09, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
HP R707 Digi Cam...zoom lense not working
I had the same problem - try to wiggle the zoom lense really carefully and the switch it on again. The zoom objective is canted a little bit and the motor is too weak to move the zoom objective. You can also open the camera by removing all 8 screws around the camera and then removing the metal front (Just pull it in the direction of the zoom lens with your fingernails). Then you can access the zoom lens better ... Andy
Sep 05, 2007 | HP Photosmart R707 Digital Camera
Kodak Easyshare M753 Digital Camera Logo
50 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
