Question about Acer AL1711 17" Flat Panel LCD Monitor
Acer al1711 i have acer al1711 its 3 years old, my monitor is not working its just black  picture when it turn on. I need replacement bulb dememsions for the monitor
  • 3 Answers
We have repaired a couple of these. R1 on board normally burnt also C6 and C22 bad on inverter board. Replace these and it will probably work. R1 is 10 ohm. Capacitors are 220uf 25v.
Posted on Jun 18, 2009
    President:
  • 2,992 Answers
More likely you need the inverter and not the lamp. The inverter supplies the power to light the lamp and that's what usually fails. Also, the inverter is replaceable but in many monitors the lamps are not. There may also be a fuse inside that has blown. I've seen two monitors (not Acers, though) where the inverter fuse was bad, and they've been fine after replacing it. (No reason found for the fuse to be blown, so I just put in another and it lit right up.) You might try contacting Acer to see if you can purchase the part from them, or check online for other suppliers (do a Google search for "acer inverter" or the like).
Posted on Nov 11, 2008
Only one time show ok display on power on than convert black dispaly
This is an old monitor, I remember working on these many years ago.
Anyways, the backlight is bad. The CCFL bulb needs to be replaced.
It is cheaper to scour ebay or something to get another one if this is in a server tray than to get it fixed.
If not, just buy a new monitor. You'll see a world of difference in picture quality.
Oct 13, 2010 | Compaq TFT5000 15" LCD Monitor
Screen goes black after not even a second after the computer is turned on, if I unplug the cord in the back and plug it back in , it will come back for a quick part of a second and then black again, I...
This might and might not be the backlight bulb. It could be the inverter or powersupply.
If you want to try to repair this on your own you will need to take it apart. If you post images of the front and rear of the boards that are inside I can give you a little help on where to start.
Mar 12, 2010 | Acer Computers & Internet
Acer AL1916W about 2 years old. Turned on this
Bad caps in the power supply, common problems with 2-year old monitors, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 25, 2010 | Acer AL1916W 19" LCD Monitor
My monitor screen goes black it lights up about half the scree when i first turn it on then blinks like a light bulb that is not screwed in all the way then goes completly black acer al2002w
vandetucker, You should use your warranty and use it NOW!! When "IT" goes to "BLACK" can you see the WIN-desktop when holding a bright flashlight at different angles 1 inch from screen??? How old is unit? How many "ON" hours does it have? Your monitor isn't any different than a Gateway or LG or Phillips, VIEWSONIC, SHARP, Samsung, Sony, Dell!!! You will need to read a few of my other responses and follow some of the links to web pages that you find already in my profile on fixya, so that you will know what questions to ask about repairing your unit. Let me know WHAT YOU WANT TO DO after you have done some research about your BLACK SCREEN lcd monitor. Here is an option I just know you will love. You can do the trade for new 2010 monitor unit and the technician in the back of the computer store just might put $6 $8 in parts into your old AL2002WSD and have a nice wide screen for the new year. Yeah, and your monitor "blinks like a light bulb" !!! Oh my!! How right you are!!! Do you know anything about "cold-cathode-fluorescent-lamps"? You should also see if Acer has a cash+old swapout program for a same model refurbished unit??? You should also give ACER a little bit of lip about the poor reliability of their short lifespan electronic ballasts and CCFL lamps. Like to know what your going to do! 12fixlouie Bye for now
Dec 21, 2009 | Acer AL2002WSD 20''Widescreen TFT LCD...
Monitor receiving signal, but no image
Hello!
I see many monitor with that trouble.
When you turn on comp., you can have a picture on monitor about 10-30 min. and that go in black screen, or If you change resolution again go in black screen.
You must repair monitor or bay another.
Nov 02, 2009 | Acer AL2416W Monitor
Acer 20" LCD AL2017 does not give a picture @ all.
You can look on eBay for BACKLIGHT FLUORESCENT BULB for your model.
They're around $20.00.
Dec 25, 2008 | Acer AL2032WD 20" Flat Panel LCD Monitor
The display screen has turned black
When you connected the external monitor thto the laptop did it display?
If so then you have to reset the monitor port. Hold down the function key and find the FKEY that shows a picture of a monitor. Press that until you get the laptop screen back.
Typical use is:
  • 1 press = external monitor
  • 2 presses = laptop and dual monitor
  • 3 presses = just the laptop screen
Dec 12, 2008 | IBM ThinkPad R40 2722 Notebook
Monitor problem
Hi...there,
It's turns blue to power safe mode (yellow) it's prevent futher damaged to your monitor. It's seems you got a busted backlight inverter. Need to replaced a new one...Since you only got it for a few months, send it back to Acer for a replacement of a new backlight inverter... Have a nice day!
Oct 17, 2008 | Acer AL1916W 19" LCD Monitor
Acer 1711 LCD Monitor
My Acer AL1711 packed up last week, I bought a new Acer and noticed they have a 3 year warranty. Give Acer a call on 0870 853 1000, and they`ll do a warranty repair with free pick up and return - great service! Not sure if you need proof of purchase or not, luckily I had mine.
Apr 09, 2007 | Acer AL1711 17" LCD Monitor
Open Questions:
Expert%*+-%1+877+778+89+69%*+-%Norton Antivirus Support Phone Number? Call 1-877-778-89-69 is followed by great amount of people because this number is used for solving the issue of virus's problem . It works with the assistance of Nortan Antivirus support phone number and therefore the number is 1-877-778-89-69.Our expert will give advice to you how can you protect better and faster your pc's or Laptop and other devices.Our Team is very experts and experienced. Nortan antivirus offer technical support in a very price effective manner by means that of tollfree service at 1-877-778-89-69.Sometimes customer face the problem of pc or laptop hanging.you must tried to use that number to solve the problem of virus's or hanging problem.Our expert always available for solve the problem you just dial 1-877-778-89-69 and your problem will solved in sort time.So use that number for any Antivirus problem.It provide the facility of shorter wait time and faster help.If your computer is infected please call 1-877-778-89-69.USA TollFree No:-1-877-778-89-69.Our customer Centre is all Always Opened in24*7.We are Nortan Antivirus Support USA. For Any Query Call US :-1-877-778-89-69 . Norton Antivirus Support Phone Number, Norton Antivirus Customer Service Phone Number, Norton Antivirus Tech Support Phone Number, Nortan Antivirus support Helpline Number, Nortan Customer support Telephone Number.Nortan Helpdesk number,Nortan Tech support Telephone number,Nortan Antivirus Tech Support Number,Nortan Internet Security Customer Number,Nortan Customer Service Technical Support Number.
May 24, 2017 | Norton Computers & Internet
See all Acer AL1711 17" Flat Panel LCD Monitor Questions
Acer AL1711 17" Flat Panel LCD Monitor Logo
447 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
