Question about Whirlpool Duet GHW9150P Front Load Washer
Wet cloths someone please help
My washer at the end with about a minute left starts adding water after the spin out and then just stops and leaves the cloths soaked any ideas thanks in advance
  • 63 Answers
Timer. "less soap plz"
Posted on Nov 15, 2008
Ge washing machine fills up with water on spin cycle
Sounds like the timer is screwed... Sending out the wrong signals and the dryer is doing the rinse cycle when it should just be the spin cycle. Do t know what your timer looks like in that washer but most now days look like the picture. 11_11_2013_2_52_52_am.png
Aug 16, 2013 | Washing Machines
Kenmore 80 series washer leaving clothes soaked after the spin cycle
In order to fix this, you will need to take off the outer panels and check the motor inside and the clutch, most likely the clutch is worn down and will need to be replaced, I have posted a picture of what it should look like.
Please let me know if you have any other questions or need further help, most likely replacing the clutch will solve your problem.
Good Luck and thank you for using Fixya
Apr 24, 2008 | Dryers
Wme8227b broken?
Possibly blockage in pressure system
Jun 13, 2013 | Washing Machines
Cabrio washer stops spinning and doesn't restart
it sounds like the water pump is not emptying properly, blow down the water outlet pipe to see if is clear if not go to the water pump and clean it out there is probably a button , paper clip or other debris preventing it from doing its job eric
Dec 25, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
Hot water stops filling too soon.
Fill setting has to be adjusted and the belt is slipping on the spin cycle and not generating enough centrifugal force to get the water out.
Aug 25, 2017 | Kenmore 22422 Top Load Washer
The washer won't spin dry. It fills and empties but the clothes are soaking wet.
If washer is spinning but clothes are wet suspect a partial blockage in the outlet pipe. This will cause the water to drain to slow and leave some in the outer drum while spin occurs but this ends up back in the clothes.
Feb 25, 2010 | Washing Machines
My washer spins but doesnt spin on the final spin and leaves the clothes all soaked. it stops at 6 minutes on the final spin
is the machine draining correctly?
the machine will oftin stop if not doing so.
you can try cleaning out the coin trap/drain pump hose.
Jan 12, 2010 | Frigidaire Affinity ATF7000E Front Load...
Clothes are not completely rinsed (they're soaking wet) at very end of spin cycle.
Try to fill minimum water level in your machine with out adding detergent or clothes and complete cycle and see if it is any watter inside. Could be a water pump.
Dec 29, 2009 | Roper RAX7244KQ Top Load Washer
Kenmore HE2 won't finish spin cycle
you have blockage in you drain plug. to solve this problem you'll have to remove the lower front panel of your machine by removing the 3 (1/4") screws on the vary bottom of the machine. once the panel is removed you'll see a 1 1/2" white PVC drainage plug. turn the inner plug to the left in till open. (WARNING ALL THE WATER IN THE DRUM WILL DRAIN THOUGH THIS PLUG) remove debris likes socks or everything that's there replace the panel and your all set.
May 28, 2009 | Kenmore HE2 Plus Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
138 people viewed this question
Dan Webster
Dan Webster
Sal De
