Question about Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2 OHMS => Model PV2000 Car Audio Amplifier
Ive bought a Peavey 1500 pa amplifier and would like to know are the a b knobs on the front treble and bass.If they are how would I take the outputs at the back of the amp to my Soundcraft mixer.
The Peavey A/B controls are output gain controls. Your mixers stereo output goes into the amps inputs, channels A & B. The Peavey is the output stage to your speaker system. If you you connect the outputs from a power amp to the inputs of a mixer you will blow the mixers input stage, amongst many other things and possibly damage the amplifier too. The bias (Bass, Mid, Treble controls) are on the mixer, not the amplifier. Unless you are using a mixer amp, which you are not. A PA system DOES NOT work in the same way as an intergrated hi fi amp.
Posted on Nov 25, 2008
Yes I agree with Punkey Ren...also note that the A gain control ( volume control) is the equivalent of a left control and that B would be equivalent to the right stereo channel. You don't have to use this amp as a stereo amp though. You can use it as 2 separate mono channels. Note also that the input and output jacks on the back are marked for channels A and B as well...I agree witht he other comments. The outputs of this amp should only be attached to speakers for use or some other appropriate test load for repair
Posted on Jan 25, 2009
Is the bass boost the gain or frequency knob?
Bass boost simply adds DB or gain to the bass signal. Some like it, some dont.
The frequency knob is the Low Pass Filter (LPF) that cuts off the amp output above
the set frequency. A bass system usually cuts off below 400 HZ and more often 200HZ.
A good, rattle your car bass note is in the 25-80HZ range or lower but most amps and audio
input devices cant attain a good low note with clarity.
"Low-pass filter allows only frequencies below the crossover point to be amplified. A high-pass filter allows only frequencies above the crossover point to be amplified - useful for keeping low bass away from small speakers, so they can play more efficiently."
Checkout Crutchfields Glossary of Car Amps.
http://www.crutchfield.com/S-LPyoWWgD5qN/learn/learningcenter/car/amplifiers_glossary.html
Mar 14, 2011 | Rockford Fosgate Car Audio & Video
I have Peavey Bass amp TNT 115 combo it is 5 to 6 years old.. Recently, while playing on the stage the output went off.... and the amp is receiving the input signals but cannot get the output!!! Please...
Have you tried to open , if so does it have protection fuses or if are they still good
Does it have a fault protection indicators like leds if so
If the above don't apply check the output device but first comfirm that both vee a vcc is reaching the output devices
Dec 06, 2010 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
How to get the best sound
punk and metal tones (late 80s): treb-7 mid-6-7 bass 6-8, presence 6-10, gain/distortion all the way up. classic rock just turn down the gain/distortion to 6-7. bridge pickup
metal mid 90s & up: treb 6-7, mids 3-5, bass 7-9, gain all the way up, presence (which is a mid and treble boost) 4-6. bridge pickup
blues SRV: treb 6, mid 6, bass 7.5, presence 8, gain 5, reverb (if you got it). use your neck pick up
of course this is subjective and depends on the guitar, cable quality, etc. it looks like a small speaker with a low watt output. that little speaker in there is going to be hard to articulate any tones. more than likely it will have a harsh bit to it cause the value of the pots and the logarythm you hear. reduce treble as needed to smooth out the harsh, keep the mids up.
Nov 02, 2009 | Washburn Amplifiers: 25 WATT Guitar...
I got a 800 watt amp from my friend and he didnt have instruction
What's the exact model of your amp? For taking the higher frequencies/treble out of the subwoofer, the amp should have a little button on the side that says "Hi Pass" or "Low Pass" or maybe an adjustable knob-thing that says "X-Over". These will set a cut-off frequency for your sub output. Some amps don't have this feature, but many do.
May 18, 2009 | Pioneer GM-7300M Car Audio Amplifier
I need a bass knob for my crunch amp
i need an bass knob for an planet audio rxd2400
Mar 01, 2009 | Hifonics TX1505D Car Audio Amplifier
Peavey 1500 PA amplifier, no output from channel A
is amp configured correct
use same input and same speaker on both sides
check output fuse on A
if fuse ok then problem is inside unit
get tech to open and check all input and output wiring
Jan 12, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Need the instructions for a peavey 158 Rage amp
Here is the link to the Peavey 258 Rage. The difference is the 158 is 15w and the 258 is 25w.
http://www.peavey.com/assets/literature/manuals/00583600_4.pdf
Dec 27, 2008 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Lightning strike to powered console.
On a generic level, without knowing the specifics of your equipment, I.E. amp & mixer make/model, you start at the mixers input stage. If an amplifiers output transistors die, they usually cause the amp to trip or blow a fuse, the weakest point in the system. If the amp is not doing this then the chances are, it's an line level problem, mixer related.  Again, you have to list the equipment you have in order for me to be more specific.
Nov 02, 2008 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Eclipse PA5532
I do think you can knowing your Amp is 5channel and 960watts,Yes you can goto radio shack for the potentimeter or goto your local audio store and buy a equalizer So you don't over power your Amp
Nov 22, 2007 | Eclipse PA5532 Car Audio Amplifier
Kenwood kac x621 kenwood kac6402
May i suggest removing the equilizer unless you can adjust the settings for each amp seperatly. The amps themselves will allow you to add bass boost and treble boost. I think the problem your having is trying to run to much bass through your system causing it to distort badly.
Feb 25, 2007 | Kenwood Excelon KAC-X621 Car Audio...
Car Audio & Video Logo
139 people viewed this question
Top Peavey Car Audio & Video Experts
Glenn Boucher
Level 1 Expert
Pablo Gonzalez
Are you a Peavey Car Audio and Video Expert? Answer questions, earn points and help others
